For those that have yet to change their oil for the first time. I know that I like to know what to expect before doing a job, and I couldn't find any photos anywhere, so here you go (for those that are interested)...
First, get her up in the air. I use the poly Rhino Ramps. Strong, and no air-dam contact issues.
This is the belly pan you have to remove. I thought it was smaller, but it covers the whole bottom of the engine. 10mm will remove the four bolts.
Pan removed.
Drain plug location. I didn't install a Fumoto valve (do a search) this time, but I will the next. I wanted to see how this looked before doing so. No problem if the valve sticks out, as the plug is almost horizontal. 13mm wrench.
WARNING - When you remove the plug, the oil will shoot out a foot or more. Put the drain pan way back! Yet another reason a Fumoto valve and hose is so cool.
Oil filter location.
Removing filter. Note: See the orange Wal-Mart special filter wrench I have. Fits great, but it WILL NOT remove the tight stock filter. The socket square rounded off! Luckily, I had a metal one that I use on my truck. The metal one got it off, but it was tight. My metal filter wrench said "Cal-Van 791"
Oil filter manifold
Here was the fun part. After all was finished I was putting the belly pan back on. The last bolt would not thread. Well guess what, the clip thingy that the bolt threads into was gone. I felt into the hole and it was up in the crossmember! Figuring I must have knocked it up in there when removing the pan I fished it out with my magnet. Well, it was broken! I'll replace it at next change. I held it in place with my finger and installed that bolt. Luckily there was enough "tab" left to keep it from spinning. Great job Chrysler! These clips are really fitting to a $30,000+ vehicle!
Overall, quick job. Given the filter orientation, you can fill it before installing it. That's cool.
I did find a lot of this information on what wrench sizes to use, how much oil to use, and that the filter would be tight via other posts on this forum. Thanks to all that contributed that!
Pat
2Likes
sig by ElCobra44 The General Sherman / 2006 Charger R/T, Bright Silver
