Results 1 to 15 of 23
    fnkychkn's Avatar
    greasy cardboard box
    LX original equipment spark plugs *
    2.7L champion RE10PMC5 gapped at 0.048" to 0.058" replace every 99,000 miles/165,000 km
    3.5L NGK ZFR5LP-13G gapped at 0.048" to 0.058" replace every 99,000 miles/165,000 km
    5.7L champion RE14MCC4 gapped at 1.14 mm (0.045") replace every 30,000 miles/48,000 km
    6.1L NGK PLZTR5A-13 gapped at 1.3 mm (0.050") replace every 99,000 miles/165,000 km
    Last edited by fnkychkn; 03-26-2007 at 11:11 PM. Reason: added maintenance intervals
    BrilliantBlackHemi's Avatar
    Feb 2004
    Been here 7 years!
    After some research I've found the following application numbers that might be helpful.
    NGK #2313 = Iridium plug for 5.7L Stock heat range
    NGK #2314 = Iridium plug for 6.1L Stock heat range, step colder for 5.7L
    NGK #2315 = Iridium plug for 6.1L one step colder, two steps colder for 5.7L
    Rule of thumb according to www.sparkplugs.com is go one step colder for every 75-100 HP added, hence why the 6.1L stock plug is one step colder than the 5.7L.
    Those of us adding lots of mods might want to step to the better and colder range plugs.
    Sparkplugs.com has them for cheaper 6.95 ea vs 9.99 and 10.99 at Advance Auto Parts.com
    R.I.P. Dad aka DynoBob
    joseph's Avatar
    joseph is offline Banned
    Oct 2004
    Las Vegas, NV
    This place has all the plugs and wires we need: http://www.rpmoutlet.com/ngkinfoi.htm
    DannyC's Avatar
    DannyC is offline Loudest SXT
    Nov 2006
    Lynchburg, VA
    When I went to sparkplugs.com and looked for my 06 Magnum SXT I got this:
    We're sorry, no parts were found for this application
    So fnky does anyone make a plug one step colder for the 3.5?
    Mr.PEZO's Avatar
    Mr.PEZO is offline Mr.LX Poster !
    May 2006
    Vero Beach / Ft. Pierce
    Danny if you copy the part number that fnky put up, into their website it will come up. I did the same thing for my car and nothing came up. I did that and they came up.
    2006 Charger R/T Midnight Blue, AirHammer, Hood Struts, BT Catch Can, BT Pink Thingy Mod, BMC catch can hose upgrade, FLXC Member
    2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
    cadzilla74's Avatar
    cadzilla74 is offline Does this smell like chloroform to you?
    Jun 2005
    FTW TX
    With changing plugs at 30,000 mile intervals I think the stock Champions will be fine for me. I got 29,000 on mine now. When I get the 30k service I'm going to make sure they give me the old plugs to inspect. One of the few things left that an old motorhead like me can still look at and get some idea how my engine is running.
    Fred is offline LX Guru
    Coram, NY
    Don't pay them to change your plugs. If you have any motorhead left in ya, it is a really easy job and saves you MOD MONEY.
    Feb 2005
    GA
    Looks like they have the 300 listed, so you might search for that.
    cadzilla74's Avatar
    Jun 2005
    FTW TX
    Thanks, Fred...I'm sorely tempted but I have so little spare time anymore and I'm a little light in the "proper tools" department to boot. I just don't think I'd enjoy doing it by myself with nobody to hang out with anymore. And the money is a trade-off, what I pay the dealer I can make back while they have the car. If I do the job myself then I'm not making any money the whole time. Sad isn't it?...
    thunderbird's Avatar
    thunderbird is offline LX Newbie
    Sep 2007
    Are changing the plugs in a 3.5 complicated mines are at 73,000 and I would like to change them myself without messing up the air intake has anybody ever tried to replace them.
    Hemi RT's Avatar
    Hemi RT is offline ?????
    Jul 2007
    Medicine Hat, Alberta
    Anyone know why the 5.7 has the plugs being changed a lot more often (lower mileage) than the other models. Is the 5.7 hard on plugs?
    Hemi Registry #00730
    fnkychkn's Avatar
    Quote Originally Posted by thunderbird View Post
    3.5L spark plug change is a little more involved than some others you may have changed. i remove the wheelhouse brace which is bolted to the rear of the strut towers. this helps with clearance issues when removing the upper intake manifold. also, i always replace the EGR tube gasket at the valve to prevent vacuum leaks.
    Quote Originally Posted by Hemi RT View Post
    2.7L, 3.5L & 6.1L use platinum plugs while 5.7L uses traditional copper plugs.
    LeadSSled's Avatar
    LeadSSled is offline Sedan on Steroids
    Aug 2005
    Knoxville, TN
    I see both Bosch and Motorcraft platinum plugs listed on both the Autozone and Advanced Auto Parts websites for the 5.7 R/T. Besides part cost, is there any reason not to switch from the traditional copper plug to a platinum one on the 5.7 hemi to get more plug life?
    2005 Magnum RT - Cool Vanilla (stock) with Torque thrust M wheels.
    1996 Impala SS (nowhere near stock) 400 RWHP, 424 RWTQ all motor.
    12.38 @ 110 mph
    fnkychkn's Avatar
    Quote Originally Posted by LeadSSled View Post
    many have switched to platinum or iridium plugs without issue.
    sizzortomgue is offline LX Newbie
    Dec 2007
    Quote Originally Posted by Fred View Post
    My buddy thinks that the plug replacement is tricky because of the intake cover. Since I'm not a mechanic but in the past could see the ignition cables and plugs relatively easy, I'm wondering how easy it is to change them in the 2.7?
    Thanks for any help!
