Per Magnum8R + TXjeff:
I simply turned the steering wheel to the lock left (to change passenger side bulb) to make some room on the front part of the wheel well, popped out the 3 rivets holding the wheel well flush, peeled it back a bit. QUICKO CHANGO! (note per TXJeff: The rivets in mine look like threaded screws. I pryed up a bit under the rivet with a flat head screwdriver to get the heads around an 1/8", and then took pointy nose pliers and grabbed under the head and hit down on the grips. Pop! It's out with no damage to the rivet. It's a bit of a squeeze to reach your hand in, so, since I was doing drivers side bulb, I held the flap with my right hand and reached with the left, to get the correct angle. On the other side it would be visa versa)
You only need to remove the 3 plastic rivets to get room to install the new bulb. The rivets go right back in if you are carefull. (Note: edit on 4/28/07 - The rivets that I claimed are "pop" rivets are really simple push type butterfly rivets that are 25 cents apiece from the dealer. So you can either get those replacement type rivets, and you don't need a pop rivet gun, or the Xmas tree rivets I mentioned. I still like the Xmas tree ones better since they are easy to get out and put back in again.)
Be carefull not to touch the glass portion. supposed to kill the bulb life. I suggest using a latex glove to avoid the risk of touching the glass part.
Dodge sometimes uses a pop rivet which will break. If so, I suggest you order some Xmas Tree rivets first which simply push in and can be removed and pushed in multiple times. Most car dealers should carry these.
N15543 Splash Shield & Wheel Well Cover Retainer - General Motors & Chrysler
http://northlandfasteners.biz/Store/...oducts_id=1032
