Had an epiphany last night, on how to remove that hood gap that isn't consistant across the hood/fascia line. This process greatly minimizes the impact the hoods' irregularity has on the body gap.
Very easy procedure:
Step 1, go to Lowes/Home Depot/Ace Hardware/etc, purchase 2 bags (or 3 each)
Step 2, open your hood
Step 3, Remove the outer 2 Drivers side fascia pins by prying up on the round center with a screwdriver, gaining enough space to slide a panel removal tool to finish the removal. You can do it with other tools, but I can't guarantee that you won't damage/marr the fastener.
Step 4, insert 2 rubber washers inbetween the fascia and the core support at the outboard fastener, and 1 under the mid fastener. Your application may require a different number of washers, depending on your irregular hood gap.
NOTE: This procedure does not shrink the gap, it takes care of the unevenness.
Step 5, reinstall fasteners, close hood
Step 6, Stand back and enjoy
