Here is a quick post on replacing the camshaft sensor.
1. Disconnect the negative battery cable.
2. Locate the camshaft position sensor, it is on the passenger side in the front on the block.
3. Remove 10mm bolt and remove camshaft sensor.
4. Unplug sensor, apply dielectric grease to new sensor and plug in, apply a small amount of grease to o-ring, replace into block and tighten bolt. Can't remember torque spec but will update it when I find it back.
5. Reconnect battery cable.
