Results 1 to 7 of 7
    345CID's Avatar
    345CID is offline LX Newbie
    Kokomo IN
    300C Rear deck removal - gain access to rear speakers
    From the trunk, remove the lower speaker cover by pulling out the panel clips. There are six of them. I didn't take any pictures of this as
    it seemed easy enough.
    Rear Seat Bolster Removal:
    Fold down the rear seats and remove the 10mm bolt from the bolster.
    Using a screw driver, press down on the spring clip at the top while pulling out on the bolster. Be sure you are pressing on the right
    thing. Once you get it right, it pops right out
    Here's what the clip looks like:
    Now remove the two screws on the side pillar:
    Fold the seat up and remove the bottom screw:
    Press the molding down from the top and remove it:
    Pop out the one center clip:
    Then grab the deck cover and pull it straight out:
    There you have it. The rest is normal speaker replacement. I installed Infinity speakers that were too big to drop in from the top, So I
    screwed them up threw the trunk. I used the same screws that were on the factory speakers:
    Do the reverse to put it all back together.
    The speakers are 4 ohms while the factory speakers were 2 ohms. It won't hurt the amp to run that way. And this simple speaker upgrade made
    the world of difference. I'm not thumping like the guy's that put in showcase systems, but for what I listen to, it sounds great.
    One more tip - be careful not to bump the glass if you have window tint. Ask me how I know!
    Good Luck
    2007 300C Loaded
    [x] In Motion hack 3-28-07 [x] iPod integration kit [ ] tvandnav2go [ ] SC Flashpaq tuner
    2006 300C SRT8 - Silver - now I have two!
    http://picasaweb.google.com/t2436jf/OurNew300C
    Tbird100636's Avatar
    Braintree, Massachusetts
    Cool
    This applies to ALL LX sedans with fold down seats. Charger or 300.
    www.ramtruckforums.com
    steve7680768 is offline LX Newbie
    Mar 2010
    Nice demonstration of that thing... there is a lot of difference in telling and in showing something.. You made it man.... Rocks...
    n.samantha is offline LX Newbie
    Jan 2011
    Extremely awesome tutorial..
    Thanks a lot for sharing..
    Good Luck
    N. Samantha
    drksyd is offline LX Padiwan
    Mar 2011
    Honolulu, HI
    This still holds true for the '11's.
    SpinTech mufflers/Aeroturbine resonators - Tinted (Panorama Hilite 40/Huper Optik clear on windshield) - catch can - AEM Brute Force - Hotchkis springs - 180 tstat - AAC halo's
    dewwhip is offline LX Newbie
    Dec 2011
    awsome
    wow! really awsome dude thanx
    DET-TANK's Avatar
    DET-TANK is offline From the D but in the NC
    Sep 2011
    WNC
    When we did the rear glass tint on my C, we didn't even remove the side trim. The back dash just slid out and up from behind it.
    The way illistrated above looks a little more safe for the panel though. I advise removing them.
    2007 Brilliant Black Crystal Pearlcoat
    300C
    At the Walter P. Chrysler Museum/Chrysler HQ
    Auburn Hills, MI
    5.7L Hemi Registry #1646
    Diablo Sport PREDATOR 93 Octane CAI tune/AFE Stage II/BT Oil Catch Can/
    Flowmaster axle back/
    #4128 T-Stat/
    15% Tint/
    All LED interior light swap
