Order a MOPAR P/N 04565022 switch.
Locate the connector behind the dash.Remove the glove box. Disconnect the cable on the left side by sliding the plastic fitting aft/down to the hole and pull the button end through the hole. Bend the stops on each side inward so they clear the back of the dash and swing the glove box down. Lift upward to disengage hinge from dash and remove glove box.
Feel for wiring harness running along upper aft edge on back side of dash and locate the branch for the light connector. Mine had the connector taped to the main harness with sticky foam tape. Pull the tape off to release the connector and pull it down to glove box opening. You may want to temporarily tape the connector to the back of the dash above the glove box opening.
The attached image shows dimensions for a hole template. I printed this full sized on an adhesive label. Orient your hole as shown or the switch housing will shield the bulb.
Cut the hole for the switch, connect to wiring harness, insert switch in hole, and enjoy.
