Page 1 of 13 12311 ... LastLast
Results 1 to 15 of 188
    PaCharger's Avatar
    Oct 2005
    Supercharged 2012 Audi A6
    Cam/Head Install Library thread
    Well well well - MAJOR kudos to Jeff F. aka PopEyes's Hemi
    He really went above and beyond the call of duty (not bad for an old guy from the coast guard )
    He has culled through the depths of this thread, shared information, and beyond to put together a great document.
    We've split it and posted it to google documents and it is consumable by the entire LX Community now.
    Please take care to read through the content, it is entirely usable at your own RISK.
    Updates and comments to updates can be sent to PopEye or myself and we'll edit as time permits.
    Hope this continues to help others looking to educate, install, understand or whatever other purpose you use the content for.
    Cam Heads Headers Install Part 1
    Cam Heads Headers Install Part 2
    Well, I'll start this and edit as necessary. As I've searched, researched, and searched some more, I've read a ton of great informative threads on cam/head installs.
    For those making search your friend you quickly realize titles make it tough to get all the great resources....so....here it is, an attempt to put all the forum brainpower, pics and information in one in easy to find place.
    Post any other threads and I'll gladly add them.
    thanks,
    PaCharger
    Really Fast Cars with New Internals
    El Cobra
    65standard
    RT Addiction
    Hemiwagn
    1Fastsedans
    blk6.1
    Bipto's
    Pics of Bipto's
    flybyu
    Pics of Hemi31's
    Pics of JonzMagnum's
    Pics of BrilliantBlackHemi's
    Pics of Bipto -more
    nhdave's
    Jaak
    Big D
    Trojan
    BoiseHemi
    Cam
    GoDaddy
    PaCharger
    InferAl
    Precision Motorsports Install
    Metgo & mtcraigco
    Flanmans 407
    Token AWD
    Slim & Boogie
    Gary's mighty fine install
    Gabes Install
    V6 Installs
    BritishNate V6 Install
    RWalshPhoto's 3.5 Inertia Install
    Disassembly Video
    Assembly Video
    Supplies:
    1) new oil and filter
    2) antifreeze and distilled water (+ Zerex additive for certain 6.1s)
    3) windshield washer fluid if you have a 300 with headlight squirters
    4) motor assembly lube (can use motor oil too)
    5) magnets for holding the lifters back - not needed if pulling heads too(we used Craftsman screw starters which were perfect, but pricey at $6 a piece x 16)
    6) new crankshaft bolt
    7) new cam bolt (can re-use the old one, but I figured since I was putting in a new cam, why not a new bolt too)
    If doing head swap too, you'll also need:
    1) Long head bolts or studs - (20)
    2) Short head bolts or studs - (10)
    3) Exhaust manifold/header bolts
    4) Head gaskets (2)
    5) Exhaust gaskets (2)
    6) Intake manifold gaskets (2) - may be able to re-use the old ones, but they often tear.
    TOOLS:
    Full set of metric sockets (10mm - 15mm mostly)
    Screwdrivers for clips, clamps, etc..
    Torque wrench for proper specs
    Coolant Pan
    Oil Pan & Oil filter wrench
    3/8" and 1/4" ratchets, with plenty of various extension lengths
    5/8" swivel spark plug socket
    Harmonic Balancer puller (can rent for free from auto parts stores)
    Valve Spring Compressor (can rent for free from auto parts stores)
    Plenty of Rags
    Mechanics gloves
    Parts and Part numbers
    6.1L Head Gasket (2)- 5037 592AA
    6.1L Intake Manifold Gasket (2) - 5037 503AA
    6.1L Head to block bolt primary (20) - 6506 694AA
    6.1L Head to block bolt secondary (10) - 6506 334AA
    Crank bolt (1) - 6506 340AA
    OEM 6.1L Header bolt (16) - 6503 131; Hex flange head M8x1 bolt
    TORQUE CHART 5.7L ENGINE
    DESCRIPTION N·m Ft. In.
    Lbs. Lbs.
    Block Pipe Plugs
    (1/4 NPT)
    20 — 177
    (3/8 NPT) 27 — 240
    Camshaft Sprocket—Bolt 122 90 —
    Camshaft Tensioner Plate—Bolts 28 — 250
    Timing Chain Case Cover—Bolts 28 — 250
    Lifting Stud 55 40 —
    Connecting Rod Cap—Bolts 21
    plus 90° Turn
    15
    plus 90° Turn
    Main Bearing Cap—Bolts
    M-12
    27
    plus 90° Turn
    Crossbolts
    M-8
    28 — —
    Cylinder Head—Bolts
    M-12 Bolts
    Step 1 34 25 —
    Step 2 54 40 —
    Step 3 Turn 90° Turn 90° —
    M-8 Bolts —
    Step 1 20 15 —
    Step 2 34 25 —
    Cylinder Head Cover—Bolts 8 — 70
    Exhaust Manifold to Cylinder Head 25 — 220
    Flexplate to crankshaft—Bolts 95 70 —
    Flywheel to crankshaft—Bolts 75 55 —
    Front Insulator—Through bolt/nut 95 70 —
    Front Insulator to Block—Bolts 95 70 —
    Generator—Mounting Bolt 55 40 —
    9 - 1530 ENGINE - 5.7L SERVICE INFORMATION
    LX
    Intake Manifold—Bolts Refer to Procedure
    Lifter Guide Holder 12 — 106
    Oil Pan Bolts 12 - 105
    Oil Dipstick Tube 12 — 105
    Oil Pan—Drain Plug 27 20 —
    Oil Pump—Attaching Bolts 28 — 250
    Oil Pump Pickup Tube – Bolt and Nut 28 — 250
    Rear Seal Retainer Attaching Bolts 15 — 132
    Rear Insulator to Bracket— 68 50 —
    Rear Insulator to Crossmember 41 30 —
    Rear Insulator to Transmission— 68 50 —
    Rear Insulator Bracket—Bolts 68 50 —
    Rocker Arm—Bolts 22 (nm)— 195 (In.lbs)
    Spark Plugs — — —
    Thermostat Housing—Bolts 28 — 250
    Throttle Body—Bolts 12 — 105
    Vibration Damper—Bolt 176 129 —
    Water Pump to Timing Chain 28 — 250
    Case Cover—Bolts
    also the downloadable Service Manual (courtesy of Factory D): New Service Manual Download Link
    1fastsedan's Avatar
    almost Mexico, CA
    Here's my write-up. Its for a 6.1 cam swap, but has a lot of the steps needed to do heads and cam.
    Instructions and tips for doing a cam swap...
    PaCharger's Avatar
    Oct 2005
    added, thanks!
    04hemipwr's Avatar
    04hemipwr is online now From Hemis to turbines...
    Grand Rapids, MI
    PaCharger's Avatar
    Oct 2005
    keep 'em coming. Almost pm'd you and erik to find the rest......figure it's good late night winter reading anyhow. Thanks eric
    mhigham's Avatar
    mhigham is offline LX Guru
    Feb 2007
    Michigan
    thanks guys...subscribed....
    Mike
    06 Magnum R/T Midnight Blue
    bipto's Avatar
    New Hampshire
    This thread is a good idea...
    HERE is the story of the very first 6.1 FRI Tomahawk prototype install...
    And HERE is a thread with some video taken about 500 miles later...
    It's hard to believe I've got over 10k miles on this combo now - I've been grinning for every single one...
    The Iron Mistress Galleries
    R.I.P. Dave...
    PaCharger's Avatar
    Oct 2005
    lmao, thanks bipto..i also linked to your pics, hope you don't mind. funny, when you posted I was already reading your threads and realized I didn't have your's - the original!
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    I'd love to post mine but Bipto has it all........I was too busy to take pics
    BFNY PERFORMANCE
    RIP My Friend
    PaCharger's Avatar
    Oct 2005
    Was that the 6.5hr install...insane fast!
    Still scouring here and CF to see what I can find.
    bipto's Avatar
    New Hampshire
    Quote Originally Posted by PaCharger View Post
    Of course I don't mind!
    R.I.P. Dave...
    bipto's Avatar
    New Hampshire
    LOL - what you were doing was far more important! Gotcha covered, my friend...
    Hemi31's install pics...
    also...
    JonzMagnum
    BrilliantBlackHemi
    Bipto
    R.I.P. Dave...
    nhdave's Avatar
    nhdave is offline This space for rent.
    New Hampshire
    And mine. I ended up having to take my own as the photographer I brought along ended up wanting to get his hands dirty too.
    06 Inferno Red Magnum SRT8
    Pretty stuff: Blinker mod, Silverstars, Auto Headlight, ERF Backups, 22Elite console w/Jina's stitching
    Go-fast stuff:
    Arrington 426 w/607 cam and FRI Heads by BFNY Performance, Tuned by HemiTuner, Kooks, Protorque 2800, Airhammer, 180 t-stat, Cool-It, B&B Catback
    11.973@112.45 N/A
    11.42@117 - 1.579 60'
    juiced
    PaCharger's Avatar
    Oct 2005
    thanks dave....anyone else know of someone I should be looking for? A thread from way back two months ago
    Jaak's Avatar
    May 2005
    2006 Magnum SRT8 - 11.85@117
