Okay guys... Thanks goes out to Meister for his excellent thermostat thread, which finally prompted me to dive into this simple mod. BTW, I am assuming this would also work just the same on the 5.7L motor. I took my time spending only about 30-45 minutes, since I am a spaz when it comes to wrenching.
Wait for the engine to cool before starting!!!!
1. Here is the Robert-Shaw 170 degree thermostat packaging. I picked up the t-stat at Autozone (part #383170) for $9.99 plus tax.
2. Park your LX with the front of the car higher than the rear as much as possible. This will limit the quantity of coolant that wants to escape.
3. Spread some rags over the radiator area, and grab a 1/2" socket with an extension.
4. With firm pressure, carefully remove the top bolt and set it aside. At this point, red coolant may start to leak out, but it shouldn't be significant.
5. Here is where you really need 3 hands. While holding a 1-gal freezer bag underneath, begin loosening the lower bolt SLOWLY. Coolant will begin to flow out of the upper radiator hose. Be patient and collect as much coolant as possible.
edit: HEMIWAGN has successfully duct taped the freezer bag to various engine components instead of holding the bag. Great idea!!!
