Here's an easy mod that makes a great difference.....
Time: 10 to 20 min
Tools: adj wrench
Difficulty: Novice
I originally switched my stock Magnum low beams for the hyper white type found at Kragen for $30/pair. Although they were brighter, they left me feeling like I still wanted more.
I checked the knowledge base & found this link from Meister recommending 80w Xenon Super Whites for that HID-like appearance. (Found here: Best fog lamps available) So I ordered the 80w low beams (9006) & 100w fog lamp (9005. although I will post fog lamp replacement on separate thread.) from autolumination as suggested by above post at this link: http://autolumination.com/194.htm
Here is a shot of Hyper Whites from Kragen. (I wasn't quite happy especially cosidering the price.):
So I ordered these at $11.99/pair:
1st: open hood & remove the air filter. (in this case removed Airaid CAI):
loosen hose clamp & remove air intake tube & small hose to valve cover:
remove the filter assembly:
using your wrench remove the screw holding the bottom air box. remove air box:
now with the filter assembly removed, locate the tab that holds the coolant reservior in place.
push tab to one side & the reservior easily lifts up & out:
now locate low beam lamp on driver's side:
making sure not to touch bulb with skin, (I used clean cotton gloves) turn the bulb 1/4 turn counter clockwise to release:
gently pull back saftey clip & wiggle the bulb loose:
install your Super White just as you removed the original:
re-install your reservior & airbox & driver's side is done. The passenger side bulb is easily accessible However, re-installing new bulb is tricky as the wiring alows very little slack & fender wall provides little room:
Make sure you seat the lights correctly, (connection should be straight up & down) to ensure correct alignment of beam.
Picture does no justice! Beam has crisp, clean HID-like look (VERY slight blue hue):
I am extremely happy with the new look & considering the price I'm a winner twice over!
Will post fog lamp replacement as soon as finished.
-thx-
I have new HID's from same place coming and was searching for some install pics.
She will always be missed
