If you've gotten the 0520 error code, it is time to replace your oil pressure sensor. The tools to use are:
15mm socket wrench and open end wrench
foot long extension for 3/8" drive
10mm socket
cheater bar (approx. 1 foot long)
car jack
jack stands
electrical tape
First things first. Get the front of the car off the ground and on some jack stands.
Remove the four 10mm bolts holding the belly pan to the car. The belly pan is located directly under the engine of the car. Set it aside, out of the way from the work area. Next, pop the hood and lift it up. Crawl under the passenger side of the car and locate the bolts holding the alternator to the engine.
In the above picture, there are two bolts that are already loosened. One is attached to the black bracket. Take these completely out using a 15mm socket and extension. I had to use a cheater bar and a 15mm closed end wrench to break them loose and then used an articulating knuckle and socket to take them out. The socket extension will stick out into the fender well. When those are out, stand up and look down into the engine compartment. You will need to remove the serpentine belt by putting your 3/8" rachet into the square hole in the automatic belt tensioner. It is located in the front middle of the engine and is aluminum in color. With the tensioner moved toward the passengers side of the engine, remove the belt from the alternator.Locate the 15mm bolt at the top of the alternator.
Once the bolt is out, remove the cables from the back of the alternator. ***CAUTION*** The cable in the picture above is HOT. It has 12volts on it and it will spark and short out the battery. Either wrap the 15mm extension with electrical tape or disconnect the battery. I wrapped my extension. When the cable is loose wrap the end with electrical tape. The oil pressure sensor is now easily visible. The wiring is connected to the sensor with a special plug. You may have to turn the sensor a bit with a crescent wrench to get at the release.
This picture shows the plug in the released position. The red button slides from left to right. Once this is off, the sensor can be removed using a crescent wrench. The picture above shows the plug in the released position.
Here is a fuzzy picture of the sensor.
The plug has three wires in it. I found oil in this plug and may be the source of the problem.
To replace the sensor, just do everything in reverse. Good luck!
1Likes
DODGE MAGNUM...its NOT your mammy's station wagon!!!!!
