Page 1 of 5 123 ... LastLast
Results 1 to 15 of 61
Like Tree2Likes
Thread: Step by Step on How to replace the Navigation Joystick
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    KB submission of this thread:
    Step by Step (by Step by Step) Guide on Nav Joystick Replacement
    Ok.. first sorry the pictures are bad, all I had was my phone when I did this:
    order the Joystick here: http://www.mouser.com/Search/Refine....user_Wildcards
    Thank You Jaak for finding that...
    Tools needed:
    Desolder iron
    empty can of some kind..
    Solder iron
    Solder
    Jewelers Flat Blade Screw Driver
    Jewelers Phillips Head Screw Driver
    **basic soldering skills**
    Step 1.
    remove Nav unit from car. (if you struggle with this, then stops here DO NOT go further)
    Step 2.
    there are 4 screws on each side and 2 on the top and bottom of the face plate, remove these and pull off the Knobs (volume, tuning, Joystick)
    (thank you Jaak for providing these pictures)
    use small screw driver to top pop the tabs that hold the face plae on.
    Step 3.
    Remove the PCB board:
    4 screws hold it in place:
    remove the connector on the left side
    Step 4.
    place the unit on a mouse pad or some other type of anti-static pad.
    I personally use an empty tissue box, because I can set the unit on it with the knobs inside the opening to prevent damage to them.
    Step 5.
    Desolder the old joystick, make sure you EMPTY the desolder iron after each pass (empty into the can) or you could spit hot solder onto the pcb board and Bye Bye Navi Unit.
    this is a desoldering iron $25 at Radio Shack:
    Step 5A
    look at the difference in the 2 joysticks.. if the new one (shorter shaft) bugs you then you can do the following and swap out the shaft:
    A. dissemble the old joystick:
    use the flat blade screw driver to lift these four tabs:
    open joystick:
    remove the shaft:
    repeat the steps for the new joystick and swap the shafts.
    Step 6.
    Now resolder the new stick in place:
    If I recall there are 15 points to solder, the stick only goes in one way so you can't mess that up,, but BE CAREFUL not to bend the ends as you insert it, they break kinda easy.
    Step 7.
    finished:
    Discalimer
    YOU DO THIS AT YOUR OWN RISK.. DON'T BLAME ME IF YOU SCREW UP YOUR UNIT.
    daverdoo's Avatar
    daverdoo is offline LX Biatch
    Aug 2005
    Atlanta
    What happened to all the pictures? Would be nice to have them.
    Dave
    Apr 2006
    sorry, i'll fix them, moved photobucket accounts awhile back
    Apr 2006
    done
    Hemipower300 is offline LX Newbie
    Joystick shown as obsolete??
    Mouser catalog now lists the part as obsolete. Any ideas on another source?
    Thanks!
    (edited) oops...found it on the beginning post....many available at present...
    (Edited again) see below: to order correct 8 way unit: I did a search for ALPS RKJXT1E12001 on but got RKJXT1F12001 as recommended factory replacement. Unfortunatelyl, that's the 4-way item.
    Here's the spec sheet and link for the correct (E) part #:
    http://www.mouser.com/catalog/636/1554.pdf (top item)
    More coming: http://www.onlinecomponents.com/buy/.../RKJXT1E12001/
    plcman's Avatar
    plcman is online now Plcman Charger R/T
    Nov 2005
    Jacksonville,Fl.
    I have the replacment switch, but it is different, the original was an 8 step switch, the new one is only 4 step.
    I am working through the problem now. I have contacted ALPS that makes the switch to get some info.
    You can buy the new switch and take the parts out of the new one to fix it maybe.
    R.I.P LOU1355
    2006 Charger R/T R&T - Ordered 9-06-05- Home 12-23-05 - Mods: SRT Hood, 180 Degree Thermostat, JBA Shorties, High FLow Cats, SRT Suspension, AFE Stage II CAI, ---Painted Half covers --- AMG Paddles--Jaak Hack direct wire--PLCMAN Line-Lock board SLP Line Lock ---raymond@plcmanguy.com
    FLXC.ORG ---North Chapter Coordinator---Hemi Registry # 00648 plcman Thanks Billet Technology 2008 Shindig winner under the hood goodies!
    daverdoo's Avatar
    Aug 2005
    Atlanta
    I got mine off of ebay for $28 including shipping.
    There are a couple others that Mr. Incredible posted for ~$8 each but both had ~8 week lead time.
    Guys... These instructions worked great!!! I am so thrilled that I didn't have to scrap my navi just because the joystick died.
    I also installed the AG map with the in-motion hack. Don't have to hear my wife bitch when on a trip.
    Thanks all!!!
    carbonater55's Avatar
    carbonater55 is offline CARBONATER55
    Dec 2008
    Toledo,Ohio
    Facia remove.
    I have no problem building electronics. How ever how do you get the facia off the dash with out damaging anything. I can't see how to release the wires.
    Never mind. I found some threads that cover it.
    mkeenan is offline LX Newbie
    Mar 2009
    Hermiston, OR
    Is there any updates on replacement joysticks? Who's got the best price on these?
    liljoejoe54's Avatar
    liljoejoe54 is offline LX Padiwan
    Sep 2007
    Chicago
    Quote Originally Posted by daverdoo View Post
    Thanks all!!!
    Can you post the link of the one you got off ebay? I have tried looking for one but cant find it.
    SilverSRTSedan is offline LX Newbie
    Jul 2008
    Elkton MD
    Looks like my joystick crapped the bed last week, any updates on which is the correct replacement to order? I need to get this fixed soon cause it is bugging the hell out of me!
    --Justin
    Beater A: '95 Civic EX 4 door
    Beater B: '87 Ramcharger 360 swap and 35s
    '00 Dakota R/T Prev. 13.5@102 N/A 12.2@110 150 Shot. Now 72mm turbo, stock 5.9 386hp/435tq
    '06 300C SRT-8 Diablo 93 oct, 176 t-stat, 275 Vredesteins, and Magnaflow high flow cats 12.3@113
    Go Mango's Avatar
    Go Mango is offline Day dreaming...2012 300 SRT8!!!
    Brampton, Ontario.
    Mine went yesterday, any updated info on this? I see this link Mr iNcredible gave is now an obsolete item.
    Men over 40: GO GET A PSA TEST DONE!
    http://lxcars.webs.com/hemihighwaykickoff2010.htm
    Jaak's Avatar
    May 2005
    This is a tough one... The orginal replacement I sourced from ALPS was identical except for the shaft length, but I believe one of the reasons the design has been obsoleted is due to the common failure point on these switches.
    But this gives me another idea... Hmmm...
    2006 Magnum SRT8 - 11.85@117
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by jaak View Post
    You want one to play with? Mine died too.
    Jaak's Avatar
    May 2005
    We'll see Don... I have a query in and it depends on the answer I get...
