Results 1 to 12 of 12
    Smoove06CSRT's Avatar
    Smoove06CSRT is offline Kiss my Rims.. They gots BIG lips!
    Nov 2005
    VES Installation Instructions.
    This is a link to the VES installation instructions
    http://site.wyckoffchryslerparts.com...s/82209382.pdf
    2006 300cSRT8
    Fastest color...... Bright Silver Met.
    "OHH! A Strip Club.....I'll Get my sweat pants on!"
    Nov 2005
    There are 2 different factory harnesses for a ves system.
    The first one p/n 4607105AD is if you don't have factory satellite radio
    The second one p/n 4607106AC if you have a factory satellite radio.
    With these harnesses you just plug them in and enable ves with the starscan.(Might not have to do that) With no satellite radio the harness runs from the bracket wiring under the counsole to a white plug above the parking brake pedal.
    With satellite radio you will have to run the wiring from the white plug above the parking brake pedal down behind the driver side kick panel and under the edge of the carpet between the drivers door and the drivers seat. then when you get to the b pillar, the harness splits and one side you have to run under the carpet to the console, (i ran it under the seat and the carpet utilizing the hole that is in the carpet already for access) and the other part of the harness you continue down the floor under the carpet to the rear of the passenger compartment into the trunk to plug it into the satellite reciever.
    I do NOT know if these harnesses will fit 2005 models. But both of the above harnesses will just plug in, no removing pins.
    There is also a 3rd harness for the dealer installed unit, (the one that comes with the kit that the installation instructions in the 1st post came from) but that harness will require you to swap pins.
    2006 300cSRT8
    Nov 2005
    VES Headphone Replacements...
    if you need an extra set, or you dont like the OEM ones, these work with the Factory VES perfect!! and I think they fit a little better too.... i have 2 sets...
    http://www.midwestelectronics.com/bl...hs01-p-41.html
    plus, at 19.95 a pair, they are half the price of the OEM ones!!!
    if you want, call and ask for Brett, that is who I ordered mine from... he helped me out a lot... Tell him you are a member here.
    2006 300cSRT8
    albertojedi is offline LX Padiwan
    Sep 2009
    Puerto Rico
    New Headphones and Remote for existing VES
    Do you have to configure new headphones and/or new remote for an existing VES system to recognize them? I bought an used 2006 Chrysler 300 C HEMI with VES but headphones and remote were missing. The seller just bought them new and is about to deliver them to me.
    Nov 2005
    nope. no configuration needed...
    the headphones and remote are universal.
    2006 300cSRT8
    Sep 2009
    Puerto Rico
    Thanks!!!
    mjr5150's Avatar
    mjr5150 is offline Just Blown
    May 2006
    Long Island , NY
    Hey Smoove ,
    If i am reading you right , all i need is this hightlighted harness to add an oem rear ves dvd player i recently purchased to my 2006 MSRT-8 ( already having a factory installed REC nav w/ sirius ) ? The rest of the quoted post would have to be followed as well ? I thought ( was hoping ) it was more plug and play but i see i have to run these wires as well . So much for an easy mod.....lol . Right now i have an ipod cable plugged into the back of the rec unit . I still have to control it on the ipod itself but it charges it . Will i lose that if i plug in the ves add on into that port ? Thanks in advance for the help , and this post . I was doing some research so i didn't have to ask an already asked question . I also wanted to know if i could get the rear picture up front on my nav without the tvandtogo mod ( cracking open the back of the REC and soldering ) . I thought the lockpick's were more for later model mygigs but i wasn't sure ? - Mike
    Quote Originally Posted by Smoove06CSRT View Post
    06 CSRT-8 Silver Steel (all opts.): MagnaCharger MP2300 TVS Supercharger, Hemituner tuned, Hemi Shop P & P heads , FRI Tomahawk cam , Dynatech LT headers,Corsa cat-back,Magnaflow HF cats,LMI CF True 4'' fendermount CAI , PT 3400 stall TC , Getrag LSD 3.06 rear, Paramount rebuilt tranny & valve body , Arrington 85MM Ported TB tapped for Nitrous , BT catch can ,Hotchkis front & rear sways ,15% tint all around,SRT-8 embroidered mats(biggest HP gain ).Future wants:Arrington 392 & an understanding(ok heavily medicated)wife..lol .
    PB 11.25 @ 125.16 - Stock Bottom 6.1L blown (10lbs boost)
    rbenkemeadow is offline LX Padiwan
    Oct 2010
    Northern, KY (Cinn, OH)
    Quote Originally Posted by mjr5150 View Post
    Hey Smoove ,
    Ever get a answer to this?
    Oct 2010
    CrazyManInCincy's Avatar
    CrazyManInCincy is offline LX Padiwan
    Cincinnati,Ohio
    You will need the wiring harness and looks like the unit has seen some water.
    Oct 2010
    zeeboid's Avatar
    zeeboid is offline LX Newbie
    Apr 2010
    I don't suppose anyone has a woring link to this eh?
    Nevermind... found one ten seconds later:
    http://www.moparsupercenter.com/pdfs/82209383.pdf
    2006 Magnum SRT8 - CAI, 180tstat, Diablo, baby seat.
