Page 7 of 7 FirstFirst ... 567
Results 91 to 93 of 93
Like Tree1Likes
Thread: 25-cent Fan Mod
  1. #91
    WitchyWndy's Avatar
    WitchyWndy is offline Pouting, sniveling and whining :D
    Dec 2007
    Northern, Ohio/Upper, NY
    Quote Originally Posted by riannapo View Post
    Ok, here is what I observed. I had set the low mph fans to kick on above 150 with the AC off. My temp was running around 177 to 179 and with the system turned off, they came on, although I'm not sure just how many fans were on, I only saw two between the radiator and engine, but I thought there were 3 fans because I had to set the settings for HS fan, MS fan, and LS fan. I figured I'd only keep these settings on race day to avoid burning up the fans. I think my issue, however is that they only come on with the engine running. I think the .25 mod will keep them running when the engine is off, correct? That could be the reason to do it via the jumper vs the diablo...
    Bingo! The jumper allows the fans to be on with the engine off.
    2007 SubLime || #1035 || Mods: Arrington 440 ci stroker, 90mm TB, roller rockers and custom 5 pt rollbar, American Racing headers and catless mids, Paramount 8.8 differential, 5K Dominator Converter, drive shaft, DSS 1400hp axles, Transmission built by Enhanced Transmissions, SRT Corsa Catback, LMI prototype headlight CAI, Lots of BT goodies, "Show and Go" install package by BFNY Performance, Tuning by JerseyBoy
    1/4 Best - 4/26/13: 10.58 @ 128.47 2
    011 Atco Vid, Thanks RobAGD: Wheels Up!
    '06 Charger, Magnesium Pearl RT - My awesome DD
    RIP nhDave - Never forgotten
  2. #92
    gunracer's Avatar
    gunracer is offline dsm n.o. member
    Oct 2009
    new orleans la
    had anyone ever thought about unplugging the fan harness at the fan and using like a small marine battery to power the fans them self so you dont have worry about draining your battery and they can stay on longer?
    trufiber ram air hood, diablo sport tuner w/ 93 oct. gas on the 91 oct. tune, ported and polished lower intake manifold, ported and polished throttle body, magnaflow muffler, blastin bobs 10 db exhaust system with the 4" tips, big bully cia, big bully catch can, 160 degree stat, jet hot coated jba shorty headers, lowered and ridin on nitto 420's 255 45r20
    fastest time- 15.532@ 89.52
    "Speed never killed anyone. suddenly becoming stationary, now thats what kills you."
  3. #93
    Jaak's Avatar
    Jaak is offline MOPAR. The only way to BEE.
    May 2005
    Oakville, ON
    Quote Originally Posted by Jaak View Post
    The mod outlined above forces one fan to high speed mode and disables the other fan for low speed mode, but still allows the FCM to enable it for high speed mode.
    If you pull a different relay and put the jumper here, instead, you force both fans on, and the mode is controlled by the FCM. So they will go low speed, or high speed, as determined by the FCM, but never off.
    Attachment 42059
    If you want both fans on high speed mode, then you must pull three relays and put in three jumpers as shown here. Make sure you use wire that can handle the current of the fan in high speed mode. (e.g. 12 gauge)
    Attachment 42060
    It's a simple mod, just like the original outlined above, but requires three jumpers. The next step is to actually wire in a three position switch to do this from inside. Easy....
    I apologise if I've driven this up over the 25 cent level...
    Fixed picture links as requested by PM.
    Super Bee #0427 of 1000 with USW Forged Wheels
    Mopar CAI, Corsa Exhaust, Diablo canned tune, Drag Radials, Skinnies
    12.217 @ 117 mph
