Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    RobAGD's Avatar
    Reston, Va
    Air Fuel Meters and Data Logging
    Ok after a lot of PDF reading here is what I have on the WB controlers listed above :
    Zeitronix ZT-2 - Base $279 ( No Display ) w/ Display $399 Order page
    Pros
    Anaglog WB Out
    Serial Out for Datalogging
    Inputs - RPM, TPS, Boost/Vac, EGT
    Warning Out
    Programing Lambda switch point - Can force lean/stock/rich conditions
    Cons
    Display is kind of expensive
    PLX SM-AFR - Base $195 ( No Display ) w/ DM-5 Display $269
    Pros
    No Calibration
    2 Analog Outs - Sims Narrow Band for factory Bung use
    No Heat Shield
    Cons
    No Display on base unit
    Requires using filtering Caps ( maybe not a con )
    No Calibration - accuracy issues ? (unknown)
    PLX M-300 - $315
    Pros
    Simple setup
    WB Analog Out
    Narrow Analog Out
    Replaces Factory Narrow
    No Calibration
    No Heat Shield
    Cons
    simple display
    lack of some features
    No Calibration -Accuracy issues ? (unknown)
    PLX R-300 - $450 w/o G Sensor $530 with
    Pros
    Neeto Nifty Dash Hawk like Display
    No Heat Sheild
    No Calibrations
    WB and Narrow Analog outs
    Replace Factory Narrow
    Accepts a G Meter sensor ( Oh Matt..... :D )
    Cons
    Price
    PLX R-500 $579 w/o G Sensor w/o EGT $720 with Both
    Features:
    Analyze fuel maps
    Analyze timing maps
    Advanced engine health monitoring
    6 Fully customizable gauges
    90 Minutes data logging
    Real-time dyno
    Stand alone engine management system interface
    Piggyback fuel system interface
    Interface with data loggers
    Stock narrowband sensor replacement
    Innovate LC-1
    Pros
    2 Analong Outs
    Sims Narrow to ECM
    Analog out Startuo Voltage control for stock narrow replacments
    Setting sample speeds
    Cons
    Heat Shield
    Calibration
    Extra Wiring
    No Display
    FJO Model CWC400x
    Features
    Data log up to 8 AFR channels simultaneously
    Sensing range from 10:1 to 20:1 AFR for gasoline
    Accuracy better than 0.1 AFR over the range 10.5:1 to 15.5:1
    Sampling rate greater than 250 per second
    2 channel programmable AFR voltage output for use with ECU or datalogger
    Serial output for display(s) or datalogging
    Tach input from 0 to 20,000 RPM
    Comprehensive analysis software
    Replaceable sensor harness
    -40° to +85°C [-40 to +185 °F] ambient operating temperature range
    Dash-mounted AFR displays
    Multi-sensor support (NTK and Bosch sensors)
    High speed FJO Digital Data Bus for expansion
    OK here are my thoughts on this :
    Pros
    Output programable 0-1, 0-5, .5-4.5, 1-0, 5-0, 4.5-.5
    Digital Port can suport Logging and guage
    Programable Custom Curves
    Rugged designs
    Solid SW Package
    Cons
    One of the outputs is factory locked to the FJO Legacy and is not workable with much else
    From reading the manual this is not as friendly as some other unit
    Limited vs other systems
    AEM 30-4100 Gugae Type UEGO Controler - $350
    Features
    Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
    Does not oscillate AFR reading like narrow band sensors
    No laptop required for monitoring!
    Bosch sensor included
    Accurate to 0.1 AFR
    Reads in AFR or Lambda via a switch in back of gauge housing
    24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
    Integrated three-digit display reveals AFR or Lambda in real time
    User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
    Serial data stream included for output of AFR (RS 232)
    Pros
    Has Display/Guage
    Has 0-5v Out good for DH w/ HE
    Cons
    No Narrow band out
    Have to make your own cable for Datalogging
    Very Basic logging
    Must use AEM O2 Sensors (?) stated in FAQ,
    AEM 30-2300 Dual Channel Controler Dual - $600 Single $400
    Features:
    Ideal for use with virtually any aftermarket programmable engine management system
    Accurate to 0.1 AFR
    Available in single- or dual-channel models
    BOSCH sensor(s) included
    0-5v calibrated output with 0-1v secondary output available to eliminate trouble codes
    Reads as rich as 0.55 Lambda
    Extruded aluminum enclosure
    Laptop or AEM UEGO Display Gauge required for monitoring
    Pros
    Each Channel has 0-5 & 0-1v for Narrow replacment & logging
    Small Size
    Dual Channel COntroler
    Cons
    Still needs guage
    Very Basic
    Fast Dual Sensor A/F Monitor - Dual $390 Single $290
    Fast Manual
    Pro
    The single Sensor can be upgraded to dual
    Built in logger w/ Play Back 50 min single 25 min dual
    Outputs for External Datalogger
    Narrow Band Replacment on Pre OBDII
    Cons
    No OBDII Narrow support
    Lack of options
    This is not 100% and some of these are more of an intrest to me and I was reading manual at work while actually trying to work so take what I have here with a grain or two of salt.
    Of those listed here to datalog you will need a PDA or laptop, I think the exception os the PLX R-500. Most of these come with datalogging software and cables for connection to the laptop.
    -Robert
    PS - I'll be reading some more manuals, tonight and tomorrow and update those that I have only listed features.
    RobAGD's Avatar
    Reston, Va
    RobAGD's Avatar
    Reston, Va
    Reserved for Break downs and Systems
    -R
    InferAl's Avatar
    InferAl is online now "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    The question was brought up to me today on the PLX no calibration and how it could stay calibrated and not loose some calibration over time. I called and asked but all they would say is that never needs to be calibrated. Does anyone have any thoughts on this
    Video
    InferAl's Avatar
    Nov 2006
    NE Ohio
    Just was reading this but I just got started and have to go to work but it sounds like a interesting debate
    http://www.innovatemotorsports.com/f...ead.php?t=1627
    Video
    RobAGD's Avatar
    Reston, Va
    I just printed out 3 more manuals tonight, I hope to have some stuff added to this tomorrow or friday.
    -R
    InferAl's Avatar
    Nov 2006
    NE Ohio
    Hey Rob how did those new A/F pan out
    Video
    RobAGD's Avatar
    Reston, Va
    Al been real busy and I did a M&G Sunday....
    I am hoping mnore work Tuesday and Wed if I can keep the out off school kids away
    -R
    LouZ's Avatar
    LouZ is offline LX Guru
    Dec 2004
    NY in the mountains
    Bump......getting closer to getting something......anything new?
    Lou -05 Magnum RT AWD ---> FRI'd 392
    RobAGD's Avatar
    Reston, Va
    Lou - its going to come down to a few small things.
    The PLX has the best display and will work down the road for data logging
    If you want something real simple the AEM isnt a bad unit and its just a very basic setup with a Guage.
    Cam went with the DM-100 w/ AFR, EGT and Sensor Pod. This will also data log those 4 items buts its not cheap but it comes with one hell of a display.
    The Dash Hawk is still the best logger for the money, The Auto Ingunity is very nice but you have to pay extra for the DCX PIDs etc but its also a lot stronger package.
    -R
    RobAGD's Avatar
    Reston, Va
    **bumb**
    HEMIDIABLO's Avatar
    HEMIDIABLO is offline LX Newbie
    Feb 2007
    WEST NEW YORK
    what about the wideband commander from dynojet? it seems like a pretty complete kit
    RobAGD's Avatar
    Reston, Va
    HD - it is, it wasnt about when I did this list.
    I have another post that explains more about what I have going on right now.
    Take a look, they are do the job, that all have differnt feature sets.
    The DynoJet kit looks good. I would love it if someone would send me one to take a look at try out and test
    -R
    Super T's Avatar
    Aurora, IL
    Features:
    Accurate to 0.1 AFR
    Pros
    Small Size
    Cons
    Still needs guage
    Very Basic
    Used one of these with a Performance Electronics PCM on a Honda F3 motor... not a bad product.
    Bubba's Dragon's Avatar
    Bubba's Dragon is offline The NEW KRT
    Mar 2006
    Daegu, South Korea
    This is a nice article with some intresting stuff. Im thinking about the PLX-R500.. What add ons should I get?
    KRT:
    2005 BLACK Dragon:
    MODS: None, pure Natural Dragon
