This mod is drop dead easy, takes less than 10 minutes (even for me!), and requires no tools.
Stealth Blubs replace your turn signal bulbs, have a silver look to them but light up amber. The product is excellent and gives a nice clean look to your front end.
Here is the drop dead easy install:
1. Pop the hood!
2. Locate the plug for the turn signal. You'll find it at the top of the headlight assembly:
3. After a turn to the right (towards the driverside door) the bulb with connector will unlock and you can pull it free:
4. Grab a hold of the bulb itself and pull it out (a little wiggle may help... the BULB that is!):
Reverse the process for the Stealth Blubs, and you're all set!
Before:
After:
Small clip of the bulbs flashing:
I am very happy with the end result, and the easy of install.
Adam
2006 Magnum SXT
