Page 2 of 10 FirstFirst 1234 ... LastLast
Results 16 to 30 of 145
Like Tree2Likes
Thread: Changing your oil for first-timers *
  1. #16
    ccl088 is offline LX Newbie
    Oil Filter??
    Anybody tried the Fram PH8A instead of the Fram PH16.Same filter but the PH8A is longer.Will the PH8A fit instead of the PH16 that it calls for since it's longer?
  2. #17
    frzn is offline LX Newbie
    Remember...5w-20 unless the oil cap otherwise and save your receits as proof you change the oil.I havnt seen Mopar push the issue...but the Benz guys are a bunch of tight azz's and may challenge it.....cover your butts.
  3. #18
    Buck70 is offline LX Newbie
    Feb 2006
    KC KS
    One more tip
    When filling with the new oil, always pull the breather tube from the airbox end and plug/elevate it. When you put a funnel in the filler neck and dump oil in it, oil can/will push up into the tube and run into your airbox/CA tube. Poor design on the filler neck/vent tube combo, makes an oily mess of your air filter on the inside.
    DB
  4. #19
    DakotaDave's Avatar
    DakotaDave is offline Banned
    Jun 2006
    Pleasant Hill, Ia
    Quote Originally Posted by frzn View Post
    My cap says 10W-30.
  5. #20
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Seattle, WA
    Quote Originally Posted by ccl088 View Post
    I wouldn't use fram. (for reasons that start flame wars, so I will leave it at that)
    yes, the longer filters fit well.
    I am running the Motorcraft FL-1A filter (which is an inch or two longer than stock mopar). Needs an extra 1/4-1/2 quart of oil in the engine, but it has MUCH more filter capacity (read: catches dirt for a longer period of time).
    2012 Ram 1500 Express - 4x4 - HEMI - Black
  6. #21
    lafrad's Avatar
    Feb 2004
    Seattle, WA
    Quote Originally Posted by lafrad View Post
    Oh.. and you can get the Oil and Filter all from Wally-World (wal-mart) in one trip... much cheaper that way.
  7. #22
    Bubba's Dragon's Avatar
    Bubba's Dragon is offline The NEW KRT
    Mar 2006
    Daegu, South Korea
    1. N-Series valve(with Nipple to accept hose) is not recommended for passenger cars with low ground clearance.
    I guess no valve for my Magnum, but for you folks with normal height rides I might get one. But I dont like the idea of it popping open and all my oil gone gone gone!
    KRT:
    2005 BLACK Dragon:
    MODS: None, pure Natural Dragon
  8. #23
    joseph's Avatar
    joseph is offline Banned
    Oct 2004
    Las Vegas, NV
    I use K&N oil filters, they are HP, don't drain back, and have a 1 inch nut welded at the end of it, making it real easy to put on and remove.
    This is the least expensive place I've found so far, only $8.50 http://www.ajusa.com/cgi-bin/knfilte...f4c7b722e6e0a8
  9. #24
    havoc1's Avatar
    havoc1 is offline Blood is the Price of Victory
    Dec 2006
    Ft Benning, GA
    Thank goodness I found this--I thought maybe I was going crazy. I've done hundreds of oil changes on dozens of vehicles or engines, and I've NEVER had as much trouble getting a filter off as I have on my Magnum. They must have had a gorilla crank that thing on there at the factory before they dropped the engine in!
    I started off with the mark I mod 0 hand, tried a set of tongs that I've used on stubborn filters in the past, moved to a metal cup-style socket adaptor (stripped/slipped), then a chain-link strap wrench and an open end wrench (can't get them in there to use properly). NO LUCK! The damned thing is all munged up and the clearances really stink. I gave up for the night and I'll probably go out there in the morning and either hammer a screwdriver through it or get that cup-style wrench back out and drill holes in it for self-starting sheet-metal screws. Unbelievable!
    I can't believe a 15-minute job has taken all afternoon! Anyone got any other wild ideas?
  10. #25
    fnkychkn's Avatar
    fnkychkn is online now genuine factory cercumsized sh!tforbrain
    greasy cardboard box
    a good quality metal cup is what i use. never a problem.
    btw, welcome to LXforums. glad you could join us.
  11. #26
    oldschool is offline Look at that wagon she is draggin'!
    May 2006
    CT
    Quote Originally Posted by havoc1 View Post
    Yes the o/c are a little quirky but the car will be just fine for you. Give it a little time and put some more miles on her and you will forget about your misadventures getting the first filter off. I use a metal cup like fnky mentioned with a long adjustable neck wrench and it gives me the room to remove a stubborn filter quick. It's all about just having the right tool for the job.
    oldschool
    BB 7db,Aircharger, blinker mod, BOSS 326 275/40/20, Mobil 1, 20% tint, tit. pedals, full LED interior, LED stock tail conversion, full chrome interior, chrome mirrors/handles, color matched license/fog bezels/chin spoiler, husky mats, Billet Tech goodies, 4"X18" tips, lead foot of course!
    http://www.lxforums.com/gallery/brow...=2&userid=8959
  12. #27
    havoc1's Avatar
    Dec 2006
    Ft Benning, GA
    This is going to sound overly n00bish but...that damned filter isn't reverse threaded or something stupid like that is it? Don't think I've ever done one that was, but this would of course be the first...
  13. #28
    fnkychkn's Avatar
    lefty loosy, righty tighty.
  14. #29
    havoc1's Avatar
    Dec 2006
    Ft Benning, GA
    LOL, sure enough, the tool below is what I was finally able to break it loose with, using a 1/2" socket! I was dumbfounded when I failed to budge it with one of those cup/cruncher attachments. I wish I'd had a torque wrench to check it, because it was on there amazingly tight. Unbelievable!
  15. #30
    Dupie24's Avatar
    Dupie24 is offline Go Dupont Racing!
    Nov 2004
    SoCal
    Quote Originally Posted by DakotaDave View Post
    My cap says 10W-30.
    Then you don't have a 5.7L Hemi! Just kidding, but really, only the 5.7 has the 5/20w spec, its for the MDS.
    BTW, I ordered one of the fumoto valves, looks like the way to go.
    2005 Inferno Red Magnum RT
    Group I and II, sunroof, tow package, nav, sirius, Uconnect, auto headlights, 20" American Racing Torq-Thrust M Wheels, 245/45/R20 Kuhmo Ecsta ASX tires, KW V2 coilover suspension, Hotchkis sway bars, Zoomers Cat Back Exhaust, Aria CAI. LED smoked tail lights. Shaved rear hatch. Pinstriping by 2-Stix. Custom painted palm tree headlights w\halos & painted fog lamps w\halos by AAC.
    Custom Billet Tech "palm tree" pieces
    And lots of little visual mods that make it ours!
