Alright, most of you have seen this wonderful engine. Here it is before doing anything.
First thing is remove the beauty cover. It will get put back later.
Next, remove the inlet air temperature sensor. First remove the plug by sliding the red tab up then squeeze the end to remove the plug. Then carefully pull out the sensor. I found that a screwdriver under the lip helped to pull the sensor out.
Next remove the air tube by lossening the two clamps, one at each end. It slides off pretty easy. Going to save mine for a little additional project for the air intake which I will do this weekend.
Then removed the small rubber hose that is mounted on the backside of the old air box. It just slides off nothing holding it in place.
:twisted:
