Results 1 to 15 of 20
    fnkychkn's Avatar
    greasy cardboard box
    Keyless Go Button (tech tip and operation info)
    TECH-TIPS # 29 – 2008 CHALLENGER / KEYLESS GO BUTTON OPERATION AND POSSIBLE
    BATTERY DISCHARGE
    DISCUSSION:
    If equipped, the Challenger is shipped with a Keyless GO Button in the vehicle’s glove box. This feature, if
    the customer chooses to have it installed, will allow the driver to operate the ignition switch without the need
    to physically install the FOBIK into the ignition switch. The GO Button is packaged in a plastic bag with an
    instruction card. The instruction card explains how to operate the GO Button once it has been installed to the
    ignition switch. The instruction card should be reviewed with the customer during vehicle delivery and then
    placed into the owner’s manual for future reference. With the GO Button installed into the ignition switch and
    the FOBIK in the vehicle interior, the GO Button (like the FOBIK it substitutes) will allow one or more of the
    following ignition switch modes. With the brake pedal not depressed (foot off brake pedal) the following
    ignition switch modes can occur: accessory, run, and off. With the brake pedal depressed the following
    ignition switch modes can occur: start-run, and off.
    NOTE: INFORM THE CUSTOMER THE BATTERY IS DISCHARGING WHENEVER THE KEYLESS
    GO BUTTON FEATURE IS IN EITHER THE “ACCESSORY” OR THE “RUN” MODE. THE
    “ACCESSORY” OR “RUN” MODE WILL REMAIN ACTIVE UNTIL THE “OFF” MODE IS
    SELECTED OR UNTIL THE VEHICLE ENGINE IS STARTED. IF THE DEALER OR VEHICLE
    OWNER FAILS TO ACTIVATE THE “OFF” MODE, AND EXITS / LEAVES THE VEHICLE
    WITH THE FOBIK, THEN THE “ACCESSORY” OR “RUN” MODE WILL STILL BE ACTIVE
    AND MAY COMPLETELY DISCHARGE THE VEHICLE BATTERY.
    TO INSTALL THE KEYLESS GO BUTTON FOLLOW THESE STEPS:
    1. Remove the GO Button package from the vehicle glove box.
    2. Position the lettering on the GO Button so that it is horizontal and readable. The GO Button has the
    words “ENGINE START / STOP” on the face of the button.
    3. Gently insert the GO Button into the ignition switch receptacle by pressing on the center of the button.
    4. If the button slips in easily, then it has been installed correctly.
    5. Press firmly on the center of the GO Button to seat the button into the ignition switch receptacle. The
    Keyless GO Button can be removed at any time. Remove the GO Button if the use of the FOBIK is
    desired to operate the ignition switch (instead of the GO Button).
    TO REMOVE THE KEYLESS GO BUTTON FOLLOW THESE STEPS
    1. The GO Button may be removed using the valet key from the FOBIK as a thin tool.
    2. Insert the metal part of the valet key under the chrome bezel at the 6 o’clock position.
    3. Gently pry the GO Button from the ignition switch.
    THE KEYLESS GO BUTTON (ENGINE START / STOP) FUNCTIONS
    With the driver’s foot OFF of the brake pedal, transmission selector in the PARK position and the FOBIK
    must be in the passenger compartment of the vehicle:
    1. Press the ENGINE START / STOP button once to activate the ACCESSORY mode which will allow
    operation of the radio, wipers, and windows.
    2. Press the ENGINE START / STOP button a second time to activate the RUN mode which will allow the
    operation of the heating / air conditioning (HVAC) controls, and the instrument cluster.
    3. Press the ENGINE START / STOP button a third time to activate the OFF mode
    With the driver’s foot ON the brake pedal (brake pedal depressed), transmission selector in the PARK (or
    NEUTRAL) position, and the FOBIK must be in the passenger compartment of the vehicle:
    1. Press the ENGINE START / STOP button once to activate the START-RUN mode. The engine will start.
    2. Press the ENGINE START /STOP button a second time to activate the OFF mode. The engine will stop.
    NORMAL STARTING
    To start the engine, the transmission must be in PARK or NEUTRAL, and the FOBIK must be in the
    passenger compartment of the vehicle. Press and hold the brake pedal while pressing the ENGINE START /
    STOP button once. The system (TIP START feature) takes over and attempts to start the vehicle engine. If
    the vehicle engine fails to start, the starter will disengage automatically after ten (10) seconds. If you wish to
    stop the cranking of the engine prior to the engine starting (within ten seconds) then press the ENGINE
    START / STOP button again.
    ZeGuru's Avatar
    ZeGuru is offline It's me, no really - it is.
    Downtown Saint Paul, MN
    Quick question: If you took the button out of the challenger and placed it in a Charger/300 with the FOBIK ignition, would this work the same?
    fnkychkn's Avatar
    Quote Originally Posted by StPaulGuRu View Post
    no idea. never tried it. i would think that the WIN (wireless ignition node), the part that the FOBIK slides into would be different, if only in programming.
    give it a try and let us know.
    ZeGuru's Avatar
    I'll have to swing by the dealership and test it out. I've just been curious to know if it would work.
    SRT-ED's Avatar
    SRT-ED is offline I swear I'm leaving this car stock. LMAO
    Mar 2008
    Rockaway Park, NY
    Keyless go is the best feature ever... I have it in my wife'w E-class. There have been plenty of times where I have got upto the door of the maggie and pulled on it and its still locked...
    Eddie... 2006 Dodge Magnum SRT8... Yeah Baby!!! N.Y.H.H.
    Air Hammer CAI, American Racing Headers, SLP Powerflo Cat Back, SLP pulley, 85mm TB, Paramount Perf. 3400 Stall T/C and Driveshaft, BT catchcan, Getrag, Blue top AMG solenoids, AMG shifter paddles, Diablo Trinity, 12k HID's...
    mebe's Avatar
    mebe is offline attendee of "UNLAWFUL GATHERING"
    May 2006
    elgin, il.
    i tried it its a no go.. Do they have to be programmed??
    I do only have a 08 touring now so i dont know if that is an issue, but i do have the fobik key.. When i put it in and push the button it the car dinges and the little security light comes on notheing else though.
    Any ideas?
    MODS:???????????????????????????????????????????
    mebe's Avatar
    May 2006
    elgin, il.
    Anybody else have any info on this at all?? fnky??
    ZMagnum's Avatar
    Tucson, AZ
    It won't work in an 08 not equiped with keyless-go. I spoke with a Mercedes mechanic about it a while ago.
    mebe's Avatar
    May 2006
    elgin, il.
    thank you sir!!
    BAKBRNR's Avatar
    BAKBRNR is offline CDXXVI
    Devon, Alberta, Canada
    This would make a nice mod for the 08s if they could be converted. I wonder what it would take to make it work?
    Smoke em if you got em!
    2008 Brilliant Black Crystal Pearl Magnum SRT8 # 160: 426 Stroker with Predator CMR Tune. RIP Blk Magnum R/T
    rxnick81 is offline LX Newbie
    Jan 2009
    Philadelphia
    Had my 09 srt8 challenger at the dealer today for the 2nd time. The dash msg center keeps saying the key is damaged and the car will not auto start. Apparently, there is a known issue with the key fobs. Don't let your dealer make you wait around the service area for 2 hours only to find out they need to new keys and rematch them to the car, like I did!
    Shoeboy23's Avatar
    Shoeboy23 is offline Shoe Pimp Extraordinaire/ Realtor
    Sep 2008
    San Jose
    Can this be put into an '08 300 or Charger...?
    YES, it can be done for 2008-2009 300C/300CSRT's
    It involves purchasing a new WIN module, new Chrysler key fobs (4-button or the 5-button with remote start), a Passive Entry Module, start button, and a couple of Chrysler low frequency antennas. A little wiring is involved. One antenna is installed under the rear seat with a pair of wires running to the dash behind the glove box. At that location the second antenna is installed and wired to the Passive module. The Passive module needs to be wired to the CaN Bus (+ and -), and also to power and ground. To make it all work, a dealer has to do some programming for the new Fobik's, and Passive module. You might be looking at $500-$600 in parts alone...
    Thanks to RESUME SPEED for the above information.
    Last edited by Shoeboy23; 02-22-2009 at 11:20 PM. Reason: RESUME SPEED provided this info...not who i mentioned before. OOPS...Thanks RS
    duce is offline remember the sand ceremony
    Dec 2007
    socal
    But no worky on charger 06?
    Quote Originally Posted by Shoeboy23 View Post
    Thanks to Mr. Incredible for the above information.
    mods: AFE Stage 2, HHP TCM, Paddle Shifters, Lock Pick, Ipod Cable, blinker mod, Billet Tech. Catch Can, Air ram, Predator, EBC Yellow Stuff in front & auto zone in back, Hardwire radar with mirror mount, i995, Corsa Catback, 180 tstat, SVS Tune, Hidgate 6000k lows and fogs, Lighted cup holders, Pistol grip Shifter, blinker mod, custom k-9 insert
    IF YOU FIND THIS FORUM HELPFUL BECOME A PAID SUPPORTER! AND IF YOU FIND IT NOT HELPFUL PLEASE DONATE SO I CAN CONTINUE TO BENEFIT FROM THIS FORUM!
    Shoeboy23's Avatar
    Sep 2008
    San Jose
    Quote Originally Posted by duce View Post
    sorry man...
    BlueBee's Avatar
    BlueBee is offline Nitrous addict
    Portland Oregon
    ohh
    so if i have the remote start setup this button will work? What is the part number, i want one.....
    426 STROKER 11.5CR built by Ding's. INERTIA STROKER CAM, Paramount Trans/TransBrake/TC/FLEX/DS/8.8 Differential with 4.10 gears, rwhp 758/ 731 rwtq
    PB N/A 10.948 @ 124 w/-200DA
    Nitrous PB 10.19 @ 136 MPH
