This will take care of the leaking O-rings, filter and fluid change, and water intake issue at the base of the filler tube.
FYI: This is for my 05 Rt (Hemi) built 10/04, I don't know how the V-6 tranny is, and you need to verify the quantity of ATF needed for servicing, before working on yours, it's your car, it's your responsibility.
If you don't feel comfortable doing this due to lack of mechanical ability, take it to the dealer, if you still have the warranty it's ok, if not they'll charge you about $250 for the following work.
You'll need:
Click on picture to make them bigger.
- T-30 star socket and basic tools.
- 5.3Qts of AFT4 (syn) ($3.49/qt at Checker)
- long neck funnel
- Ramps
- Jack or Jacktstand
- Large container
- Black silicone
- 1 large O-ring, DCX dealer part# 68001278AA ($1.98) UPDATE: It's preferable to use the O-rings from the Mercedes Benz dealer, they fix the problem better, so I've heard, $3 each + tax, they call them seal rings, parts#: MBN 026997404828 and # MBN 026997414828.
- 1 small O-ring, DCX dealer part# 68001279AA ($2.30)
- 1 Transmissiom filter, dealer part# 52108325AA ($11.62)
To start:
Now let's work on the 2 O-rings:
- Put the car on ramps, set parking brake
- support transmission with jack or jackstand
- Remove the 2 middle bolts (15mm)of the crossmember
- Remove crossmember by removing the 4 bolts (1/2")
- Place large container under tranny pan and remove bolts with T-30 star socket (start from the rear first to let it drain as much as possible before removing the pan) (remove filler plug also)
- Remove pan, clean pan, re-usable gasket and magnetic plug
- Pull down on filter to remove it
- Make O-ring of new filter wet with ATF4 and install new filter after all fluid has drained, just push it in making sure tab is in hole.
Now let's seal the base of the filler tube with silicone to prevent water from going into tranny:
- Turn bayonnet lock counterclock wise (use large pliers if needed) and remove connector
- Remove plug with a 7mm wrench
- Make the 2 O-rings wet with ATF4 and replace them after cleaning the plug well (Update: Read post #11 and #18 regarding tab removal, if present, there wasn't one on mine)
- (picture of tab here, post # 17: Another leaky tranny )
- Put plug back in, tighten it with 7mm wrench, put connector back in, turn bayonnet lock clockwise until it clicks (make sure it cliks or will come out over time)
- Put tranny pan back in and make bolts tight (you cannot overtighten pan and crush the gasket because the bolts have stops on them, you'll see what I mean when you remove them)
Now let's put everything back:
Check again in a few days to make sure it's all good, and next time you change the oil or work under the car, double check the pan bolts to make sure they're all tight, and that nothing is leaking.
- Replace crossmember (put the 2 15mm bolts first to center it)
- Remove jack
- Put 5.3 Qts of ATF4 slowly (double check fluid quantity for servicing) (also check how much came out to verify quantity) (4.5 Qts came out of mine, meaning it was .8 Qt low, it was leaking more and more every day at the connector)
- Screw plug back in filler tube (make sure it's tight)
- Start up the car, let it run for a minute, put it in D & R a few times, put it in P, and check under the car with the engine running to make sure there are no leaks (everything was ok on mine)
- Hopefully you didn't forget anything and now you're done.
