Installation of a MDS “ON” Indicator Light
written by Magnuman
Added 10/23/06: New, updated PDF version by IT Rider can be downloaded HERE.
The following is a “How to” for the addition of a Multi-Displacement System (MDS) “ON” indicator light for the 2005 MDS equipped Hemi engines installed in the Dodge Magnum RT.
This may also work on the Chrysler 300C, but the installation in that vehicle has not been verified. This document is intended for reference only, and is merely a step-by-step of how the author installed this modification on his own vehicle. Anyone using this document as a guide to install this modification is doing so solely at their own risk. This installer should have, as a minimum, an intermediate understanding of automotive electrical principals and systems, electrical circuitry, wire routing and termination, insulation requirements and circuit protection. The author accepts no responsibility for errors, omissions, or any other problems or damage that may be caused by this installation.
The purpose of this modification is to provide a method (lighted switch in “on” position) of monitoring when the MDS is active. Turning the switch off will stop the light from coming on and cease monitoring of the MDS. It will not affect the operation of the MDS. It is accomplished by connecting the lighted switch to the power wire for the No. 4 cylinder MDS activation solenoid. Connection is made to the wire leading to Pin 28 of plug C1 of the Powertrain Control Module (PCM).
Parts Used
All parts were obtained from local auto parts store.
- 1 ea.Illuminated rocker switch (any color)
- 1 ea. Plastic rocker switch mount bracket
- 2 ea. No. 8 X ½ inch, pan head sheet metal screws (to mount switch mount bracket)
- 10 ft.24 gauge or larger, 2 conductor multi-strand wire
--each wire should be identifiable, i.e. two different colors.
--two color speaker wire works great
- 6 in. 18 gauge multi-strand wire (Should be this size to tie into 18 gauge MDS power wire on PCM)
- 5 ea.Solderless fully insulated wire connectors to match wire size(s)
- 2 ea. Push on style to match connections on back of rocker switch
- 1 ea. Female push plug barrel style connector (to be used on 6 inch wire)
- 1 ea. Male push plug barrel style connector (for power wire to switch)
- 1 ea. Connector with ¼ inch hole or “open” horseshoe type (for switch ground at PCM)
- 1 ea. 18 gauge saddle type wire splice (the type used for hooking up trailer wiring) --used to tie into MDS power wire on PCM
- 4 ea. 8-10 inch nylon ties
Tools used
- --No. 2 phillips head screwdriver
- --8-10 inch long small common screwdriver (used only to feed wire thru firewall)
- --Set of metric end, box or socket wrenches
- --Exacto knife (preferred) or single edged razor blade
- --Solderless terminal crimping tool
- --Standard or channelock pliers (used only to crimp closed saddle splice)
- --.110 (approximate) drill bit (for drilling mount bracket holes)
- --Multimeter (handy but not mandatory)
- --18-24 inch Test lead with alligator clips on each end (handy but not mandatory)
Be sure ignition switch is off. Disconnect the battery, for insurance, if in doubt. Note that if battery is disconnected, resetting of some vehicle functions may be required.
Preparation (under hood)
1. Remove plastic PCM cover held on by two push lock fasteners. Use common screwdriver to pull up on center of fasteners. The PCM is located in the right front fender well near the firewall.
2. Remove the PCM. Held on by one bolt. Let it sit on mount brace.
3. Loosen or remove (depending on type of ¼ inch ground wire connector you have) PCM mount bracket bolt nearest the C1 plug on the PCM.
4. Unplug top (C1) plug on PCM only.
PCM_C1_Pinout
4. Using an exacto knife or single edge razor blade carefully slice the electrical tape covering the wires on plug C1 from the plug to the junction with other wires (about 2 inches), being careful not to damage any of the wires. I used an exacto knife and slid it under the tape and cut away from the wires.
5. Gently peel the tape back, but do not remove it. Wires from plug should now be exposed.
6. Locate and isolate the 18 gauge brown with light blue striped wire. This is the No. 4 cylinder MDS activation solenoid power wire. Power from this wire will be used to turn on illuminated switch.
EDIT (4-8-05):
There is more than one brown/light blue striped wire on plug C1 of the PCM.
The brown/light blue wire we are concerned with is the one that goes to Pin 28, the MDS solenoid for the No. 4 cylinder. (The other brown/light blue striped wire goes Pin 4 and is connected to the injector control for the No. 8 cylinder. There is also a plain brown wire with no stripe going to pin 33, which is the No. 2/2 oxygen sensor signal lead.)
Please refer to the diagram of the C1 plug below and the Plug pinout chart below to ensure you are splicing the correct wire!
C1 Plug
C1 Plug Pinouts
7. From the driver’s side under the hood, locate the small cable and grommet that goes through the firewall. It is located about 10-12 inches above and to the outside (right) of the steering linkage. It’s the only one there, so shouldn’t be too hard to find.
8. Pull the soft center of the grommet away from the firewall (toward front of car). Later we’ll feed the wire through this grommet.
Preparation (inside the car on driver’s side)
1. With door open remove trim strip (approx. 12X2 inch) on door side of lower dash panel. Gently slide a common screwdriver under the strip and pry the clips loose. I think there is one at each end. This will expose one (1) lower panel mount screw.
2. Remove mount screw and one (1) other located at the bottom of the panel to the left of the steering column.
3. Gently pull the top of the panel from right to left toward the back of the car. You can get hold right under the steering column to start. The panel is held in place by about four snap clips similar to those on trim strip. Just let panel lay on floor.
4. Remove shiny metal panel under the steering column, held on by four metric bolts.
5. Using the switch mount as a template, locate, mark and drill mounting holes. I mounted mine under the ignition key. There is a little recessed shelf separating upper dash from the lower panel that works great. This location is easily visible to the driver, relatively inconspicuous, and does not cause excessive glare at night. Do Not mount switch bracket at this time.
