The Mopar VES system is a console mounted rear display DVD system. It conists of a flip-up LCD screen and a DVD player. The system is extremely well integrated into the vehicle; the only complaint is that there is no 'video out' plug that would faciliate using the VES as a DVD player for other screens in the vehicle.
The possibilities are endless, but by using the nav2go mod from supporting vendor Dominic at www.TVandNav2Go.com one could display DVD's on the front screen if they so wished. Caution -- the general wisdom is that displays of DVDs, TV's etc. that are visible to the driver while the car is in motion are illegal--so use this mod accordingly.
This how-to will show how to fabricate a video-out feed from the VES. It does not deal with how to install the nav2go mod -- that has been covered elsewhere in the forum. A nod to cbutler32 (a member here but mostly on the 'other' forum) - he was a very strong advocate of this mod and his research lead me to the internal wiring harnesses that for me, were the key to getting this done.
To do this mod, one has to be comfortable with stripping insulation off of and soldering tiny little wires. The pics are close-ups, in the real world old guys like me need double magnifying spectacles just to see these tiny conductors.
The VES does not have to be removed from the vehicle, however doing so may help you position things to solder better.
Depending on how comfortable you are with this stuff the mod will take a couple of hours to half a day.
Tools and supplies needed:
-fine phillips screwdriver
-pencil soldering iron
-sharp, thin blade knife
-solder with flux core
-butter knife (to remove trim cover)
-needlenose pliers and/or good tweezers
-torx driver (only needed to remove VES)
-electrical tape
-22ga or 24ga wire
-female RCA jack, preferably pre-molded on a cable
-3/32" and 3/16" heat shrink tubing
-sample DVD; Grinner's Moddin' Art recommended
Some other tips to help the mod go better:
1. have a small container (say tupperware) for the screws and bits that you are going to remove. No, you will not be able to find them on the carpet easily.
2. put a towel or some sort of cover on your seats. You will be sliding in and out a lot and kneeing on them. Might as well save you a future clean-up.
3. I did not disconnect the battery, although it is wise to do so. I did have the key out of the ignition though, so no accessory power was on.
So I'll start with a couple of pointers on VES removal should you want to do that.
The VES is held in by only 4 torx screws. The front two are visible and easily seen. However the rear two require the back panel of the console to be removed. This in turn requires the console itself to be loosened or removed as the back panel is fastened by two screws on the inside at the bottom of the panel. Pics on this subject are in post #4 of this How-to.
Ok, now to the video out wiring.
Remove VES cover. There are 5 screws, 3 at the front and 2 on the rear top under a cover.
The rear cover has a small slot:
I used a butter knife to pry it up:
Which reveals the 2 screws:
The cover will now lift off:
On the rear side, the cover has to be moved towards the front of the car a tiny bit (the aligning pins won't easily clear unless you do this).
Once the cover is off, you will see the internal wiring harnesses:
We will be dealing with 2 wires on the 10 pin harness. BTW the red/blue wires connect to the switch that turns the unit off when it is folded down -- NOTE: with this mod, when the rear screen is folded down, the screen goes off, but if the unit itself is still on, the video out feed remains active, cool huh?
The 3 pin harness goes to the cover for the video lockout switch.
It is advisible to pull the 3 pin connector while doing this mod to allow the cover to be set aside out of the way.
The wires we need to tap are the ones that feed the LCD display on the VES. These 2 wires are actually in one coax conductor:
As a bit of a sidebar, although the coax cable itself was pretty suggestive that these were the correct wires, it is always better to test first rather than blow some sensitive part. So Jaak the u-connect electronics genius lent me an oscilloscope, advised the output should be about 1 volt and that the display would be a high (but not ultra high) frequency.
If you like to watch paint dry, here is a vid of the scope test: Thanks Jaak -- if I just went with what was suggested on other forums, I would have blown something -- always better to test first!
Next, remove the heat shrink tubing from the coax wire. This pic shows the 'coax' nature of this cable -- the wire braid around the outside is just visible before it has its own heat shrink insulator:
Note there are two wires. The white one is the postive wire and is the inner core of the coax, the black one is the outer sheathing of the cable and is ground. You need to remember which is which so you mate them to the video out cable you will be adding later.
VERY CAREFULLY strip off a small section of the insulation from the black wire. Start with this one to get a feel for this delicate work. The black wire seems to have more conductors than the white wire and is more robust.
Even MORE CAREFULLY strip a small section of the insulation from the white wire. 'Shaving' the wire is probably a better way to describe it. I suck at this stuff. Be sure to have a sharp knife with a thin blade. Think 'scalpel'. Or there are special purpose wire strippers but be sure you squeeze just enough to cut the insulation and not the strands. In this case, there was no way to cut one end and slip the insulation down the wire, so I had to try to expose one side of the wire and fold the insulation back. I could not find a great knife (the one I had was too large) so this was a bit messy and ended up breaking later -- you'll see...
Now prepare the cable that will serve as the 'video out' jack. I snipped off part of a donor cable that had a female RCA jack already molded on:
Then I added small 26ga leads on the unfinished end. This will make soldering the internal VES harness much easier. 26ga is pretty small and may be hard to find; 22ga would work just as well.
Post continued below (have hit the 16 images/post limit).....
