How to Install a K&N Aircharger Cold Air Intake Kit (part number 63-1114) on a Dodge Magnum RT. This install is the same for other LX platform 5.7 or 6.1 HEMI engines.
Time: 45 minutes
Level: Beginner
Please reference the PARTS LIST
http://i31.photobucket.com/albums/c3...INSTALL/KN.jpg
Tools Needed:
Flat Blade Screwdriver
Ratchet
10 MM Socket
13 mm Socket
10 mm Wrench
13 mm Wrench
1) Disconnect the negative battery cable and remove the engine cover by lifting up.
2) Remove the air temperature sensor electrical connection. This can be done by unlocking and depressing the red tab connected to the air intake.
3) Loosen the hose clamp that connects the intake to the throttle body and remove.
4) Disconnect the crank case vent hose from the valve cover port.
5) Remove the air box mount bolt.
6) Remove the air intake box and tube from the engine compartment.
7) Install the twist bracket (part V) on the core support with parts W, K, X, and L. You will use the two fender washers (part X) to sandwich the core support.
8) Install the L bracket (part U)) onto the heat shield (part S) using parts T, K, and L.
9) Install the two pieces of edge trim (parts Q and R) onto the heat shield, making sure to leave a gap at the bracket mounting locations.
10) Install the heat shield into the engine compartment with the bracket installed in step 7 with parts T, K and L. Also bolt the L bracket to the air box mounting location using the existing factory bolt removed in step 5.
11) Assemble the saddle tube mounting bracket (part H).
12) Install the saddle tube mounting bracket to the engine with parts M, O and P.
13) Install the silicone hose (part B) onto the throttle body with a hose clamp.
14) Install the grommet (part C) into the K&N intake tube.
15) Remove the air temperate sensor from the factory intake tube, and place in the grommet that was installed in step 14.
16) Install the K&N intake tube (part E) to the throttle body with a hose clamp.
18) Secure tube to the saddle bracket installed in step 12 with a hose clamp.
2006 Inferno Red Magnum R/T AWD
American Racing Burn's 22in Black with SS Lip
...soon i will be adding some more goodiess!!!!
