Step 9:
I like to call them speed holes
-At the very edge of each side of the diffuser you will find a hole for a body fastener. I suggest using a ¼” 2-piece rivet.
-Due to the position you are in (facing up, with a drill practically right above your head I suggest EYE PROTECTION for this part too).
-I started a small pilot hole and worked my way up to a ¼” bit. I found from my chin spoiler install that the plastic tends to suck the drill through if you try to bite too much, so be mindful of this because as soon and your drill breaks though it will want to just pull itself through instead of removing material (good timing and a well braced arm with prevent this). When you finish drilling the holes make sure the mating surface is clean and doesn’t have material shavings around it.
-Test fit the plastic rivets for these holes. You will have to work fast when you need to put these in and I don’t want you to be fumbling with so be familiar with how they work.
-If the adhesive ever fails (doubtful) this is what your diffuser will look like with the six mechanical fasteners holding it. It definately won't fly off, but it will look kinda ghetto.
-Pull the rivets set them near their specific hole so you’re not looking for them when the time comes to use them.
Step 10:
Home stretch
-At this point you should have done the following:
-Cut the tabs off the diffuser
-Cut out your existing exhaust cutouts to allow for better clearance
-Washed, clayed, washed, and dried the work area
-Taped the leading edge of your diffuser
-Taped your exhaust tips
-Taped the outline of the diffuser on your bumper with a 1/16th” clearance
-Drill the holes in the bumper for mechanical fasteners at either end of the diffuser
-Prep your caulk gun, and cut the nozzle of the adhesive so that you can put down a nice fat bead. (Those of you who have never handled a caulk gun before may want to buy a tube of cheap silicone from the hardware store and practice what is involved in putting down a nice even bead of caulk on a piece of cardboard).
-This stuff is STICKY so try not to get it anywhere you don’t want it.
-Prepare 5-6 pieces of long painters tape that is stuck to the diffuser with about 6-8” dangling free. (I suggest using 3” wide painters tape here).
-With the diffuser hanging by the 4 rivets on the backside of the bumper cover and resting on the exhaust tips start laying a bead of adhesive that basically follows the line of tabs that you cut off earlier. Make sure that adhesive sticks past the leading edge of the diffuser (that way you KNOW it will make contact with the bumper cover). Don’t be afraid to be liberal with the adhesive. I also put a bead following the approximate location of exhaust cutouts on the diffuser (I was able to tell where as they made slight marks from the test fittings). Don’t spend more than a minute or two doing (you really should shoot for 30-45 seconds until you are ready to lift the diffuser into place). You don’t want this stuff to skin over… then you will have problems. It will take longer than that to skin over, but I'm trying to stress the importance of doing this part quickly.
-Lift and push the diffuser against the bumper cover, using the painters tape to secure it in place. Pull it TIGHT and push on the diffuser a little as you do it. You will notice that a little adhesive has squeezed out of the seam. This is good as you know you have good bond right there. Don’t bother with cleaning them now, they will come off easily when they are cured.
-At this point snap in those two rivets at either end of the diffuser.
-Once you get the initial 5-6 pieces of tape up start taping more and more until you don’t see any gaps along the seam.
-I let the adhesive cure at least 12 hours prior to removing the tape. I’m sure you could remove it after 3-4 hours but I wanted to play it safe.
-Don’t forget to button up your exhaust hangers at this point.
Step 11:
Pulling the bandages off
-Easy as pie right? Wrong. If you managed to pinch any of the tape on the bumper cover under the diffuser you will have a hard time getting those little slivers of tape off. Otherwise this step is cake and is very enjoyable to watch the fruits of your labor unfold.
-If you do manage to pinch any tape good luck. I got a lot of mine out just by being able to catch an edge, the really stubborn ones I lightly scored it with a razor blade and then pulled it off with a tweezers. But this leaves a hint of blue in the seam. I’m gonna try and get the rest out with a fine but stiff detailing brush, but haven’t had a chance to give that a shot yet.
Step 12:
Durability testing
-While I was taking the tape off I pushed down pretty hard on diffuser and it didn’t budge at all. In fact it look like it deflected the bumper cover instead.
-Survived an extended and spirited drive (hey I had to test out my new rubber :D) with a few jaunts up to 80 MPH on the small section of expressway around here that isn’t under construction.
-Also survived a touchless high pressure car wash (Lazerwash 4000)
Final thoughts
While I had originally wanted to use a mechanical fastening technique I really feel that this adhesive will go the distance and is very strong. I have complete confidence in it to do its job. Total time from start to finish included the several breaks for photos and taking my time to think was probably 6-7 hours. I could probably do this in about 4 hours now that I know what to do and the order in which to do it. Those of you who are interested in doing this mod shoot me a PM and I would be more than happy to let you pick my brain over the phone. Those of you that are kinda local could convince me to help you for a meal and a beer
if you think you can't do it yourself or don't have the proper tools.
