These are instructions that I have put together from my expierience of installing the factory accessory illuminated door sill guards. I used part# 82208040AB. As you can see it is for a Magnum but the lame illustrated only instructions are titled Chrysler 300/Dodge Magnum Illuminated Door Scuff Plates.
First thing I found out after opening the box, there was no primer in the box, the instructions clearly show there is supposed to be. Also there is no double stick tape installed on the scuff plates as the instructions called for.
No problem though, I have read in other threads that the tape is lame and does not hold. Suggestions were hot glue, 3m tape, etc, more on that later.
First step is disconnect the negative battery cable. It probably isn't necessary but I do it anyways, wouldn't want a stupid mistake to cause big problem if you know what I mean. Didn't take pictures of removing battery cable, if you need instructions on this then do not attempt this install. Make sure when you are done to perform battery reconnect procedure. You can find this in the knowlege base.
Second step is to remove the moldings for access to install the wiring. Start on the right side and remove the A pillar trim piece first. This is the A pillar trim
The trim is a bitch to get off. There are two clips, an upper one and a lower one. The upper one is the bitch. Put your fingers under the trim piece at the windshield and get them under the trim piece, pull towards the back of the car at the upper clip. I found that it came a little at first and then was real hard. I tried prying with screwdriver (be careful not to damage trim edges, etc.) and prybar, finally it came with a loud pop. This pic is the A piller trim piece removed. At the bottom (left side of pic) you see a tab sticking out. this connects to a slot in the upper dash, you have to wiggle the trim piece and pull to get it out of this slot, comes out pretty easy once the upper clip is removed (edit: Check post #24, Turf has a easier way to do this step, thanks Turf!)
This is what it looks like with the A pillar trim removed. I have circled where the two clips go into from the trim piece
Here is a pic of the upper clip, it has a head on it and the plastic retainer in the A pillar holds on real tight to this.
Now remove the middle trim piece from the A pillar. It has two clips similar to the lower clip on the upper A piller trim. Just pull straight back towards the rear of the car and this piece pops off
Now remove the lower scuff panel. Start at the back of the panel nearest the rear of the car. Pull straight up working your way towards the front of the car, it has the same clips as the middle panel. When you get to the pillar, just wiggle it and pull and it will come off. It has a clip in the upper part of the panel near the mid trim piece bottom
Now remove the glove box. There is a small rope attached to the right side of the glove box door, it acts as a dampner when opening the door so it does not slam when opening. This is a bitch. You have to open the clip a little bit to get the loop out. You will see what I mean. I used a screw driver to pry the clip open.
Now we drill a hole in the lower scuff panel to let the wires from the plate to go through. The instructions call for 16 1/8" but I added an 1/8" to this. This allows the wires to go through the plate without taking a real hard 90 degree turn through the plate that might cause the wiring to be damaged.
Now we run the wiring. First run the wiring that will splice into the A pillar connector. You can put your left hand up from the bottom and your right hand down from the top the grab the wire assembly. These are the two wires that are tapped together with a cloth type electrical tape. I think the tape used is better for protecting against chaffing.
Start from the bottom
and grab them from the top
Next disconnect the white electrical connector. There is a push tab on the body side of the connection, just push the tab and then pull the connector apart, it comes apart fairly easy. Then pull the wiring harness free from the holder half way up the pillar. This pic does not clearly show the harness holder half way up the pillar but you'll see what I mean. this pic is after I soldered the wiring, but it does show the connector disconnected. You can also see the push tab you need to push to disconnect the connector. It is in the middle of the connector
Next carefully strip the Yellow/White wire which is in position 2 on the connector and the Black/Light Green wire in position 4. I stripped them a few inches from the connector. I know that I am connection the wires to the up side of the connector, but the down side of the connector does not come out very far for access to stip and solder the wiring. There is plenty of extra length in the kit harness to allow attatchment were it is much easier.
Here is a pic of the the wires stripped
Connect the Red wire from the kit to the Yellow/White wire on the car wiring harness. The Brown wire from the kit goes to the Black/Light Green. Solder the wires
