Results 1 to 15 of 15
    JamminWagon's Avatar
    Cheyenne, WY
    Ignition controlled power tap write-up
    All LX's do not have an accessory controlled power source at the stereo harness. The radio is controlled by the car's CANBUS.
    Tools:
    a) If using push on taps, pliers
    b) If doing the wrap tap, knife, electrical tape and tie strap (soldering iron if used)
    Now to get to the cig lighter.
    1) Remove the rubber pad that is directly infront of the ashtray.
    Take something like a thin putty knife to get underneath it and pop it out.
    Rememeber which way it comes out because it only goes one way in.
    2) Pull off the radio bezel buy grabbing the cubby hole and with an light
    upward pressure and pull straight out. It is only held on with clips.
    3) Disconnect the AC controls and switches above the radio and put the bezel aside.
    4) Then gently pull on the ashtray and it will pop out.
    5) Then you can pop off the power connector for the lighter and tap into it.
    !!!!!!!!! PULL FUSE #18 FIRST !!!!!!!!!
    The wire that you want to tap into is the 16 guage red/orange wire.
    There are a couple of ways to tap.
    USING SQUEEZE TAPS
    You have to be careful and get the correct gauge tap.
    If you go too small you can cut the wire or too big it wont "bite" through the insulation.
    You can get a tap from RadioShack(p/n 64-3052 $1.99 pkg of 10).
    WRAP TAP
    Using a knife, cut a ring around the wire so that you can pull the
    insulation apart(go slowly so you dont nick the wires too bad).
    Then take knife point and carefully poke through the wires making a hole.
    Take the wire that you want to run up to the HU
    and push it into the hole.
    Wrap the excess around closing the hole.
    Soldering the connection is the best way to connect the wires but is not required.
    Now take electrical tape and wrap the connection, when you wrap the
    wire to close the hole make sure that the ends are not poking up so that
    it wont poke through the tape. Then what I do is take small tie wrap and
    put at the end of the electrical tape that is capable of coming undone to
    make sure it stays put.
    Now if you have the smoker's group, the cig lighter will have power to it all the time.
    If you have the smokers group the change to ignition control is very easy.
    In the rear fuse block fuse 18 has 3 slots.
    If you look at the pic the one fuse that is down from the others is the way you want it.
    Install the radio, ash tray and radio bezel, reinstall fuse 18 and enjoy!!
    mannyhernz is offline 'WestCoastiN'
    Westcoast
    is this for base system or premium?
    ekaz is offline all gone
    Jun 2006
    CHICAGO
    Quote Originally Posted by mannyhernz View Post
    It is for both systems and all LX's. He's just using the cigarette lighter as a switched power source.
    Unlawful Gathering
    Click for details!
    2009 MBP GCSRT8
    Powered by PWR
    Shifted by SHR
    Tooned by Johan
    Blinged by Billet Technologies
    SRT Brian is offline SRT Brian
    NICE Great wright up!!! Save my life just now lol . Owners manual dosent list Cigarette lighter
    Viper hood,powdercoated wheels,5% tint,custom exhaust,Kenwood 8019 Touch screen,150 Shot of Nitrous, Custom dual bottles,Tinted Tails,all moldings removed,SRT emblims on the Cowl,Shaved Ram head on the front grill,Polished underhood,Hemi Orange valve covers,Custom one off Shiffter boot,Peddel Covers,3 in Drop,LED underbody kit,Headlight strobes,LED Nitrous purge, Tunner,Custom switch panel,160Gig Ipod interface, Cold Air-So far before programer 11.98 1/4.
    "Project Black Out"
    FloridaRT's Avatar
    FloridaRT is online now LX Oldtimer
    Ocala, Florida :-)
    Great write up, I used it for my Halos...................
    Bob
    prican_2000's Avatar
    prican_2000 is offline Hispanic causing Panic!!!!!!!!!!
    MD
    Wow- Great Write Up!!!!!!!
    Thanks!
    "Death Smiles at Everyone -- Marines Smile Back"
    MOD LIST: C/F Hammer, Flowmaster Ex, FRI-Sidewinder Cam, Gibson Headers, Predator, B.T. Ported T.B., Lil Silver Box, Red Illum Rear Wing, Blue Angel Eyes, Yellow HID FOGs, 09 Intake, CTP Spacers, SRT Rails & Injectors, SRT Rear w/3.55 Gears and 2010 R/T Axles....What's Next?
    Cheyenne, WY
    Glad to be of help.
    Taz85268's Avatar
    Taz85268 is offline Magnum Owner 'til Death
    Apr 2008
    Fountain Hills, AZ
    The Fuse for my Cigarette Lighter keeps blowing if I use a Cigarette Lighter in it.
    I have tried 10A and 15A fuses with the same result.
    I pulled ashtray panel out last night and noticed that there appears to be a very small pair of wires going to the 12v receptical.
    I would have imagined a lot larger wires.
    Does anyone know if there are any other wiring configurations that would put larger wires at the cigarette lighter?
    Thanks,
    Terry
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    awesome write-up...
    but a lot easier way to do this (and keep from cutting factory wiring) and takes under 5 seconds to return to stock is to use this:
    this is a mini-fuse add a circuit.. $6 at pep-boys.
    you pull fuse #18, insert the car fuse in the bottom circuit, the top circuit is the add on..
    you run the wire up to the front of the car along the passenger side under the door strip molding.. (takes about 30 min)
    insert the mini add-a-circuit into the stock #18 location and you now have 2 switched circuits there..
    I always try to avoid cutting ANY factory wiring if at all possible...
    MuscleMan305's Avatar
    MuscleMan305 is offline Hopped up on Super Supreme
    South Florida
    Quote Originally Posted by Mr. iNCREDIBLE View Post
    awesome write-up...
    I can only find this for a 10amp and the fuse currently on there is a yellow 20 amp. I tried 2 discount auto parts and a pep boys. One guy said it doesnt really matter that the wire is rated for 10amps but i can easily swap with a 14guage wire and still insert the 20 amp fuse. Any truth to this??
    Cheyenne, WY
    Quote Originally Posted by MuscleMan305 View Post
    it doesnt really matter that the wire is rated for 10amps that is how fires can start. Too many amps through a wire, wire burns up, wire hooked to power hits body (ground), nice spark, something catches fire! The wire swap is a good idea, the only thing I would worry about is that the fuse holder itself is "advertised" as 10 amps. Even if you put 0 guage wire on it, it would burn up at whatever amps it can handle. Since the fuse holder probably isnt stamped with it's own rating, I would have to go with 10 amps. I am using the wiring that came with the HU which had both the IGN and the Constant wires with fuses.
    trent's Avatar
    trent is offline Chargereur
    Jan 2008
    Austin, TX
    Thanks a lot, JamminWagon! I just used this trick today to hook up my Air Fuel meter. I could find no other alternative besides disconnecting the gauge manually when I stopped the car. You're a life saver!
    2008 Charger R/T. Modifications: Borla 125 exhaust, Mopar CAI, hood struts, Transformers Autobot badges, Mopar Headers, Red brakes with mopar decal, Trufiber SRT8 hood, Knight-Rider LEDs in hood scoop, Diablo Predator, 180 tstat, Oil Catch Can, FRI Sidewinder Camshaft, FRI underdrive crank pulley, Inertia big-valve heads.
    To do: decal set
    361.5 RWHP
    http://www.iguana.org
    RobAGD's Avatar
    Reston, Va
    Something to think about is a little bit of kit that PLCMan is putting together.
    Its a 12v switch power supply w/ a optional 5v power supply board ( for powering some external sensors for data logging )
    Here is some info on it - Power 12v Switch Bus
    -Robert
    ggt4 is offline LX Padiwan
    Maryland
    I have been looking everywhere for this info................THANKS!!!!!!!!!
    07 Jeep Grand Cherokee SRT-8: Silver, Bwoody 4" intake, 180 thermostat, Predator w/Johan tune, R1 drilled/slotted rotors, stoptech brakes, billet shorty antena, HID lows, fogs, reverse lights, rear fog conversion, more to come.
    06 Magnum SRT-8-SOLD
    www.maboerboels.com
    BlueBee 6.1's Avatar
    BlueBee 6.1 is offline BlueBee266
    Sep 2008
    Oxford, Michigan
    This is great, I am looking for a place to provide switched power for the amp I am about to install on and off with the ignition.
    BlueBee266
    K&N CAI, Jet 180Tstat, Predator,Magnaflow HF cats and cat back, Mopar strut brace, Billet catchcan, Eibach front and rear sway bars, Eibach ProStreet S Coil Overs, Pedders bump steer kit, Comp XFI273H-14 Cam, Comp Beehive valve springs, Arrington pushrods, SLP underdrive pulley.
