The power steering fluid in my car looked dark, smelled burnt and the steering was stiff until it warmed up. Here's what I did to flush the old oil out myself.
Tools needed: Flat screwdriver, pliers, 10 mm wrench/socket, suction gun, 5/16th OD plastic tubing/hose, funnel, oil bucket, 4 Liters ATF+4, A plug (to fit over the hose connector on the bottom of the reservoir, I used a large vacuum cover that I had, I'm guessing it's 5/16th's ID)
Time needed: less than an hour.
Difficulty Level: A little more than beginner, not much, but some.
1.) Remove the air filter box. 1 clamp on the air intake hose, 1 air box hold down bolt towards the grill, and remove the hose running from the air intake to the manifold. The air box lifts right out.
2.) Use the suction gun to suck as much oil out of the reservoir as possible.
3.) Stuff a rag down under the hoses(for when you pull off the hose).
4.) Locate the smaller of the 2 hoses on the bottom of the reservoir and use the pliers to squeeze the hose clamp and pull the hose off.
5.) Take the 5/16th clear plastic tubing and stuff it down the hose and use the existing clamp to secure it.
6.)Put the plug on the hose connector on the bottom of the reservoir.
7.) Put the funnel in the reservoir and fill up the reservoir with new oil.
8.) Put the 5/16th hose/tubing in the oil bucket. (hang on to it, there's lots of pressure!)
9.) Have someone else start the car and crank the wheel while you pour the new oil. The new oil wouldn't pour out of the container fast enough. The reservoir would suck dry fairly quickly so have the other person shut the car off as needed and refill the reservoir before restarting.
10.) Repeat until you see good clean oil coming out the hose. (I used 3 liters, probably way more than needed.)
11.) Put everything back together as it was and refill the reservoir to the correct level. Be sure to crank the wheels lock to lock a few times to purge any air out of the system and once it's been driven for a while, check the level again.
Here's a picture half way through so you get the idea.
