Results 1 to 15 of 24
    JamminWagon's Avatar
    Cheyenne, WY
    Stereo Bezel moulding to put in DDIN in non-Nav Bezel
    Tools and supplies:
    Dremel
    Epoxy
    Spot putty or body filler
    Sander
    Difficulty:Moderate
    I never tried anything like this and it came out good.
    Stock Non-NAV Bezel
    Lining up the HU Bezel to mark for cuts
    HU Bezel Epoxied in
    First sanding with controls in to check for clearance
    "ears" from mounting kit epoxied in also
    Used left over plastic to fill in the gaps
    Result of sanding after plastic filler
    First coat of spot putty also after sanding all the checkerboard pattern off
    First sanding of the putty
    Second coat of putty
    Result of final sanding and painting with textured paint
    You can use body color but more work is needed to
    feather in the filler
    Final result with HU installed
    I did this over 3 days. It pays to take your time.
    I have had this in the car for over the the last year
    with numerous removal and it is holding up. I would
    even do this to a NAV install kit to give a stock look.
    With windows tinted, it looks like a stock NAV unit
    and is less of a theft temptation.
    srw2's Avatar
    srw2 is offline I roll in luxury
    Minnesota
    thats exactly what i want to do... where did you get the little ears? do I just need to buy a dash kit and cut the ears off of it? where do I get a doubledin dash kit? the only one I can find is one for a single din with another pocket in it....
    It looks really good and I really want to do this same thing. the little square piece is the surround of the indash dvd player?
    SRW2
    I gotta say.. Today was a hot day..
    Check Out My Ride On Cardomain
    PappaDoc's Avatar
    PappaDoc is offline God takes pleasure in your prosperity!
    Jun 2005
    Humble
    That my friend is true custom craftsmanship!!! You deserve some beans for that!!
    BTW, when will I have more than one bean!!! LOL
    Cheyenne, WY
    Quote Originally Posted by srw2 View Post
    Yes the "ears" are from a non-nav install kit.
    At the time this was the only kit that was availible.(done over 2 years ago).
    http://www.installer.com/item/displa...php?it=99-6510
    Its the Metra 99-6510.
    Yeppers
    srw2's Avatar
    Minnesota
    Quote Originally Posted by PappaDoc View Post
    HA! you get way more than one bean for them suicide doors... 18 months of work is worth at least 2 or 3 beans
    and also gotta say thanks a lot to Semi Hemi... for the great info... I never woulda gotten up the nerve to do this mod if I didnt see this thread about it... I'm off to buy an in dash dvd player!
    SRW2
    Cheyenne, WY
    Well thats why we are here!! Why pay a shop $200+ to do something that we can show how to ourselves for under $20, just takes our time!
    I should not that the holes that the 2 clips by the HU clip into that secure the bezel are not there. But the bezel has enough rigidity that the other clips keep it steady.
    SRW2 besure to post some pics of the finished product.
    TORREDAYTONA is offline Banned
    Angry
    dude ,ur the man
    looks awsome
    05 ROLN ON 24'S's Avatar
    05 ROLN ON 24'S is offline LX Padiwan
    DETROIT
    Wow All That Work And U Didnt Even Round The Corners Like The Corners On The Head Unit.... Its The Small Details That Count.
    Cheyenne, WY
    Quote Originally Posted by 05 ROLN ON 24'S View Post
    Thats the way that the bezel comes with the HU. Because the face tips down you have to have room for the face to swing. The face is tapered outwards. Even if the HU is off of center by 1/16" it will rub. It is something that has to be lived with. The factory knows best.
    Feel free to try it yourself and prove the factory wrong.
    imahemi is offline ...
    Feb 2007
    Omaha, NE
    I found this tread in the KB and was thinking of doing the same thing only with a single din deck. I was wondering how your head unit is supported? could I hang it from the bezel or is something else needed?
    Ryan
    -Ryan
    <<<clicky...
    '93 1500 SB - 226k, '05 Magnum RT - 17k, '80 El Camino - 84k
    Cheyenne, WY
    Quote Originally Posted by imahemi View Post
    Ryan
    I would get the single mounting kit. The ears just pop on the mounting kit. Epoxy the ears to the bezel, do the filling/sanding/painting and pop the bezel back on.
    Feb 2007
    Omaha, NE
    Quote Originally Posted by JamminWagon View Post
    got that one on its way... will see what I can come up with.
    Thanks
    Ryan
    Edit: by the way did you extend the wires on your ac controls??
    -Ryan
    <<<clicky...
    Cheyenne, WY
    Nope everything is stock length and location.
    robnhatch is offline LX Newbie
    Jul 2007
    hey jammin wagon u think this would work...
    non nav bezel cut to double din?...see pics...
    Cheyenne, WY
    Quote Originally Posted by robnhatch View Post
    probabaly would, just have to take the measurements of the kit vs the opening. Yall sure got it easy with the release of the NAV kits haha
