Results 1 to 15 of 18
    Spiffywerks's Avatar
    Spiffywerks is offline Whoohooo!
    Lakewood, CA
    Auto Window Down/Up Reset Procedure.
    I recently accidentally disconnected my battery in my car and noticed that my window Auto Up was no longer working. I stopped by the dealership and this is the procedure we went through to get it working again.
    This is for Vehicles equipped with the Auto Window Switches (Marked "Auto" on the switch) for driver and passenger windows.
    1. Turn the key to on.
    2. Roll the window down all the way and hold for 10 seconds. (This resets the auto down)
    3. Pull the switch up and hold for 10 seconds. (This resets the auto up)
    They said that if you listen very closely, you could hear a click from the switch after 10 seconds showing that it has reset.
    Tada! Your windows will now be able to roll up and down with a single press of the switch.
    CURLY's Avatar
    CURLY is offline The Black Pearl
    Jan 2008
    Aurora, Ohio
    Auto roll up ?
    I tried this on mine "the switch say's AUTO" It rolls down if i push it all the way down and let go. BUT it would not roll up, when you let go of the switch it just stops ???
    oldschoolhemiguy's Avatar
    oldschoolhemiguy is offline 5.7 Hemi 2006 RT Magmum
    Aug 2007
    Indiana
    x2 how do you know if you have an auto up, mine also works on the down but not the up
    Tbird100636's Avatar
    Braintree, Massachusetts
    Exclamation
    Quote Originally Posted by jljbtm View Post
    I don't remember 2005 Magnums having this option. If you had auto up/down front windows then both front window switches would say AUTO on them.
    www.ramtruckforums.com
    Exclamation
    Quote Originally Posted by oldschoolhemiguy View Post
    As previously stated, both front window switches would say AUTO on them. There was a TSB for the Auto up/down function not working.
    Ruff n Tuff RT's Avatar
    Ruff n Tuff RT is offline THE PAVEMENT IS MY CANVAS
    HARBOR AREA
    Nice to see you George
    and nice to hear that ....now i know
    I always wait like a whole day and it resets it self
    2006 CHARGER RT / ROAD & TRACK
    stitchmonkey's Avatar
    stitchmonkey is offline What's up Doc? Who's drivin this thing?
    Feb 2007
    It rubs the lotion on it's skin, or else it gets the hose again!
    Quote Originally Posted by Tbird100636 View Post
    Mines an 05 only the driver window says auto up. Does this mean the window goes up automatically when the car's shut off? or uo and down with a touch of the button.
    Exclamation
    Quote Originally Posted by stitchmonkey View Post
    Mines an 05 only the driver window says auto up. Does this mean the window goes up automatically when the car's shut off? Or up and down with a touch of the button.
    This means you have the standard power windows, where the driver's window is auto down only when pressing all the way down to the second detent and releasing. No auto up. Auto up/down windows have extra detents in the front window switches for express opening or closing. Pressing the switch all the way down to the second detent and releasing it causes window to open completely without driver input. Pressing down only half way, or to the first detent is manual operation. Lifting all the way up to the second detent and releasing it causes window to close completely without driver input. Lifting only half way up to first detent is manual operation. Standard power windows use a circuit breaker in the master (LF) switch to control express opening. Auto up/down (express) windows use different front window switches, different window regulators that contain hall-effect switches to detect window position, unique door wiring, and electronic door modules on the CAN bus that look at the signals from the hall effect switches and control power and ground to the regulators.
    Beal's Avatar
    Beal is offline <= That's my dog, Emma
    Wilsonville, Oregon
    Thanks for posting this thread.
    My drivers side recently stopped going up automatically. Did the 10 second trick and bingo, it's back.
    Thanks again.
    Previously known as 'alpha' and 'b.71'
    ZMagnum's Avatar
    Tucson, AZ
    I just had my car at the dealership today for the front passenger side window which wouldn't go down. They had to replace the regulator. I got the car back but the auto up no longer worked (I have auto up/down on both front windows). They took the car back and used the Starscan to fix it. I thought I had read there was a procedure that didn't require Starscan. I was right.
    Apparently a new regulator installation requires a reset as well as a battery disconnection.
    COOKZ32's Avatar
    COOKZ32 is offline AK RT C-LEG DAVAF
    Feb 2006
    Minnesota, we need longer ski runs
    Why did the auto up feature on my driver's side window stop working. Only the up feature on the driver's side stopped working. I just reset it, and now it works fine.?????
    07 Super Bee 0991 * SRT8 pedals custom install by F1fan - Rick and Jina SUPERBEE's - Gloss Black Decals and Custom Paint by Maple Plain Auto Body, Leanord - Seq. Turn Signals, Flashing 3rd brake light - Billett Technology Caps - BMC Performance - DMH Cutous - NoEsp&Fan - Hotchkis Sway Bars - Saint Paul Automotive, Scott - Crazy Luck rear deck BEE - Freebird BEE on custom plates
    fnkychkn's Avatar
    greasy cardboard box
    Quote Originally Posted by COOKZ32 View Post
    possible candidate for TSB 08-011-07A.
    COOKZ32's Avatar
    Feb 2006
    Thanks Funky! I hope not, I hope it was just a fluke........
    roswald0511's Avatar
    roswald0511 is offline RIP Clifford
    Where the Wire was filmed
    Can we swap motors and switches from a later build LX?
    fnkychkn's Avatar
    Quote Originally Posted by roswald0511 View Post
    probably, but only if the donor vehicle has the same type of system (auto down vs auto up/down).
