Page 1 of 6 123 ... LastLast
Results 1 to 15 of 80
    SDMagnumRT's Avatar
    SDMagnumRT is offline My maggie did me proud
    Dec 2005
    San Diego..now Syracuse
    How-to Adjust Sunroof Glass
    I as well as countless other LXers have been plagued by a sunroof that seals well for the first while and then doesn't sit exactly right and it bugs you to death. I have certified this adjustment alcohol friendly so no worries there either..to a point
    Soooo...instead of having to take it to the stealership, get excuses made due to exhaust, baby seats, etc(ask me I got a good one for that) and attempting to get them to adjust it for you why not take it upon yourself to do it as it takes about 5 minutes to get it just right. It can all be found on pages 6750 and 6751 of the LX tech manual which can be found floating around the forum. If you don't have it I highly suggests getting it(it's pricey to buy) because it has a massive wealth of knowledge. It is like having FnkyChkn in your pocket
    Tools:
    All you are going to need is either a screwdriver with a T25 torx head bit on it or a ratchet with a 3" extension and a 8mm or 5/16" socket on the end.
    (I opted for the screwdriver because the bolt holding the glass is close to the glass and I feared scratching the glass with a ratchet and you can easily tighten it with your screwdriver and you may overtorque it with the ratchet)
    Procedure:
    1. You need to slide the fabric cover all the way back just as it would be if the sunroof were open. Note the black plastic mechanism cover on each side.
    2. With your finger pull back on the corrugated plastic guard that hides all of your sunroofs uglies. It feels like it should come off but it does and can easily be put right back, which you need to do when done.
    NOTE: There are three clips on the sunroof that hold the cover.
    3. Now comes the fun part, about 3/4 of the way from the front of the sunroof glass will be a bolt that has a hexagonal head(for you who want to use a ratchet) and the T25 torx bit slot for you screwdriver folks. (My sunroof is in the vent position for the ease of taking a picture, make sure yours is closed).
    4. The LX Service manual calls for the glass to be 0-2mm BELOW the roof on the front and 0-2mm ABOVE the roof in the rear. The torque spec on the bolts is 5.5 N-m or 47 in-lbs which is not too tight so if you want a torque wrench for it more power to you but I used my calibrated arm for this.
    You are going to want to loosen the bolt on the affected side, only do the front or the rear at a time, not all bolts. I put my screwdriver in the bolt as I was standing outside the car and adjusted it from out there because you can tell if it is correct or not and you can tighten it once you get it where it should be. Make sure you are holding the glass as you are tightening it so that it stays where you want it to
    NOTE: Due to the weatherseal material on the sunroof glass when holding it where it should be add an extra 2-3mm(less than 1/8th an inch or so) in height so that once it cycles it will seal itself in the proper place since you pushed it where you wanted it to be and the motor didn't.
    5. With all adjusting done, make sure your bolts that you touched are tight or you will need to go back and do this again in the future. Now you need to reattach the mechanism cover to the glass so it looks all pretty again and doesn't do bad things when you go to open the sunroof. You can push it until you feel it not move anymore. To make reattaching this easier you can vent your sunroof but I chose to leave mine closed.
    6. Test the sunroof now by opening it then closing it. It should be just about flush with the roof. Good job. Now to verify you can vent the sunroof and then close it and make sure it looks all pretty.
    If you need to tweak it just repeat the steps and you are done. Now you can have a cold one for celebration ......or finish the one you were working on
    Hope this helps all and solves any questions
    -Kyle
    05 Magnum R/T Brilliant Black - 4/25/05 to 1/29/07
    bmartin9122's Avatar
    bmartin9122 is offline Thread Killer, Vote Stealer
    Jul 2004
    Texas Coastal Bend
    SDMagnumRT...
    Nice KB Post. I have already linked to it on Dodgeboy for a forum member there.
    BTW, you have your "dirty Mag" pic for the online M&G!!! j/k
    Bean for you!
    -Bryan
    -Bryan
    current ride: 11 Ram 2500 Megacab CTD 4x4 mod list: none... yet
    previous rides: 09 Ram Crewcab 5.7L, 08 GC SRT8, 06 Magnum SRT8, 05 Magnum RT
    Longhorn Band from Fall 90 to Spring 94
    sieb's Avatar
    sieb is offline Mopar Monkie
    Normal, IL
    Sweet, mine just got to the point that I need to do this. Just in time!
    Sieb
    2005 Magnum SXT
    BillyDsl's Avatar
    BillyDsl is offline Longhair/XMarine
    Feb 2005
    Houston, Tx
    Good info and well illustrated..
    How often do you have your arm re-calibrated.. couldn't resist.. j/k
    Thanks bunches
    BillyD..
    2005 Mag/RT, Build Date 1/05, ConvGrp, Sunroof, 6CD/Nav/Gps.
    Mods:K&N cai, Gibson Headers, Flow50s/no-resos,Viper Hood(needs paint :waah, UltimatePedals,
    GTechPro RR, Auto Headlights, Val-1, HIR headlights, Short PlugWires, KW V2, SC-Tuner, FO-LedTails.
    Factory U-Connect.
    Comming soon: flipflop pearl flames, 20" wheels,
    Still in lust..
    marmaduke's Avatar
    marmaduke is offline LX Padiwan
    Feb 2006
    Toronto
    Good write up..
    Has anyone had a sunroof that squeaks non stop? Very annoying. I am going to try an adjustment...
    2006 300CSRT8 - 2006 MSRT8 - 2006 GCSRT8
    SDMagnumRT's Avatar
    Dec 2005
    Quote Originally Posted by marmaduke View Post
    Good write up..
    There is a TSB for the squeking sunroof...it is the actual mounting bolts doing that...lemme look for the TSB # and I will update for that. The squek can be recreated by thumping on the glass on the inside or you can always hit a rough patch of road. I am getting mine fixed next time I go to the dealer
    EDIT: The squeking sunroof TSB is 23-005-06. You can go to the TSB section and look it up under the 2005 Magnum TSB's. I am sure it applies to others as well.
    BUTWEET's Avatar
    BUTWEET is offline GOOD MEAT TAKES A LONG TIME!
    Bothell, WA
    Excellent "how to!" Good pics and tutorial. Have a bucket of beans!
    MY MEAT WILL MELT IN YOUR MOUTH....NOT IN YOUR HANDS! ENJOY THE Q.
    Sublimeon24s's Avatar
    Sublimeon24s is offline Got me a Lime, now wheres the Patron!
    Feb 2007
    Orlando, FL
    good info, ive been hearing about sunroof problems
    joseph's Avatar
    joseph is offline Banned
    Oct 2004
    Las Vegas, NV
    Now I can fix mine, which was fine up to a few months ago, but now sit 1/4" low in the back, I just raised it flush with the switch, and never touched it since then, but now I'll fix it for real, thanks a lot
    bikerinphx is offline AZ LX
    Jun 2005
    In North Phoneix area of AZ
    thanks for this thread i was just about to takle this on my own but this thread will help a lot thanks
    joseph's Avatar
    Oct 2004
    Las Vegas, NV
    I just did mine.
    FYI: you need to loosen both sides to adjust (ie: both front screws loose before adjusting)
    My sunroof is kind of sticking in the middle in the rear, I kept adjusting the rear up and there would still be a gap, then I pushed it up and it moved and ended up being ok, but it was sticking in the middle as if it needs an extra push in the middle to close it good.
    Any remedy for that sticky middle?, is the motor not strong enough?
    DanRealtor's Avatar
    DanRealtor is offline Supreme Being
    Oct 2005
    Thumbs up Sunroof Noise
    I read on the forums previously about using spray silicone to help quiet the sunroof. I finally got around to doing it and WOW: Instant quiet sunroof!
    I sprayed the silicone on a rag and wiped down the rubber seal of the sunroof all the way around and wiped down the painted surface that the seal contacts. INSTANT quiet sunroof for the first time ever.
    I HIGHLY recommend trying this before you go to the dealer and having them attempt a fix.
    Now I can actually drive around wth the shade open and the glass closed without being drven crazy by all the damned noise!
    DanRealtor
    Of Course It Was Me
    but you already knew that...
    perfectwave's Avatar
    perfectwave is offline If Can, Can, If No Can, No Can!
    Nov 2006
    where the weather SUCKS!!
    Very Nice! Thanks for the info. I will be adjusting this weekend.
    Mahalo
    McKinneyMagnum's Avatar
    McKinneyMagnum is offline LX Newbie
    Dec 2005
    McKinney, Texas
    I have just done the above trick (for the 2nd time in less than a year) but after I push up the rear and re-tighten both back bolts (one side at a time) then either vent or open the roof entirely, the glass falls back to its original sagging position. Very annoying. Any suggestions for what I am doing wrong. The last time I did this re-adjustment it worked for 6+ months.
    2005 Inferno Red RT
    Custom CAI thanks to Frankentake III
    Blastin' Bobs 7db
    Flowmaster Delta 50 Series Mufflers
    LED Eyebrows and Blinker Mod
    McKinney, Texas
    SDMagnumRT's Avatar
    Dec 2005
    Quote Originally Posted by McKinneyMagnum View Post
    PM sent
