This information, or parts thereof, has been posted before in various threads. But here it is again. In the one spot.
YOU GET A CEL
Ensure car doors are closed. Turn key ON>ACC>ON>ACC>ON in rapid succession. Codes will display in EVIC in place of Odometer reading. WRITE THE LETTERS/NUMBERS DOWN. COPY YOUR VIN NUMBER FROM THE DASH TAG.
DECODE THE DIAGNOSTIC TROUBLE CODES (DTC)
Go to this site: http://www.obdii.com/codes.asp
Choose manufacturer from pull-down menu. Type in your DTC (the prefix letter and the numbers you wrote down in the car). Click on the "Lookup DTC Information" button. On the next screen, type in VIN # if needed for further clarification of DTC.
For quick verification, go to this site:
http://www.iequus.com/support/obd2_definitions.php
Put in your DTC. Sometimes you'll get a slightly different code explanation there that makes more sense to you.
Write down the DTC explanation (from both sites if necessary) and ....
THEN WHAT?
Do a search in the forum for threads that address the issue you have discovered. Get educated. Then, if necessary...
Post your own thread and ask for further guidance.
1Likes
