Page 1 of 4 123 ... LastLast
Results 1 to 15 of 47
Like Tree1Likes
Thread: How to turn off the seat-belt reminder chime
    DMAG's Avatar
    Feb 2004
    New Yawk
    From the service manual:
    Enhanced Seatbelt Reminder Programming
    The seatbelt indicator also includes a programmable enhanced seatbelt reminder or “beltminder” feature that is enabled when the vehicle is shipped from the factory. This beltminder feature provides extended and modified visual seatbelt indicator and audible chime warning responses to an unbuckled driver side front seat belt. The beltminder
    feature may be disabled or enabled by the customer using the programming sequence that follows, or by the dealer using a diagnostic scan tool. The following sequence of events must occur within sixty (60) seconds of the ignition switch being placed in the On position in order for the programming to be completed successfully.
    1. With the ignition switch in any position except On or Start, buckle the driver side front seat belt.
    2. Turn the ignition switch to the On position and wait for the seatbelt indicator reminder function to conclude (about six seconds).
    3. Unbuckle and buckle the driver side front seat belt three or more times, ending with the belt buckled.
    4. Turn the ignition switch to any position except On or Start to toggle the beltminder feature from its current setting (from active to inactive, or from inactive to active). A single chime tone will provide an audible confirmation that the programming sequence has been successfully completed.
    (Thanks to shane for the original post. Note that the red seat-belt reminder icon will continue to appear in the instrument cluster even if the chime is disabled.)
    Anthony
    BlackCharger06's Avatar
    BlackCharger06 is offline Black Charger 06
    Boston
    Thanx
    Thanx Tony. I'm a die hard Red Sox fan so thanking a Met is new to me, but judging from this site I will probably do it very often. At least your not a Yankee fan
    convbcuda's Avatar
    convbcuda is offline List Lurker
    Jun 2004
    Northern Virginny
    Or you could do the smart thing and actually wear your seatbelt.
    I have to because of my allergies. My face is very allergic to windshield glass. If it hits the windshield at a high rate of speed, it starts to bleed and bones break. This can be a deadly allergic reaction.
    NM08SRT8 likes this.
    69 Road Runner Convertible - 528 Hemi
    DMAG's Avatar
    Feb 2004
    New Yawk
    Quote Originally Posted by convbcuda
    I sat in the parking lot at work on lunch today with the car running to keep the A/C going for one hour while I read the paper and ate my lunch. (It was almost 100 degrees.) The trans never came out of Park.
    Think I kept my seat belt on?
    I never...repeat NEVER drive without a seatbelt, but there's times I'm in my car and not driving that I don't want a bell going off in my ear.
    Anthony
    Banshee's Avatar
    Banshee is offline Southern by the grace of God
    East Tennessee CSA
    I turned mine off also..
    Those who beat their swords into plowshares usually end up plowing for those who kept their swords
    SeadooSandi's Avatar
    SeadooSandi is offline LX Jetski tower
    May 2005
    On a lake in Texas
    I don't need a chime to remind me to put my seatbelt on. It's automatic for me but sometimes when I'm just sitting in the car the chime does get annoying.
    '07 Magnum RT RWD Steel Blue with Road & Track package, NC-SXT silver honeycomb grill, 20" Foose Nitrous Chromes
    Other Rides
    '01 BMW Z3 2.5i Roadster
    Watercrafts:
    '97 Seadoo GTX - Hydroturf matting mod
    '05 Crownline 202 BR with duoprop
    Misc Toys
    2010 Wildcat 31TS 5th Wheel
    The last time I refused a beer I didn't understand the question.
    w5blt is offline LX Newbie
    Oct 2004
    Concord, Ca
    What gets me is when I'm out detailing my car and I just want the drivers door open so I can listen to some tunes. I don't want to disable any alarms, but, I would like to listen to some music without hearing a constant "ding".
    Any ideas?
    Bob
    Concord, Ca
    fnkychkn's Avatar
    greasy cardboard box
    Quote Originally Posted by w5blt
    Any ideas?
    once door is open, trip latch using a screwdriver or a pen. that will trick CCN into thinking the door is closed. just remember to release the latch before slamming door or you could damage latch.
    gn300's Avatar
    gn300 is offline Tipmaster G
    Nov 2004
    Nova Scotia canada # 1313
    Alligator clips to complete the circut would be safer than jamming a screwdriver which could scratch if moved,
    Hemi4me?'s Avatar
    Hemi4me? is offline LX Newbie
    Dry Heat, AZ
    Thank You!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    fnkychkn's Avatar
    Quote Originally Posted by gn300
    don't leave the screwdriver there, just use it to trip the latch.
    Hemi4me?'s Avatar
    Dry Heat, AZ
    DMAG,
    If you can figure out a way to get the F*&^ING TPM (tire pressure sensor) light and ding every 10 minutes off as well, I will give you $20.00 cash (or Paypal...)!!!
    I am serious, the sensors would not fit in my wheels (not sure why) and there is no way that I have heard to disable the TPM system...
    Any input on this, reason I asked is that I assumed the seatbelt ding could not be avoided either...
    Thanks
    300MAG's Avatar
    300MAG is online now Going No Place Slow
    May 2005
    Woodstock, GA formally from L.I.
    I read you can trick the tps by putting the wheel sensors into a wheel barrow tire and blow up to proper pressure and put the tire under the seat.
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by davesan
    Better think about that a little more. You have 4 tires.
    SoCal_Magnum's Avatar
    SoCal_Magnum is offline LX Venerator
    Los Angeles, CA
    My procedure for turning off the seat belt chime:
    1) get in the back seat
    2) buckle the seat belt behind the seat
    3) unfold any flapped sections of the belt so it lays flat across the back of the seat.
    4) ride in peace.
    Man's biggest mistake is to believe that he's working for someone else.
