This is NOT for SRT8 Models with Brembo Brakes
from FSM:
REMOVAL
NOTE: Before proceeding, (Refer to 5 - BRAKES - WARNING)(Refer to 5 - BRAKES - CAUTION).
1. Raise and support vehicle. (Refer to LUBRICATION & MAINTENANCE/HOISTING - STANDARD PROCEDURE)
NOTE: Perform steps 2 through 6 on each side of the vehicle.
2. Remove wheel mounting nuts (3), then tire and wheel assembly (1).
NOTE: In some cases, it may be necessary to retract caliper piston in its bore a small amount in order to provide sufficient clearance between shoes and rotor to easily remove caliper from knuckle. This can usually be accomplished before guide pin bolts are removed by grasping rear of caliper and pulling outward working with guide pins, thus retracting piston. Never push on piston directly as it may get damaged.
3. Remove Lower caliper guide pin bolt. To do so, hold the guide pin (3) stationary while turning bolt (1).
4. Rotate caliper upward (1), exposing brake pads (2 and 5). Use care not to overextend brake hose when doing this or damage may occur. </B>
5. Remove inboard (2) and outboard (5) brake pads from caliper adapter (4).
6. If necessary, remove anti-rattle clips (3) from upper and lower abutments of adapter (4).
INSTALLATION
NOTE: Perform steps 1 through 7 on each side of the vehicle.
1. Completely retract caliper piston(s) back into bore(s) of caliper. To do so:
- Remove fluid reservoir cap.
- Use hand pressure or a C-clamp may be used to retract piston, first placing a wood block over piston(s) before installing C-clamp to avoid damaging piston(s).
- Install fluid reservoir cap.
2. If removed, attach anti-rattle clips (3) to upper and lower abutments of adapter (4).
3. Install NEW inboard (2) and outboard (5) brake pads on caliper adapter (4). NEW Inboard and outboard pads are interchangeable.
4. Push caliper guide pins into caliper adapter to clear caliper mounting bosses when installing.
5. Rotate caliper downward, aligning upper mounting boss with lower guide pin.
6. Install Upper caliper guide pin bolt (1). While holding guide pin (3) stationary tighten bolt to 60 N·m (44 ft. lbs.) torque.
7. Install tire and wheel assembly (1). Tighten wheel mounting nuts (3) to 150 N·m (110 ft. lbs.) torque. (Refer to 22 - TIRES/WHEELS - INSTALLATION)
8. Lower vehicle.
9. Pump brake pedal several times to set pads to caliper and brake rotor.
10. Check and adjust brake fluid level in reservoir (1). (Refer to 5 - BRAKES/HYDRAULIC/MECHANICAL/FLUID - STANDARD PROCEDURE) CAUTION: When NEW brake pads have been installed, keep in mind that braking effectiveness might be somewhat reduced during the first brake applications following installation.
11. Road test vehicle making several stops to wear off any foreign material on brakes and to seat brake shoes.
I
