Results 1 to 13 of 13
    a2fire2i's Avatar
    a2fire2i is offline LX Newbie
    Sunny Sarasota, FL
    How to Install a K&N Aircharger Cold Air Intake Kit (part number 63-1114) *
    How to Install a K&N Aircharger Cold Air Intake Kit (part number 63-1114) on a Dodge Magnum RT. This install is the same for other LX platform 5.7 or 6.1 HEMI engines.
    Time: 45 minutes
    Level: Beginner
    Please reference the PARTS LIST
    http://i31.photobucket.com/albums/c3...INSTALL/KN.jpg
    Tools Needed:
    Flat Blade Screwdriver
    Ratchet
    10 MM Socket
    13 mm Socket
    10 mm Wrench
    13 mm Wrench
    1) Disconnect the negative battery cable and remove the engine cover by lifting up.
    2) Remove the air temperature sensor electrical connection. This can be done by unlocking and depressing the red tab connected to the air intake.
    3) Loosen the hose clamp that connects the intake to the throttle body and remove.
    4) Disconnect the crank case vent hose from the valve cover port.
    5) Remove the air box mount bolt.
    6) Remove the air intake box and tube from the engine compartment.
    7) Install the twist bracket (part V) on the core support with parts W, K, X, and L. You will use the two fender washers (part X) to sandwich the core support.
    8) Install the L bracket (part U)) onto the heat shield (part S) using parts T, K, and L.
    9) Install the two pieces of edge trim (parts Q and R) onto the heat shield, making sure to leave a gap at the bracket mounting locations.
    10) Install the heat shield into the engine compartment with the bracket installed in step 7 with parts T, K and L. Also bolt the L bracket to the air box mounting location using the existing factory bolt removed in step 5.
    11) Assemble the saddle tube mounting bracket (part H).
    12) Install the saddle tube mounting bracket to the engine with parts M, O and P.
    13) Install the silicone hose (part B) onto the throttle body with a hose clamp.
    14) Install the grommet (part C) into the K&N intake tube.
    15) Remove the air temperate sensor from the factory intake tube, and place in the grommet that was installed in step 14.
    16) Install the K&N intake tube (part E) to the throttle body with a hose clamp.
    18) Secure tube to the saddle bracket installed in step 12 with a hose clamp.
    -Corey
    2005 Midnight Blue RWD Magnum RT
    Build Date 09/04
    SC Flashpaq 3825 Octane 91 Tuned
    Magnaflows in the rear, suitcase removed and straightpiped
    K&N Air Charger CAI
    AirAid PowerAid Throttle Body Spacer
    Free Auto Headlight Mod
    300C SRT8 Door Pulls
    3 rear windows wrapped in Fractal Art
    a2fire2i's Avatar
    Sunny Sarasota, FL
    19) Connect the K&N crankcase vent tube (part D) from the K&N tube to the crank case valve cover port.
    20) Install the filter adapter (part Z) into the filter charger (part AA) with hose clamps.
    21) Install the silicone hose (part B) onto the filter charger with a hose clamp.
    22) Install the filter charger onto the K&N intake tube with a hose clamp.
    23) Reconnect the air temperature sensor electrical connection.
    24) Reinstall the engine cover.
    25) Reconnect the battery cable.
    The above steps came from the K&N provided installation instructions. This mod was quite an easy install. I did notice a slight whistle/hissing sound after the install coming from the filter area. This noise is normal, but check your connections just to make sure everything is snug.
    Black Hemi's Avatar
    Black Hemi is offline LX Newbie
    Kenosha
    I think the whistle is from your TBS?
    2006 Dodge Charger RT W/R&T 4/6/06
    RamAir hood, Spoiler. Suitcase muffler removed,
    Mopar remote, K&N Aircharger CAI, 180 T-stat,
    Superchips programer 91, Visor stickers, Blinker mod, Front R/T emblem
    pir8magnum's Avatar
    pir8magnum is offline Magnum-animous
    Tampa Bay, FL
    Did you notice any benefits after the install? More responsive? Better mileage? Just curious because this is probably the first upgrade I will be performing on my Magnum.
    Thanks!
    stanekjp's Avatar
    stanekjp is offline LX Newbie
    Ringwood NJ
    I just put in a mopar cai, and I have a whistle too... Is that really normal? To me it sounds like there might be air entering somewhere it shouldn't. Can't pinpoint it though. Sometimes it occurs softly at 2000rpms when the engine is under load like going up a hill, and other times when at full rev it sounds REAL LOUD, like a backyard style firecracker taking off kind of whistle.
    I also hear a knock/click from the intake area that gets faster underthrottle, almost like a rhythmic engine knock/ping or something flapping open and closed. Perhaps that was there before, and the new intake made it more audible.
    Any thoughts?
    2006 Inferno Red Magnum R/T AWD
    Mods: Diablosport Predator, Mopar Cold Air Intake, Trailer Hitch w/7pin wire, 300C DUB Chrome Lower Window Trim, 300C SRT Leather/Chrome Door Pulls, Leather armrest cover, minor custom paint of plastic parts, roofrack, and engine cover, shaved door molding, 255/45 R20 Yokohama Parada Spec-X, 20x8.5 Voxx Ancona Wheels
    dstyl3's Avatar
    dstyl3 is offline Bend over, because D Styl3 is here!
    Jan 2007
    Winter Springs, Fl
    great write up!
    Mike Evans
    Winter Springs, Florida
    2005 Dodge Magnum SE
    Mods: 5 and 28% Window Tint, K&N Drop-in Filter, JL Audio 500/1 Amp, JL Audio 12in W6v2 Sub, and Monster Cable 4guage, SS Pillars, Chrome Door Handle Covers, Chrome Vent Ports, Real Rosewood Dash Kit with "Magnum" logo American Racing Burn's 22in Black with SS Lip...
    Modding cost money and money takes time ...soon i will be adding some more goodiess!!!!
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    The whistle is normal for most CAI's.....they are more open than the stock unit filter boxes so you hear them a little more.
    LX HEMI's Avatar
    LX HEMI is offline RIP Magnum R/T
    Virginia Beach, VA
    Quote Originally Posted by stanekjp View Post
    Any thoughts?
    Mine does the same thing. Being new to the club and just buying my Magnum RT about 2 months ago, it already had a K&N CAI installed, along with Magnaflow's. Makes the hissing sound when I'm on the gas and it's really loud when I stomp on it but quiets down when the rpm's get really high. Kind of intemidating to others when they hear it rev. People think there's a super charger or a turbo under there. I like it...
    Even the slight knocking/clicking/flap noise I hear as well.
    R.I.P 05 Maggie RT
    Welcome 05 Z71
    CAI, MT's 35's, ProComp 18's, 6" Lift
    06 Harley custom, chopped, dropped and jockied
    PUNISHER's Avatar
    PUNISHER is offline I dont drive fast I just fly real low
    Seffner, Fl
    Now Add you a Fuel Saving AirTornado and Woosh you will be ready for the INDY 500!
    Jack aka The PUNISHER
    06 Charger R/T - Hemi Registry #00746
    Judged Best Charger at the 2007 LX Shindig
    http://www.myspace.com/813stylz
    www.cardomain.com/ride/2617203
    trav_d's Avatar
    trav_d is offline Hemi Hooked!
    Mar 2009
    Ohio
    Nice write up. Only step you forgot was to detail your engine compartment when you got you old air intake off.
    Travis (trav_d)
    draftingmonkey's Avatar
    draftingmonkey is offline LX Newbie
    Oct 2009
    South Ornage County, CA
    I installed a Volant CAI and part of the setup was a new tube from the front to the air box. The stock tube/box is a pretty hefty item as you can see. For you K&N guys it might be an idea to remove the extra weight as it is so aerodynamic.
    Alex832's Avatar
    Alex832 is offline Alex832
    Aug 2011
    trav_d...... nice to see someone else as anal as me
    Alex832's Avatar
    Aug 2011
    ive recently installed a K&N....didnt notice any whistle........and knowing me if it was there i would have herd it.....i'll keep tuned to it
