So, you really want to do this, eh?
This is the first version (06-22-06), I just wanted to get this started with an OEM parts list and pricing, so you know what you're in for.
(06-04-09) Wow, pathetic... 3 years later and I get around to adding more information? Sorry about that. I added info on the underbody shield, brake air ducts, and headlight washer nozzles (to fill those holes!) The headlight washers are confusing. From what I've been told, they require a second pump, additional tubes to feed off the resevoir (obviously), all of which seem to be difficult to track down parts numbers for.
*IMPORTANT NOTES - PLEASE READ!*
-Be aware that the HID light assemblies will physically fit directly in place of the HALOGEN 300C lights. If you choose to go the HID route, you must buy additional wiring harnesses not listed here.
-You must be sure that you order 300C lights and not 300 Touring lights, as they are shaped differently, requiring a different fascia and, possibly, tie bar.
-Some of these part numbers have a zero in front of them in the OEM catalogue, but it is not required to find it...
-I opted NOT to get the headlight pressure washer units as they were expensive and I had no knowledge as to how they would integrate with the washer fluid system and I didn't think I would ever use them.
-It cost me roughly $2,500.00 in paint and labor (all labor) to put this whole thing together, and I feel I was charged fairly and the workmanship - so far - has proven excellent. I will attempt to sort out what labor is related to my crash and which is related solely to the conversion, but I know that paint/labor was a bit over $1,000 alone.
PARTS
4805928AC
300C Stock Grille (fits SRT-8 fascia)
$227.00
5183422AA
Front fender (R)
$88.85
5183423AA
Front fender (L)
$88.85
05112136AG
Hood
$624.00
5030576AB
300C SRT-8 Front Fascia
$464.00
4805843AA
300C Tie Bar (headlights and fasica mount to this)
$210.00
4805729AB
Front Bumper Impact Absorber
$139.00
4805862AH
HALOGEN Headlight Assembly w/bulbs (R)
$324.00
4805863AH
HALOGEN Headlight Assembly w/bulbs (L)
$324.00
4805860AA
Side Marker Turn Signal (R)
$23.85
4805861AA
Side Marker Turn Signal (L)
$23.85
5013995AA
Side Marker Turn Signal Wiring Harness (x2)
$21.75 each
4805858AA
Fog Light Assembly (x2) (Magnum fogs will NOT fit)
$142.00 each
4878883AA
Pin/Retainer (x10)
$3.70 each
6504737
Plastic Rivet (x10)
$0.25 each
6506132AA
Push Pins (x8)
$1.10 each
4860379AA
Push Pins (x10)
$0.75 each
4596521AA
A/C Label
$1.35
4726202AA
Engine Label
$0.45
5029900AA
Air Duct to Brake (R)
$58.52
5029901AA
Air Duct to Brake (L)
$58.52
1BE04ZZZAA
Headlight Washer Nozzle (R) - Brilliant Black (different colors have different part numbers but all cost the same)
$39.04
1BE05ZZZAA
Headlight Washer Nozzle (L) - Brilliant Black (different colors have different part numbers but all cost the same)
$39.04
1Likes
