The Frankencooler project, originally announced in this thread came about to address a situation found to plague -- and in some cases disable -- LX vehicles driven in extreme circumstances... particularly with respect to track days. I would, however, not limit this project to tracked cars only. For example I would argue that ANYONE who has installed a high-stall torque converter needs the tranny cooler.
I'll let that original thread stand as an intro to this one, and not re-cover the ground that was gone over there, so if you haven't looked at least at the initial post of that thread, go check it out, read the background and come back afterwards.
As was noted in the original thread, unlike the Frankentake project, Frankencooler is a project that needs a shop to do the work, or someone experienced enough with automotive maintenance -- who has the tools -- to take it on. this is not a job for the noob. Now that we've done a couple of installs we can say this for sure. We had some surprises, some redesigns and some difficulties, all of which were worked through. And it turned out to be more expensive than expected. I would expect that the best you are going to get away with is 5 hours shop time, assuming a meticulous and careful job is done. You should expect six. Lastly, reality bumped off theory as usual and we have had some parts list changes from that earlier thread (although I have, with one exception, kept the lists updated in the other thread).
Coolers and Capacities
I have spent a bunch of time on this, and learned a lot. All coolers are nowhere near alike, even if they are of the same type. Like in many things, you can find "the same" product at different price points and quality levels.
First of all, we are not using tube-and-fin coolers for anything here. The tube-and-fin design is good for minimal restriction but in terms of capacity, its not optimal. Instead the stacked-plate type of design is what you want if you want to pack in a lot of cooling capacity into a small area. Not surprisingly, stacked plate coolers are relatively expensive. An excellent description of how stacked plate coolers work is at the Setrab USA web site.
In general, it seems as if most of the stacked plate coolers out there and available to us ordinary slobs are made, in alphabetical order, by Derale, Earl's Performance Plumbing and Setrab. Actually calling Derale a manufacturer is incorrect, since Derale is buying coolers from a 3rd party and simply packaging them, unlabelled, in their own name.
Derale
These coolers were the original choice for all three coolers in this system. While their pricing isn't cheap, its still the least expensive out there. However Derale has more than its share of problems. First of all, all units are on "custom order" status at Summit Racing or anywhere else you try to buy them. The individual I spoke to repeatedly at Derale told me this is because what Derale does is wait until enough orders accumulate for their coolers to allow them to get *their* required minimum order quantity, at which time they buy coolers from the manufacturer to in turn hand off to Summit. We discovered the hard way that the month-long wait we experienced could very easily stretch to at least two as our oil coolers came in, but the tranny coolers were projected to be a wait of still another month by the time it was admitted that no coolers had arrived, nor would they be arriving anytime soon. A call to Derale yielded apologies and evasions but nothing positive, which was kind of a pattern when talking to them about getting product shipped. Not only was the transmission oil cooler replaced by another brand, so was the engine oil cooler. Why drop Derale coolers for both applications? Thats another story, and not so flattering to Derale, either.
Lest you think I am totally down on Derale, I am not. If you have time and patience, and you are willing to accept a quality level that is "acceptable", then you can consider the Derale units a budget alternative and save yourself about $85 across both engine oil and transmission oil coolers. They should work fine.
The oil cooler mini-saga
After receiving our tranny oil coolers from Earl's, I wanted to know if I could get a capacity ratingg from them, so I called and spoke to an engineer at Earl's and was given some hot-off-the-test-bench efficiency test results. They showed the cooler efficiencies even better than Setrab's published numbers by a fairly wide margin. Meister and I decided to order one each, examine them at time of install, put in the better of the two and send the other packing. when the Earl's unit arrived Bob at SVS compared them and noted that the Derale unit's ID for their fittings was markedly smaller than the Earl's unit. So that was that.
However when my own cooler arrived I compared it to the Derale and found no such fitting size differential (although there was a definite difference in fit/finish/materials, with Earl's winning the comparison). Upon my arrival at the shop I held the two coolers side by side and saw that clearly the Derale had the wrong size fittings... so wrong the -10 fittings wouldn't screw into it. After making their customer wait for over a month for delivery, they sent a cooler with -8 AN fittings packaged as a -10 AN. Meister would have been screwed if we hadn't had this backup plan already in place.
My Derale cooler vs. the one Derale sent to Meister
Earl's 25-row unit next to the comparable Derale. Note the earl's fittings follow the industry norm and are interchangeable whereas the Derale fittings are permanently fixed. there's no way to fix it without sending the cooler back and waiting another month for the right one to arrive.
Setrab
Setrab is a big name in coolers. Their stuff is top quality. With that reputation comes the top price on the market. Interestingly, Derale told me they used to buy their coolers from Setrab, but did so no longer due to increased pricing. Indeed, a Setrab cooler could be almost double the cost of a Derale cooler even at the best internet price to be found (Google "Setrab Coolers" to find them). Their heat transfer ratings are certainly excellent. Setrab's pricing coupled to their heat transfer ratings when compared to Earl's coolers kept them from being considered for this project.
Originally written off as unnecessarily expensive given the Derale products' pricing, Earls' coolers wound up being our coolers of choice. The fact that they could be had in a single day without any hassles was certainly a big factor, but after talking with an engineer at Earl's, and directly comparing the quality of the coolers they delivered, Meister and I both are happy we made the move away from Derale. In hot-off-the-bench performance figures made available to us, Earl's heat transfer ratings beat out Setrab by a substantial margin.
NOTE:
All parts numbers below are for for Summit Racing, where you can buy everything you need in one shot. If you want to shop around maybe you can beat some of these prices, but Summit prices their products aggressively
ADDED Jun 16 2007: You can save a few bucks over the parts lists shown below by using Summit Racing's house brand for some fittings and for braided hose. For example, AER-FBM4034 costs $23.95 and you need two of them on the oil cooler. You could use two of SUM-220087 priced at $15.95 each and save $16. However no one as of this writing has purchased these parts and reported on their relative quality.
...the next
