Results 1 to 15 of 18
    rjkusse's Avatar
    rjkusse is offline Vader
    How to install American Racing Technology Oil Can
    I've been reading a lot about the amount of oil that gets into the intake and therefore into the cylinders. I wasn't really interested until I had my intake off and the runners were covered in oil.
    That prompted me to find a solution. I had seen many different types for the GM cars but none that fit without modifications for the LX platform. One of our local DFWLX club members contacted David at American Racing Technology. David has been making them for the Vipers for years and was happy to help. This is one of the few that have been installed. So here's my install instructions.
    Mod:
    Install American Racing Technology Oil Catch Can
    Time:
    30 Minutes
    Skill Level:
    Easy
    Tools Required:
    - 9/16" wrench or socket
    - 5/8" wrench or socket
    - Allen wrenches
    - Utility knife
    Additional required items:
    -Autozone hose part #4522 - see below
    Step1: The kit
    The kit comes with you see here
    Step2: Currently the barbs that David provides are a little long in the threads, however they are the right size for our hoses, so no adapters are required.
    Mark it and cut it back so it is inside of threads
    Step3: Because this is all based on vacuum, I used tephlon tape on all the fittings
    Step4: Install both fittings
    Step5: Assemble the bracket. The nice thing is it is drilled for multiple mountings, so there is no issues with clearances.
    Step6: Mount bracket. There are two long bolts provided with the kit. There is a hole next to the alternator where the shorter one goes. The other along with the sleeve goes into the head.
    Step7: Connect hoses. This is where the additional hose comes in. Per David, you can use the existing hose to go to the top of the can. Looking for a little bit of a better solution I went to visit the local Autozone store. Here is where the hose currently connects into the PCV
    To the top of the intake:
    After looking around in the back of Autozone, I found one that I initially thought might work. It actually worked out much better as you will see. It is part number 4522 or 63249. The hose on the bottom is the stock and the Autozone hose is on the top:
    It is just a little bit longer on the end going into the PCV so some trimming with a sharp utility knife is required.
    Step8: Install can and tighten. Now install the can and connect the hoses. David provides the hose that goes from the side of the can to the top of the intake. He also plans to offer different clamps for these hoses in the near future.
    You can see here how nice the hose from Autozone fits the new application:
    Connect the other hose and thats it.
    Never argue with an idiot. They drag you down to their level then beat you with experience.
    2006 300 SRT8 - fully loaded
    MODS: Centric Posi-Quiet pads, Magnaflow hi-flo cats, Corsa cat back, Airhammer II, B&G StageII, Tinted tails, Painted grill, SS Brake lines, LED interior, GSM Phenolic Spacers, HD Police Oil Cooler, Stealth Bulbs, 176 t-stat, GSM Fan/ESP, KW V2, Hotchkis Sway Bars
    SRT-8 Hemi's Avatar
    SRT-8 Hemi is offline LX Newbie
    Fresno, CA
    Where can I get one of these? Does the can rest on the alternator? Is the can drilled for a 3/8 fitting or is it actuall drilled for the 1/2 fitting?
    SiliconJesus's Avatar
    SiliconJesus is offline modernmopars.com
    Hagerstown, MD
    Is this just straight using the Viper Kit? Will it work as well on the 5.7?
    Thanks for an awesome writeup. Beans!
    sixsicksheep's Avatar
    sixsicksheep is offline Indian Name = Counting WhiteMans Money
    5 mi North of the U.S.A.'s Prince Albert.
    How much, and where can I aquire this kit. The black will match well with everything else goin in the engine bay.
    Girtman
    '99 Dodge Viper GTS Silver/Blue Stripes--SOLD
    '07 Magnum SRT8 Option Groups: I, II
    Official FLXC Member!!!
    http://www.myspace.com/sixsicksheep
    http://www.cardomain.com/ride/2647810
    Upcoming Mods: Kooks LT Headers & Hi-Flow Cats, Mopar Coilovers & Sways.
    Finished Mods: Check out the Cardomain Page for completed mods
    2007 MOROSO-MOPAR CHALLANGE 1st Looser!! (also known as runner-up)
    rjkusse's Avatar
    Here's the ordering info:
    David Weaver
    General Manager
    866-313-RACE
    512-312-2258 local
    512-312-2944 fax
    Give Dave a call and he will set you up. Not sure about the 5.7L?
    The bracket allows it to sit above the alternator and the fitting and can are all tapped for 1/2" so no need for adapters.
    Thanks. I'm going to order it tomorrow.
    Girtman
    Ozzie's Avatar
    Ozzie is offline LX Goo'Roo
    SoCal
    Thanks for the detailed instructions and pix! Most excellent!!
    Pigman 440's Avatar
    Pigman 440 is offline Mag RT AWD
    Dec 2004
    Grove City,Ohio
    good info & pictures,thanks!!!
    Hemi registry#00729
    LxReJx
    Super T's Avatar
    Aurora, IL
    I don't like the one-size-fits-all bracket, but props for the install :-)
    rjkusse's Avatar
    The benefits outway the lack of an application specific bracket for me.
    300CSRT8's Avatar
    300CSRT8 is offline www.dfwlx.com
    Dallas Area
    You are my hero Rick
    Rob
    _______________________________________
    Check us out @ www.DFWLX.com
    oldschool is offline Look at that wagon she is draggin'!
    May 2006
    CT
    I think I saw this/something similar on Bipto's today. Looks like a great idea. Is this a 6.1 thing or is this a 5.7 problem as well?
    oldschool
    BB 7db,Aircharger, blinker mod, BOSS 326 275/40/20, Mobil 1, 20% tint, tit. pedals, full LED interior, LED stock tail conversion, full chrome interior, chrome mirrors/handles, color matched license/fog bezels/chin spoiler, husky mats, Billet Tech goodies, 4"X18" tips, lead foot of course!
    http://www.lxforums.com/gallery/brow...=2&userid=8959
    rjkusse's Avatar
    Not sure about the 5.7s. Anybody?
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Quote Originally Posted by rjkusse View Post
    Yes 5.7 also especially heavily modded 5.7's
    Video
    DarthCharger's Avatar
    DarthCharger is offline LX Guru
    Aug 2007
    Cypress, Texas
    Very useful install and the instructions and pics are excellent. Do the instruction provided by ART include torque specs for the long and short bolts or does it not matter?
    DarthCharger
    2007 Charger SRT 8 Two-tone
    Viper Red/Brilliant Black Crystal Pearl
    Arrington forged 392\ProCharger D1SC (11.377/123.8mph)
    2009 Challenger SRT 8
    Hemi-Orange & Techco SC
    Member of SpaceCityLX club, DFW LX Club, Tx Outlaw Challengers, & West Houstom Muscle Club.
