This list provides Mercedes part numbers for items useful to LX owners.
Ok, first item is the transmission dipstick
This allows checking the fluid level without having to use the starscan for tranny temps.
140 589 15 21 00
Trans Pan w/drain plug
140 270 08 12
Transmission Pan Gasket
Normal maintenance part
140 271 00 80
Transmission Filter
140 277 00 95
Transmission Electrical plug Adapter with O-rings.
You need this if you have a leak at the plug on the transmission.
203 540 02 53
Transmission Electrical plug Adapter O-rings.
These are replacement o-rings for the above plug.
026 997 40 48 28
026 997 41 48 28
Blue Top Transmission Solenoids
These will increase line pressure and therefore shift firmness in the 5 speed NAG1 Tranny.
240 270 00 89
Rear Diff Cooler and required Diff Cover for 215mm rear
Keep those rears cooled off.
Cooler: 171 351 0108
Cover: 204 351 05 08
Thanks to Jim McVeigh
Parking Brake Pedal Cover (Matches Mopar Pedal Covers)
203 430 00 84
!!!May need a bit of trimming to the rubber back in Auto cars!!!
Thanks to Speedy at Challengertalk.com
More to come.
Reserved
Hi good stuff so I assume I can use the trans stick in my 300 CRD since its a damiler/chrysler engine, so its just take the cap off the trans tube and shove the dipstick in?
Catchcan,22Elite,DNX9260,DVD HR,Alpines,amp,StarTech,07-3.0CRD,314BHP-645 N/Tq,spoliers,Mesh Grill,GB roof,Kluck fenders,Passport 9500ci,Paddle shifters,6K HID,HL,FL,BU,Pillar POD,tracker,3" SS pipes no mufflers,Razor Edge,Remote Start,belly lights,LSD,Pedder,20" w/nitto,sway bars, CelticTuning remap,Lg intercooler,Tq limiter off, VIS SRT hood,GripTuning,Volant,6K LED HALOS,HL,FL,Aeroforces,REM R Brace,tranZformer,F&B Cam.VIP300,LXCustomSolutions,StopTech,No ESP
Awesome information - Thanks!!!!!!
"Death Smiles at Everyone -- Marines Smile Back"
MOD LIST: C/F Hammer, Flowmaster Ex, FRI-Sidewinder Cam, Gibson Headers, Predator, B.T. Ported T.B., Lil Silver Box, Red Illum Rear Wing, Blue Angel Eyes, Yellow HID FOGs, 09 Intake, CTP Spacers, SRT Rails & Injectors, SRT Rear w/3.55 Gears and 2010 R/T Axles....What's Next?
Will the blue top solenoids cause future problems down the road with the added line pressure, and does the tranny need more fluid to compensate?
Magnum Man
I haven't had any problems. Downshifts are firmer. Normal fluid fill procedure (and volume) with the above mentioned DB measuring stick.
Any part numbers for the paddle shifters?
You can up the shift firmness with a simple, yet effective, pred tuner
Posted via LXFMobile
TAG
Yay, resurrecting old threads. so when we say these are Mercedes part numbers, does that mean that I have to go to a Benz dealer and not a Dodge dealer for the parts?
Yes
Or goto purchase off parts.com If you use this link you can insert the part#. It is possible a vendor here can get these parts for you. Mabye Builder Bill or Southern Hot Rod.
2005 Silver Magnum R/T
5.7 Stock Bottom
12.115@111mph 1.69 60'
Pick a lane...same destination
2011 IMSM Pro Outlaw Street Heat Division Rookie of the Year
2012 Midwest Index Shootout Pro Outlaw Street Heat Division Champion
HEADS-UP DRAG RACING
10.645 @ 125.18 Tuned by Tim Barth @ MPH Racing
