Page 1 of 4 123 ... LastLast
Results 1 to 15 of 57
    thefever's Avatar
    thefever is offline LX Padiwan
    Feb 2008
    How To: RT Exhaust into V6
    After scouring the forums for information on how to put an R/T exhaust on my V6, I decided to do a write up of how it is done. All of the information compiled into an easy to understand (hopefully) write-up. Now, I’m having a shop weld my on. Some people, from what I’ve read have used the clamps, and had to use an adapter. This just seemed “Un-steady” to me. I didn’t want to have to check the tightness of the clamps every few thousand miles. With that said, let’s get onto the parts you’ll need.
    Total Time:
    About an hour for prep, and an hour or so at the shop.
    Difficulty: 3 of 10
    WHAT YOU’LL NEED:
    Stock Exhaust Brackets.
    Part Number: 4581723-AB
    Cost: $9.20 a piece from my dealership.
    Two 8mm Bolts. 1-1/4”
    Cost: $1.03 from Home Depot.
    These will be used to bolt the exhaust brackets to the car.
    Two Exhaust Insulators.
    Part Number: 17160
    Cost: $3.99 from Autozone.
    Two Rolls of Insulator.
    Cost: $4.29 from Home Depot.
    RT Exhaust.
    Cost: $100 from a local member. (Thanks Terri)
    Socket set, plastic cleaner, rags.
    There’s a good few things you can go ahead and do before you take your car to the exhaust shop. I was able to clean the RT exhaust and polish the tops of the tips, put my heat shield material onto the inner fender well, and gas tank, and also install my brackets.
    Step 1:
    I didn’t have my ramps, so I just jacked up the rear of my car and used some jack stands.
    Step 2:
    The first thing I did was crawl underneath there and with some cleaner and a rag, cleaned my inner bumper where my left side resonator will be fairly close to. I went ahead and placed some of the insulator on this area.
    This stuff goes on really easy, and is incredibly strong. We will see how it holds up when some heat gets around it. I may end up going with the factory heat shield if I need to.
    Step 3:
    Next, I put some of the insulator on the gas tank, across from the factory heat shield. Make sure it’s clean so it can adhere well.
    Step 4:
    Get your bolts and brackets for the exhaust and get your socket set. Mine was a 12mm socket. I didn’t get before pictures of the holes where the brackets need to go, but you can’t miss it. The after should look something like this.
    Furthest back:
    Closest to rear of car.
    Step 5:
    Grab your exhaust insulator A.K.A., the rubber hanger, your checkbook, and head out to your local exhaust shop.
    Out with the old
    This was the guys at The Muffler Shop on Raguet in Lufkin sliding the passenger side of the exhaust into the appropriate hangers.
    All mocked up, ready to be welded.
    Getting welded on
    In with the new
    Side Notes: The exhaust insulators I got from Autozone ended up being a fluke. They were made out of old recycled tires, it looked like. Luckily, the shop had some extras they used that were about a ¼” longer than the stock ones. I’d advise getting some from the dealership, or maybe even having the shop weld them on instead.
    Because of the quarter inch difference, I will be going back and adding a quarter inch washer to the brackets on the passenger side.
    The heat insulator I used is working great; it isn’t peeling back or anything. I will give more of an update after it’s been driven in rain and regular conditions.
    Overall: It sounds great, not too loud; not too quiet. I actually feel like it gave me a little bit of pick up. I don’t know about actual HP increase, but it definitely looks good and fills in that extra cutout. I am extremely pleased with the outcome. If you have any questions, feel free to PM me.
    Final Cost to me:
    $207.02 (I gave the exhaust guy a tip)
    ToddStone's Avatar
    ToddStone is offline Bug Killer Extreme!
    Spokane, WA
    That's funny, I did my exhaust about the same time you posted this. I wish I'd seen this before. The shop that did mine made the left side not even with the right side. I'm going to have to take it back next summer when I get back from Iraq. It's bothered me, but at the time that I had it done, I was getting ready to leave.
    Thanks for the write up. Wish I had known that before.
    Mods: Big Bully/Spectre Cold Air Intake; R/T Exhaust;JDM Headlights; SRT Sways; Tinted Windows;Boston Accoustic Speakers and 10" sub, Crunch 500 watt power amp; KW V1 Suspension/Coilovers; Predator Tune; Fog Lights; 71mm TB and lower intake; HoneyComb grille; JBA Headers.
    LongLiveRock1974 is offline LX Newbie
    Mar 2009
    Nice write-up. A lot of people say they go without the heat shield but I'm going to buy a few rolls. I'm glad that stuff worked for you. I've been looking to an inexpensive alternative.
    2006 Black SXT. 3.5L AFE Stage 2 CAI. 18" alloy's Tinted windows 35%. Leather, Sunroof, De-Badged.
    I will never test drive a HEMI. I like my 3.5L and want to keep it that way:D
    cepp's Avatar
    cepp is offline LX Padiwan
    Jan 2009
    Lancaster, OH
    wonder does a r/t exhaust heat shield for the gas tank fit a sxt? looks like all the brackets that need added are the same, is that true? Does anyone have a part # for the rubber isolaters thru the dealer?
    '08 Magnum SXT, 300SRT8's, Eibach Pro Springs, Koni STR.T's, 6000k HID's. Y Pipe w/ R/T Resos.
    Dantra's Avatar
    Dantra is offline I shaved both of our asses
    Dec 2007
    Indiana
    The rear isolaters are about $25 each, fronts are $10 and the heat shields will run you $25 for the upper and lower (each). You're gonna be around $100 buyiing stuff from the dealer if thats the route you decide to go. Best bet might grab the stuff listed in post #1 and save some coin
    cepp's Avatar
    Jan 2009
    Lancaster, OH
    do you have the part number part of the page, or just the pic?
    Dantra's Avatar
    Dec 2007
    Indiana
    Link sent via pm
    300 touring is offline LX Newbie
    Mar 2009
    I can get my hands on a Borla set up for the LX platform. All brand new still in the box. I think I can get it for about $200.00. Do you think this would be something I should do? Would it be as easy as the stock set up. I'll be putting it on my '05 300 Touring w/3.5.
    65standard's Avatar
    65standard is offline Programmer/Fabricator
    Dec 2008
    Chicagoland
    Great write-up. Why did they have to weld anything? Doesn't the 5.7 x-pipe fit the 3.5s mid pipes?
    MidnightSXT's Avatar
    MidnightSXT is offline LX Guru
    P.G. B.C. Canada
    Quote Originally Posted by S/S Dodge View Post
    5.7 pipe is larger. 3.5`s pipe has to be expanded or welded
    P-Funk is offline LX Newbie
    Jun 2008
    Silver Spring, MD
    Did you experience any hp dropoff going to a larger diameter than the stock?
    ChuckWagon's Avatar
    ChuckWagon is offline no matter where you go, there you are.
    Dec 2008
    Rochester NH
    I recently purchased RT exhaust, courtesy of V8mag (Thomas) and I've been debating on whether or not to delete the resos. I heard a 300C (5.7) over the weekend with reso delete and it sounded good at WOT, but it didn't make much difference at "normal" operating inputs.
    My exhaust goes on April 11 thanks to Klarmie (Keith) and I think I'm going to leave the resos on. I'm worried about it losing too much back pressure and also sounding like a weed wacker in a tunnel. I don't know about all of you guys out there, but my V6 frequently sees 6000 rpm, so I want whoever is behind me to say "hhmmm..that doesn't sound bad" not "....dam ricer wannabe".
    Am I making any sense?
    2005 Magnum SXT AWD
    Midnight Blue
    R/T exhaust, demolded, debadged
    Billet Tech catch-can, Airhammer HO
    Predator Custom tuned by Johan!
    R1 rotors front and rear
    Tranzformer shift tool
    cepp's Avatar
    Jan 2009
    Lancaster, OH
    I agree with you Chuckwagon.. Good sound, not ricer.. Post pics of your install.. Trying to prepare my self for my install?
    Hell Ride's Avatar
    Hell Ride is offline LX Newbie
    Mar 2008
    sound clip?
    ChuckWagon's Avatar
    Dec 2008
    Rochester NH
    I will post pics on the 11th...late tho. I've got nothing to record a video/sound with 'cept my cell phone, so I'll just say that there are plenty of sound clips out there of the 3.5 with the RT exhaust for those that are curious. I won't be posting that.
    2005 Magnum SXT AWD
    Midnight Blue
