Page 1 of 4 123 ... LastLast
Results 1 to 15 of 52
    DMAG's Avatar
    Feb 2004
    New Yawk
    How to install sonar parking assist
    How to install sonar parking assist.
    By DavidA
    Besides the 4 holes in the bumper for the sonar sensors, you need to drill 2 additional holes, one to feed the wire into the taillight housing, and one to get the wires from the bumper into the trunk area of the car.
    This 1st picture shows the taillight housing. Drill through the foam in the upper right with a 1/4" drill.
    Take the spare out and the rear panel that covers the latch. Drill another hole in the back of the car in the flat area just above the spare tire well. I used the same hole saw that came with the kit after I drilled the bumper.
    Drilling the bumper was easy. The tricky part is to measure very carefully so the 4 holes are completely level. Measure the 2 outer holes and start the hole with the hole saw supplied. DO NOT DRILL THROUGH, just the small hole. Use a chalk line from the holes side to side to make sure all the holes will be straight. I measured from the edge of the license plates to get my side to side measurements and drilled on the chalk line.
    I then ran the wires into the spare well. I took out the left side trim and the rear center piece that hold up the roof liner. I then ran the wires from the well into the taillight housing and also ran the LED displays up to the roof area.
    I then spliced one wire to the backup light put the light assembly back in. I drilled a small hole in the side of the spare well and put a ground screw in.
    I connected everything and put the beeper in behind the grill that you remove to get the tail light out...
    ...dressed all the wires, taped the control unit to the side of the spare well, put everything back and then taped the LED displays to the roof. These show which side the interference is close to and also give you a visual as you get close to something.
    The beeper also gives an audible signal .. all very neat.
    There are no wires showing, the beeper is hidden and all you see are the LED's in the rearview mirror. All in all, it took me about 3 hours. The total cost was $54.00 and some time. I also painted the sensors before I put them in the bumper. My car is Magnesium so I really didn't want the flat black sensors stuck in the bumper. After I was done, I re-touched the sensors and that's it.
    Now I can back up at night with more confidence. With the dark windows and the length of the car, I really had a hard time telling where the back end was.
    Anthony
    schexy1's Avatar
    schexy1 is offline LX Padiwan
    Albuquerque
    where did you get the system for $54?
    redinorange's Avatar
    redinorange is offline Curmudgeon
    Nov 2004
    Orange, CA
    ...and could you elaborate just a bit more on the splice information?
    Thanks.
    Attitudes are contagious. Mine might kill you.
    desquirrel is offline LX Padiwan
    Jan 2005
    Rahway, NJ
    A guy on eBay sells a kit for around $45. The kit has 2 sensors. You can "upgrade" to the 4 sensor unit for $15 more. You can specify external tape-on sensors or the hole mount units. They come in a couple of colors. The components look EXACTLY like the $250 Chrysler kit.
    SoCal_Magnum's Avatar
    SoCal_Magnum is offline LX Venerator
    Los Angeles, CA
    What was his user ID...want to make sure I dont buy a fake. I could REALLY use backup sensors
    Man's biggest mistake is to believe that he's working for someone else.
    Nov 2004
    Orange, CA
    Quote Originally Posted by desquirrel
    Are you DavidA?
    FUll Throttle is offline LX Newbie
    Jan 2006
    I quick ebay aearch shows a bunch of guys selling these. Might also be good for the front of my SRT 8 if I can hide the sensors. Might keep us off the parking blocks
    Mike
    quarky42's Avatar
    quarky42 is offline LX Guru
    Jan 2006
    Las Cruces, New Mexico
    Kicka$$. Thanks for fixing the images. I look forward to using the guide when I get my car. I ordered the sonar sensors yesterday.
    Where did you get the paint to match the bumper? Dealer? Or is magnesium pretty easy to match from "off the shelf" ?
    DMAG's Avatar
    Feb 2004
    New Yawk
    Images fixed.
    Anthony
    quarky42's Avatar
    Jan 2006
    Does painting the sensors affect them at all? I noticed you painted them and they look very good that way. I'm in the Magnesium boat also... what type of paint did you use (part#/brand if possible) ??
    lsitter is offline 300C Papa
    Dec 2005
    Greenwood, IN (Indy)
    Question
    Can you give brand and model number for this kit? I'm unable to find it on ebay. Thanks, Lou
    fnkychkn's Avatar
    greasy cardboard box
    Quote Originally Posted by lsitter
    the kit referred to in this thread is the mopar kit. P/N 82208246AB
    XCITsNU's Avatar
    XCITsNU is offline Supporting Vendor
    Jun 2005
    Cincinnati, KY
    I want this, but for the front of my car. I hate thinking about parking, cause I always think I'm going to scrape the front end. More details on this ebay seller and / or kit please. . .
    19 month record holder for Quickest 1/4 Mile All Engine LX vehicle: 11.08 @ 121 MPH - Stroked 426ci 300c SRT-8
    Nightshade's Avatar
    Nightshade is offline LX Guru
    Kitchener, Ontariooooo
    Has anyone ever played with one like this?
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...tem=5827519565
    There are backup sensors in addition to a camera. Provides video display right in the rearview mirror itself... Would mean that ya gotta swap out the mirror for this one.. but is pretty neat nonetheless. (didn't mean to threadjack, but there are lots of offerings out there for reverse sensors and since there is no real integration into the canbus, there is no reason to limit ourselves to factory parts for this.. )
    charlieinnj's Avatar
    charlieinnj is offline 2006 Stone White R/T
    Feb 2006
    Marlton, NJ
    My dealer recommended a unit called "ReverseGuard" The sensors are in the license plate bracket. Works like a charm! I have it.
