Removal
Step 1
Open the door and locate the small piece of trim that runs along the side of the dash.
Simply grab onto the top or bottom and pull the piece toward you. It will pop off.
Step 2
Pull the weather strip off the pinch weld from around the pillar. You don't need to remove the entire section of stripping, like I did...
Step 3
Grab onto the top of a pillar cover and pull toward you. It won't come completely off right away. There is a stud connected on the top of the pillar. Reach your fingers behind the cover and pinch in the tabs of the piece holding the stud and the pillar cover will release.
Your pillar is removed!
Installation
Step 1
Locate the plastic retainer on the cover's stud and remove it.
Install the clip in the hole of the a pillar frame by gently pinching and inserting.
Step 2
Insert the bottom section of the pillar cover to the dash.
Step 3
Line up the tab toward the middle of the cover and the black stud to their respective holes and push the cover back into place.
Step 4
Reinstall the weather stipping along the pinch weld and the trim piece on the side of the dash.
Congratulations... Your pillar cover is installed!
3Likes
