Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    rwalshphoto's Avatar
    rwalshphoto is offline Matte White Wagon
    Phoenix, AZ
    How to: Port a V6 Throttle Body
    Porting the 3.5L V6 Throttle Body
    I started this project last week and got quite a bit of questions and lots of inquiring minds so here is my best shot at explaining the porting of the V6 throttle body.
    The Intake Diameter at the entrance of the Upper Intake Plenum is 71mm. For the sake of this write up and assuming that the results are favorable to the theories presented the porting of the throttle body will be done in such a manner as to create a funnel or venturi effect into the manifold. I'm sure by now you are all aware of the physics behind this, after all the AirHammer is designed around these ideas as well as all other well-performing intakes.
    Stock Throttle Body (Info):
    * Cast Aluminum
    * 67mm at the barrel entrance
    * 65mm at its smallest point at the perimeter of the blade
    * Exit diameter of 68mm tapered to 72mm
    The Ported Throttle Body (the end result):
    * approximately 71mm at the barrel entrance
    * Tapered to 72mm, smoothed into perimeter of blade
    Note: Diameter of TB at blade area will NOT be altered (see further instruction)
    * Smooth tapering of the ridge on exit of throttle body
    * Sand / Polish (optional)
    Tools Needed:
    * Pneumatic or Electric die grinder
    * Carbide Cutting Bits (cylinder with round tip works best)
    * Flap wheels or Sanding cones (80 grit, 120 grit)
    * Caliper (for measuring diameters to check for accuracy and consistency)
    * 500 grit, 1200 grit, polish compound, 2" cotton rag buffing wheel (for polishing....optional)
    Illustrated Procedure:
    70mm Intake Diameter of Upper Intake Plenum:
    Stock Throttle Body (Unported):
    Porting, In Process - Carbide Bit, Rough Surface
    Taper Back of throttle body, smooth ledge, do not remove to much near blade:
    Check for consistency:
    Sanding, Flapwheels or Cones (80 grit, 120 grit)
    ** Smooth the ledge into the blade area but do not go to deep, remove as little material as possible near the blade.
    Check for consistency last time before polishing:
    POLISHING
    * Sand with 500 grit until all major visible scratches are gone
    * Sand again with 1200 grit until your fingers are numb
    * Cover areas in polishing compound
    * Use cotton rag buffing wheel on a drill or die grinder to polish to mirror finish
    End Result:
    Starting over with a new Magnum RT (SRT8 Conversion)... 6.1L with SRT Max Cam, Corsa catback with chambered center pipes, Sinister Extreme dual ram intake system, SRT Suspension, silver Brembos, graphite powder coated Charger SRT wheels, frost white intake manifold (ported) and valve covers, matte black engine bay, carbon fiber engine accents, 300C SRT8 Front end, Matte White vinyl wrap, Black Ops 300-Challenger style carbon fiber hood. Project "SnoMachine" all work performed by Arizona Hemi Specialists - Plum Floored Creations, Mopar Automotive Photography
    CHARGERTREV's Avatar
    CHARGERTREV is offline Official 2 Million Poster!
    Jul 2008
    THE KING OF DE
    It feel any better?
    2007 BB Charger - SOLD
    2012 Black Mustang 5.0 6 speed - Current
    Phoenix, AZ
    Quote Originally Posted by CHARGERTREV View Post
    It feel any better?
    Dunno yet, car has only had 3 miles to learn it. Throttle response is definitely better, cant say yet for the rest of it.
    DaILLestWun's Avatar
    DaILLestWun is offline DUDEBRO!!!
    Pembroke Pines, FL.
    You da man!!! Beans to you!!!
    World's first tuned V6 LX!!
    -Jimmy aka Jimbo
    fnkychkn's Avatar
    greasy cardboard box
    great write up, Ryan. should have posted it in KB submission forum.
    i can sorta see how this could improve airflow but i fail to see how this can improve throttle response. was battery disconnected or fuse 11 pulled to reset PCM?
    Phoenix, AZ
    Pulled fuse 11, yes but not the battery. In my previous thread when I initially started on this I didnt take anywhere near this much out, maybe brought it to about 72mm. But since Billet Tech is giving it a GO and I wanted to try this at max capacity. So its time to data log and send it to Mike Lafrad again and see what he can do.
    As far as perceived gains, it just seems more responsive and "jumpy" if you will off the line. And testing the throttle ranges at different speeds 0-60 and transitions between coasting and WOT. Also hold the car against the stall converter seems to take more braking power now to hold the car back.
    fnkychkn's Avatar
    just pulling the fuse is enough to reset the PCM and improve throttle response.
    pretty sure i have a spare T-body somewhere. might have to try this.
    Phoenix, AZ
    Very true, however I've probably pulled Fuse 11 4-5 times in the past week or so between playing with this in different configurations (I started at 72mm and worked up to this 74mm where it is now) and it has got progressively better and the longer the car has to learn it the better it gets. I just sent some logs to Mike so we'll see what he thinks... poor guy is gonna kill me.
    Phoenix, AZ
    So here is what the schedule is looking like everyone:
    I will be headed to Speedworld tomorrow night to do some track runs now that I am tuned for the cams and also the ported manifold and ported throttle body. If anyone local (cough cough) would like to tag along lets swap out a stock TB and see what the difference is.
    I will be dyno testing this throttle body on BritishNate's car as soon as his tuning is squared away for the camshafts and he gets his post-cam dyno done and his JBA headers installed. We do a baseline run for the car with that current configuration which is:
    Inertia Camshafts V1.1
    Custom Tuning by Mike Lafrad
    K&N Intake
    Blastin Bobs 10db kit replaced suitcase with Magnaflow
    JBA Shorty Headers
    We will install the ported lower manifold and do a few runs with that and then a few more runs with the ported throttle body. We will probably try and put a few street miles in between testing for the manifold and TB as it takes time for the car to learn the mods without being specifically tuned for it.
    ChuckWagon's Avatar
    ChuckWagon is online now no matter where you go, there you are.
    Dec 2008
    Rochester NH
    Excellent work Ryan! Great pics! Beans to you!
    BTW...them there are some new calipers huh? j/k
    oh yeah.....subscribed
    2005 Magnum SXT AWD
    Midnight Blue
    R/T exhaust, demolded, debadged
    Billet Tech catch-can, Airhammer HO
    Predator Custom tuned by Johan!
    R1 rotors front and rear
    Tranzformer shift tool
    shagmag07's Avatar
    shagmag07 is offline MEDICATED AND MOTIVATED
    Oct 2008
    El Paso/Qatar, SWEET HOME ALABAMA
    subscribed
    Magnum Owners Club Member #1430
    Current Mods: 20" Chrome Clads,R/T Powerslot Rotors,R/T Calipers,Diablosport Tuner,JBA Shorty Headers,Big Bully Intake(FREAKINN AWESOME), Injunwiz's Stock R/T Dual Exhaust, SRT Suspension, Debadged.
    www.Facebook.com/stuntin86
    ToddStone's Avatar
    ToddStone is offline Bug Killer Extreme!
    Spokane, WA
    So, just to go back to the grinding, you really don't want to touch the flap area at all, is that correct? How much space did you keep away from it?
    You reshaped it so that from the 68mm to meet the 72mm (just making sure I read that right). Thanks for the write up. I'm very intrigued.
    Mods: Big Bully/Spectre Cold Air Intake; R/T Exhaust;JDM Headlights; SRT Sways; Tinted Windows;Boston Accoustic Speakers and 10" sub, Crunch 500 watt power amp; KW V1 Suspension/Coilovers; Predator Tune; Fog Lights; 71mm TB and lower intake; HoneyComb grille; JBA Headers.
    Phoenix, AZ
    Quote Originally Posted by ToddStone View Post
    I used the 120 grit flap wheel at a low speed and took off just enough material to smooth that ledge down into the blade area. The goal is just to get rid of that lip and nothing more.
    BilletTechnology's Avatar
    BilletTechnology is offline Now that our relationship has changed...
    Dec 2006
    Part Timer in Steamboat.....Full Timer soon.
    Brother this a great DIY. If I could have beaned ya 100 times I would have. Excellent and informative. write up
    Phoenix, AZ
    I have a 2.7L Magnum in my driveway now! It looks promising! He's out for a drive right now and sounds to be doing swell.
