Results 1 to 6 of 6
    fnkychkn's Avatar
    greasy cardboard box
    replacement bulb specs *
    REPLACEMENT LIGHT BULBS - EXTERIOR
    LIGHT BULBS — Exterior (300, 300 Touring Models)
    Bulb Number
    Low Beam Headlamp 9006
    High Beam Headlamp 9005
    Front Park/Turn Lamp 3757AK
    Front Inner Park Lamp 194NA
    Front Outer Park Lamp 194NA
    Front Fog Lamp—If Equipped 9145/H10 (Serviced at Dealer)
    Front Sidemarker W5W (Serviced at Dealer)
    Tail/Stop/Turn Lamp 3057
    Rear Sidemarker 168
    Backup Lamp 3057
    Center High Mount Stop Lamp (CHMSL) LED
    License 168
    LIGHT BULBS — Exterior (300C Models)
    Bulb Number
    Low Beam Headlamp (Standard Halogen) 9006XS
    Low Beam Headlamp – High Intensity Discharge (HID) D1S (Serviced at Dealer) High Beam Headlamp 9005
    Front Park/Turn Lamp 3157AK
    Front Fog Lamp 9145/H10 (Serviced at Dealer)
    Tail/Stop Lamp 3057
    Tail Lamp 3057
    Turn Signal Lamp 3057
    Backup Lamp 3057
    License W5W
    REPLACEMENT LIGHT BULBS - INTERIOR
    LIGHT BULBS — Interior
    Bulb Number
    Rear Courtesy/Reading Lights W5W
    Rear Compartment (Trunk) Light 579
    Overhead Console Reading Lights 578
    Visor Vanity Lights A6220
    Glove Box Light 194
    Door Courtesy 562
    Shift Indicator Light JKLE14140
    DODGE MAGNUM - exterior
    Back-Up 921/W16W
    CHMSL LED (Replace as unit)
    Front Fog 9145/H10
    Front Park/Turn 3457AK
    Front Sidemarker 194NA
    License W5W
    Rear Sidemarker 3757APY27/7W
    Tail/Stop/Turn 3157KP27/7W
    DODGE MAGNUM - interior
    Door Courtesy 562
    Glove Box 194
    Liftgate 578
    Overhead Console 578
    Rear Courtesy W5W
    Shift Indicator JKLE14140
    Visor Vanity A6220
    NOTE: For lighted switches, see your dealer for replacement instructions.
    All of the interior bulbs are glass wedge base or glass cartridge types. Aluminum base bulbs are not approved and should not be used for replacement.
    '08 & '09 LC REPLACEMENT LIGHT BULBS - EXTERIOR
    LIGHT BULBS | BULB NUMBER
    Low beam headlight – high intensity discharge (hid) | D1S
    High beam headlamp | 9005
    Front park/turn lamp | 3157
    Front fog light | 9145/H10
    Front side marker | 168
    Tail light | 3057K
    Tail/stop/turn light | 3057K
    Rear side marker | 168
    Backup light | 921
    Center high mount stop light (chmsl) | LED
    License | 168
    '08 & '09 LC REPLACEMENT LIGHT BULBS - INTERIOR
    LIGHT BULBS — Interior | BULB NUMBER
    Rear courtesy/reading lights | W5W
    Rear compartment (trunk) light | 562
    Overhead console reading lights | 578
    Visor vanity lights | A6220
    Glove box light | 194
    Door courtesy | 562
    Shift indicator light | JKLE14140
    Optional door map pocket / cupholder lighting | LED
    NOTE: All of the interior bulbs are glass wedge base or glass cartridge types. Aluminum base bulbs are not approved and should not be used for replacement.
    cm2005300's Avatar
    cm2005300 is offline The New "Milli Vanilli"
    Bc
    Nice Info Thanks
    lowriderman3's Avatar
    lowriderman3 is online now Rut Ro!
    Low Down Dirty South!
    2006 DODGE Magnum
    Low beam headlamp
    9006
    9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
    9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
    9006XV XtraVision Halogen - The Brighter Light
    9006CB Cool Blue Halogen - The Whiter Light
    9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
    High beam headlamp
    9005
    9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
    9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
    9005XV XtraVision Halogen - The Brighter Light
    9005CB Cool Blue Halogen - The Whiter Light
    Parking light
    3457ALL
    3457AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
    Front turn signal
    3457ALL
    Rear turn signal
    3757ALL
    Tail light
    3157LL
    Stop light
    3157LL
    High mount stop light
    Assembly
    Fog/Driving light
    9145
    9145ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
    License plate
    2825
    2825LL Long Life Upgrade: Up to twice the life of the standard lamp
    Back up light
    921
    921LL Long Life Upgrade: Up to twice the life of the standard lamp
    Front sidemarker
    194NA
    Rear sidemarker
    3757ALL
    Glove box
    194
    194LL Long Life Upgrade: Up to twice the life of the standard lamp
    Map light
    578
    Dome light
    578
    Step/Courtesy light
    2825
    562
    Trunk/Cargo area
    562
    578
    dumpster's Avatar
    dumpster is offline rock and rolla
    Feb 2007
    zion, illstate
    just what i was thinking of yesterday... thanks guys
    Frank@Diablosport's Avatar
    Frank@Diablosport is offline No more point, coupons now!
    Feb 2008
    Boca Raton, FL
    Thank you for the specs! Comes in handy
    JNL HYDROGRAPHICS GETTIN' THEM WET, ONE AT A TIME!
    Overkill's Avatar
    Overkill is online now LX Padiwan
    Nov 2007
    Whitby ON
    For anyone considering an update to their bulbs, this is a good link http://www.danielsternlighting.com/t...nal_bulbs.html
    For example, 3057 or 3157 bulbs can be replaced with brighter 3457 bulbs. 194 bulbs can be replaced with 168 bulbs.
    The front turns are 3457 already but if you bought the car used like I did you may find someone's used a 3157 which is a dimmer bulb. Also the rear turn signal bulbs are 3757 which has a different tab on the sides of the base but the sockets will still take a 3457 bulb if you simply use a file and smooth down flush the 3457 tabs.
    And remember that on our cars its a hidden blessing that they use amber turn signals front *and* rear, they increase safety in every survey and test I've seen from traffic and safety authorities, so buy amber turn signal bulbs and not clear ones!
