Many thanks to BrilliantBlackHemi and his photo-article on changing spark plugs. When the dealer asked me $230 dollars to do it once, I decided to evaluate my cost to purchase new tools and replacement parts over 4 spark plug service intervals. That's $220 for the next 200,000 km for me. Versus them at $920. $700 anticipated savings.
I completed the 16 plug job last night with success, including setting each one to the right torque.
However there are some important prerequisites I needed to assess before deciding to go ahead with that job, but they aren't mentionned in that article, so I thought I would write this.
It's because taking out spark plugs is the same as open-heart surgery, in the sense that you are exposing the innards that are not designed to be exposed to the elements.
And you have to be confident that you can sew up the patient completely, otherwise you may kill it. That means preventing disasters like cross-threading, introducing contaminated particles that may have wound up on your plugs, cracking the old plug, etc.). So even if you are under warranty, you are assuming these risks.
Before starting, as stated in the service manual, you need to prevent ANY particles from entering into the engine!
Here are the precautions I took, being outdoors initially:
- blast the engine with a vaccuum cleaner hooked up backwards and let the dust settle.
- keep the combustion chamber exposed to a minimum by preparing the new spark plug before taking an old one out.
- wait for a calm day (because there's no way I'm letting a windy day push around dust/dirt/leaves/bugs that could wind up in the compression chamber)
- keep the tools clean (imagine rust particles from old tools winding up you know where)
- work on a thermally static (cold) engine
One other helpful hint regarding the removal of the spark plug boot/coil pack is this: when they say "Remove coil pack by pulling upwards", they really mean "away from the engine along the axis that is perpendicular to the engine", or if you prefer "about 45 degrees relative to the ground". Not 90 degrees to the ground, which is what "upward" usually means...
2005 Magnum RT : 358 rwhp & 372 rwtq
