This is the correct length belt needed for the 5% overdrive pulley.
Old Dampener:
New ATI Unit:
Old Dampener:
New ATI Unit:
Nice Red. Any noticeable difference in anything? Charging issues? Dimming? More power? ect...
What kind of info do you want....it is a dampener that is stronger than the stock one and can handle higher revs...with my TCM my car shifts at 6500 RPM and the stock dampener really ISN'T made to handle that...replacing it was preventive maintenance.
You need a damper cause your car revs 250 more RPM than stock?
Why the 5% overdrive? Wouldn't you want an underdrive if you are running the motor at higher RPMs?
Just curious.
Thanks!
Thanks for the post. Now I don't have to search all over hell. You get that bad boy back together yet?
Later
Slice of cherry pie...Slice of the profits...Slicing through traffic...It's all relative.
"Slicer"
Silver "The Refined Color" Charger SRT8 Options I, II, III and Sunroof.
Badged like crazy!!!
....waiting till tomorrow to fire her up..appraently you need a PCM to get the car to start...who knew ???![]()
