Page 1 of 6 123 ... LastLast
Results 1 to 15 of 76
    DMAG's Avatar
    Feb 2004
    New Yawk
    Installing Automatic Headlight Switch (factory)
    Automatic Headlight How To
    by Jim
    What is "Automatic Headlights"?
    Automatic Headlights is the ability of the vehicle to monitor the light conditions around the vehicle. If the light goes below a certain point it activates the headlights and dash lights for you automatically. Then when the light levels return to a "safe" level the lights automatically turn off. It's standard equipment on the 300 Limited and 300C but not available as a factory option on any other LX platform.
    What do I need?
    The list of parts and tools you will need to complete this mod is very short:
    1. For this to work you must have the climate sensor installed! This sensor is located in the middle of the dash at the base of window. (Fig. 0)
    2. Chrysler headlight switch (part #: 4602348AC)
    3. Trim tool (or some other very slim, rigid tool that can be used to pry. I used a butter knife)
    How do I remove the existing light switch?
    The light switch is held in place by 3 metal clips, two on the top and one on the bottom. (Fig. 1) To remove the switch slide your trim tool into the space between the top edge of the switch panel and dash being very careful not to scratch the dash! Find the clips with the trim tool and push them down and use another trim tool to gently pry the switch panel forward a little at a time switching between the 2 top clips.
    Once you have the top of the switch panel pulled forward you will notice that it catches on a piece of the dash. (Fig. 2) You need to use your trim knife to gently pry the dash up some so that you can pull the control out. Mine made a loud pop when it finally came out, scared me to death but it didn't actually damage anything. Once the top is past that piece of the dash then the whole switch assembly will just pull out. The wiring is connected to the switch using a 5 pin connector that has a locking mechanism. To unlock the switch connection pull the red sliding switch (Fig. 3) on the connector away from the switch. Once its unlocked the connection will pull off the switch very easily.
    How do I install the new switch?
    Connect the wire to the back of the new switch and relock the connector by sliding the red switch towards the light switch. Then simply push the switch back into the dash. The clips will catch and your all done.
    How do I use the Automatic Headlights?
    The only difference between the new switch and the old is that the new switch has an additional setting on the dial labeled "A". (Fig. 4) Just put the dial in that position and your headlights will turn on and off automatically! I leave mine in that position all the time so I never have to worry about remembering to turn off my headlights.
    Fig 0
    Fig 1
    Fig 2
    Fig 3
    Fig 4
    Anthony
    VIDEOBOB's Avatar
    VIDEOBOB is offline Magnum R/T Master
    Dallas, Texas
    Just to clarify, this mod works on the Magnum right?
    I wasn't sure if this was a 300 specific mod.
    SO, the only mod is the addition of the switch and it will automaticly interface with the sensor on the dash?
    How much was the switch?
    Thanks!
    - Videobob
    '05 Black Magnum RT (SRT8 Conversion)
    '02 HD Ultra-Classic FLHTCUI
    '57 Chevy 210 Wagon
    '82 Pontiac Trans-Am (Knight Rider)
    '81 Delorean (Time Machine)
    '74 Dodge Monaco (Bluesmobile)
    '60 Cadillac M&M Ambulance
    '63 Cadillac Convertible
    '80 Checker Marathon
    convbcuda's Avatar
    convbcuda is offline List Lurker
    Jun 2004
    Northern Virginny
    Quote Originally Posted by VIDEOBOB
    Thanks!
    Yes, yes and around $30.
    http://moparsupercenter.com/
    Look under Dodge, Magnum, 2005, Maintenance items, Headlamp switch.
    69 Road Runner Convertible - 528 Hemi
    Jim's Avatar
    Jim
    Jim is offline Thats no moon!
    Apr 2004
    Denver
    New Tip! If you install the switch and it doesn't work but you do have the sensor in your dash try disconnecting the battery for a little while. This solved one users problem.
    Jim
    2006 Inferno Red Magnum SRT8
    2005 Silver Magnum RT - SOLD
    2005 Brilliant Black Magnum RT - SOLD
    rakstr is offline LX Newbie
    Dallas
    Switch changed
    I just called the local dealer and the switch part # 4602348AC has been superceded by part # 4602348AD, The cost is double that mentioned ($60 and change). I'm going to check some other dealers because parts here in the Dallas area can vary an amazing amount from dealer to dealer. I also will try to find out why the new part.
    a12bee's Avatar
    a12bee is offline LX Padiwan
    Nov 2004
    Co.
    Check the vendors from this site, way cheaper than dealer and in a round about way it help support the site.
    My other car has 3 pedals and 100 more inches.
    Earcandy's Avatar
    Earcandy is offline MAG DADDY
    Burlingon, North Carolina
    Does anyone know if you do can just add the dash sensor along with the switch if you don't have it? My wife has a 300 Touring and it does not have either.
    Thanks for the help
    Thanks for the Avatar, Hazman
    Mine:
    Hers: :downboy:
    Mine::twisted:
    51 Chevy pick-up
    http://www.soundsweet.com
    CoolVanilla's Avatar
    CoolVanilla is offline The Dude Abides
    I just installed it with no problem! I ordered via http://moparsupercenter.com/ and received the "AD" version... still was $30.
    I'll need to wait till tonight to see if it actually works though . Thanks for the tip!
    boggart's Avatar
    boggart is online now aka MagnumSXT
    Pittsburg, KS
    I have not heard of anyone installing the sensor. Have any of you?
    bmartin9122's Avatar
    bmartin9122 is offline Thread Killer, Vote Stealer
    Jul 2004
    Texas Coastal Bend
    Talking
    Ordered my AD version today... $34.23 including shipping from South Carolina to South Texas. My local dealer wanted $43.25!!!
    Thank you Mopar Supercenter!!!!
    -Bryan
    current ride: 11 Ram 2500 Megacab CTD 4x4 mod list: none... yet
    previous rides: 09 Ram Crewcab 5.7L, 08 GC SRT8, 06 Magnum SRT8, 05 Magnum RT
    Longhorn Band from Fall 90 to Spring 94
    GOT HEMI's Avatar
    GOT HEMI is offline LX Newbie
    Jun 2005
    miami florida
    Orders mine on E-bay for $35 shipped works excellent!
    Frank
    BlkHemiMag's Avatar
    BlkHemiMag is offline <--- Practice Safe sex
    Jan 2005
    Ft Walton Beach
    I've got my switch and started to install, but I was worried that I'd force it, slip, or break something. I remember reading a post about getting to it the round about way of removing the panel(s) below the steering column, but I've tried several searches and can't seem to find it again. Could someone point me in the right direction? thx
    2005 Magnum RT
    1972 Chev K10 lifted..
    1972 Chev C10 lowered..
    fnkychkn's Avatar
    greasy cardboard box
    Quote Originally Posted by BlkHemiMag
    disconnect and isolate battery negative cable. wait 2 minutes for airbag capacitor to discharge. remove steering column opening cover. from underneath and behind the instrument panel, push up on the lower clip on the headlamp switch then wiggle it down and out of instrument panel.
    BlkHemiMag's Avatar
    Jan 2005
    Ft Walton Beach
    Thanks!
    2005 Magnum RT
    PaCharger's Avatar
    Oct 2005
    Supercharged 2012 Audi A6
    this is an easy one....i found this thread...of course, after i did mine, and put my instructions to pen and paper, see below....
