First thing you need to do is put the car up on ramps or jack stands. Unless you are the thin man from the circus you will not be able to get to everything. All of the pictures below were taken while laying down on my back looking up at the car.
Once you have it up on the ramps, there are several 7 mm bolts holding the front part of the cover on. Remove all of these.
There are also two 10 mm bolts holding the back of the cover on. There are six push pin style connectors on the sides of the cover. I used a crimping tool to pull these off. Whatever you use make sure it doesn't cut the head off.
Once you have all of these removed the cover will just slide off. Just behind the cover on the drivers side you will see the stock air sliencer.
Pull the wheel well back a bit and you will see a 10 mm bolt holding the stock air silencer in place. Use a long extension with your socket and it will come out easily. The bolt is much longer than you would think so it takes a bit to get it removed.
Once you have the bolt out, slide the silencer to the left just a bit to disengage the pins at the bottom. Once you do, the box just comes right out.
Since I have the 360 air intakez system installed I used the old air inlet to provide some cooler air to the box. As soon as I get some more time to work on the car I will make a cover for the air box to force the system to pull air from this new location.
Just put the covers back on and you are all set. Hope this helps.
