Results 1 to 7 of 7
    swagon's Avatar
    swagon is offline Ding Frys are done
    Jan 2009
    WISCONSIN
    Crankshaft Position Sensor Replacement
    Quick little how-to.
    1. Disconnect battery
    2. Remove the 3 bolts (15mm socket) that hold the starter in.
    3. Move starter to the side. You do not need to remove it, it will sit to the side.
    4. Locate sensor, you will have to unplug before removing the sensor, to get the sensor unplugged you will have to rest the starter against your hand to have enough wire to get the sensor unplugged. The plug is the same as the one on the coil packs so you might want to check out how they operate before you try to unplug the crankshaft sensor. Use a 10mm socket to remove the bolt.
    5. Apply dielectric grease to the plug, apply a small amount of grease to the o-ring and reinsert the sensor in the block, reconnect the plug, and tighten the bolt for the sensor.
    6. Replace starter and tighten the three bolts. Remember to include the bracket on the top bolt that holds the wires in place.
    7. Reconnect battery
    Hope these can help someone. Any questions please ask.
    sergeo'shemi's Avatar
    sergeo'shemi is offline True failure is the failure to try!
    Jan 2008
    Chicago IL
    so why did you have to replace yours?
    400ci stroker, Vortech blower, and enough said
    07 Magnum Srt8 incognito brute
    UPS92008's Avatar
    UPS92008 is offline appetite for destruction
    Sep 2007
    Carlsbad CA
    Long starts????
    20" Vipers/ Afe Stage 2 Pro Dry S/ BT bling/
    Stealth lights/ mopar/ KILLERGLASS
    CORSA/ EBC USR's/ HOTCHKIS/ Diablosport/
    HID 5000K/ BMC/ jj's precision guesswork/ MGP/
    swagon's Avatar
    Jan 2009
    WISCONSIN
    Quote Originally Posted by sergeo'shemi View Post
    My car runs like crap. Here is a thread I started and it was a cheap thing to try and a few people suggested I try it but it did not help so on to other parts.
    Sergio is offline LX Newbie
    Mar 2010
    There are many ways to save the connector from the elements, if the supplied heat shrink is not suaitable you can fill the ends with liquid electrical tape, it will seal the connector.
    archebald23 is offline Banned
    Jul 2010
    whats a liquid electrical tape? is it some sort of a silicone sealant? with my crank position sensor, i used a silicone sealant to seal the connector.
    sam01 is offline LX Newbie
    Nov 2011
    There are many ways to save the connector from the elements, if the supplied heat shrink is not suaitable you can fill the ends with liquid electrical tape, it will seal the connector.thanks for sharing
    __________________________________________________ _____________________
    ged practice test ged math practice test ged software ged prep kit ged books
