Results 1 to 15 of 23
Like Tree2Likes
Thread: fuse location/amp rating/circuit protected *
    fnkychkn's Avatar
    greasy cardboard box
    these are for '06 magnum but should be the same for all LXs '07 & older.
    Power Distribution Centers
    Front Power Distribution Center Fuses
    A power distribution center is located in the engine compartment. This center contains fuses and relays.
    CAUTION:
    • When installing the Power Distribution Center cover, it is important to ensure the cover is properly positioned and fully latched. Failure to do so may allow water to get into the Power Distribution Center, and possibly result in a electrical system failure.
    • When replacing a blown fuse, it is important to use only a fuse having the correct amperage rating. The use of a fuse with a rating other than indicated may result in a dangerous electrical system overload. If a properly rated fuse continues to blow, it indicates a problem in the circuit that must be corrected.
    thanks to ZMagnum for posting this diagram:
    Cavity/ Fuse /Circuits
    1/ 20 Amp Yellow/ Left High Beam Headlight
    2/ 20 Amp Yellow/ Right High Beam Headlight
    3/ 15 Amp Dk. Blue/ Adjustable Pedal
    4/ 20 Amp Yellow/ Horn
    5/ 25 Amp Clear/ Headlamp Washer — If Equipped
    6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
    7/ 20 Amp Yellow/ Fog Lamp
    8/ 15 Amp Dk. Blue/ Park Lamp
    9/ 15 Amp Dk. Blue/ Non ABS Brakes
    10/ 5 Amp Orange/ Starter
    11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
    12/ — —
    13/ — —
    14/ 25 Amp Clear/ Powertrain Control Module
    15/ 20 Amp Yellow/ Injectors, Ignition Coils
    16/ 15 Amp Dk. Blue/ Powertrain Control Module
    17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
    18/ 30 Amp Pink/ Windshield Wiper/Washer
    19/ 50 Amp Red/ Radiator Fan
    20/ 20 Amp Lt. Blue/ Starter
    21/ 50 Amp Red/ ABS Pump Motor
    22/ 40 Amp Green/ Radiator Fan High/Low
    23/ 50 Amp Red/ High Intensity Lighting
    24/ — —
    25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
    26/ 20 Amp Lt. Blue/ Transmission
    27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
    Rear Power Distribution Center Fuses
    There is also a power distribution center located in the trunk under the spare tire access panel. This center contains fuses and relays.
    CAUTION:
    1/ 60 Amp Clear/ Ignition Off Draw
    2/ 40 Amp Green/ Battery
    3/ — —
    4/ 40 Amp Green/ Battery
    5/ 30 Amp Pink/ Heated Seat/Steering Column
    6/ 20 Amp Yellow/ Fuel Pump
    7/ — —
    8/ 15 Amp/ Dk. Blue Ignition Start/Run - Start
    9/ 20 Amp Yellow/ Console Power Outlet
    10/ 10 Amp Red/ Rear Fog Lamp — If Equipped
    11/ 25 Amp C/BRKR/ Memory Module/Door Locks
    12/ 25 Amp C/BRKR/ Passenger Power Seat
    13/ 30 Amp C/BRKR/ Door Module Run/Acc/Delay
    14/ 10 Amp Red/ Sentry Key/Remote Keyless Entry/Cluster
    15/ 20 Amp Yellow/ Brake Light (5.7L)
    16/ 20 Amp/ Yellow/ Power Outlet Trunk - if equipped
    17/ — —
    18/ 20 Amp/ Yellow Selectable Power Outlet
    19/ 10 Amp/ Red Stop Lamp
    20/ 20 Amp Yellow Rear Wiper — If Equipped
    21/ — —
    22/ — —
    23/ — —
    24/ — —
    25/ — —
    26/ — —
    27/ 10 Amp Red/ Airbag/Occupant Classification Module
    28/ 10 Amp Red/ Curtain Airbag - if equipped
    29/ 5 Amp Orange/ Sentry Key/Remote Keyless Entry/Powertrain Control Module Ignition Feed
    30/ 10 Amp Red/ Steering Column Module/Power Mirrors - if equipped
    31/ — —
    32/ — —
    33/ — —
    34/ — —
    35/ 5 Amp Orange/ Power Antenna/Garage Door Opener/Ignition Delay
    36/ 20 Amp Yellow/ Radio/Navigation
    37/ 15 Amp Dk. Blue/ Transmission
    38/ 5 Amp Orange/ Analog Clock/Garage Door Opener / trunk light (charger)
    39/ 10 Amp Red/ Heated Mirror
    40/ 5 Amp Orange/ Power Mirror
    41/ 10 Amp Red/ Climate Control Module/Headlamp Leveling — if equipped/Rear Park Assist — if equipped/Tire Pressure Monitoring — if equipped
    42/ 30 Amp Pink/ Automatic Temperature Control (ATC) Blower Motor
    43/ 30 Amp Pink/ Rear Defroster
    44/ 20 Amp Lt. Blue/ Audio Amplifier / sunroof
    thanks to Tbird100636 for posting this '08 front fuse box (TIPM) diagram and fuse & relay chart:
    Here's a diagram of the TIPM (The sucessor to the IPM, more advanced functonality) Because of the stupid Adobe SVG viewer they use 2007 up, I had to copy it piece by piece. Here it is...
    Fuses:
    1.-15A-TIPM internal electronics-Washer Motor
    2.-25A-ASD Relay coil and PCM
    3.-25A-Run/Start Relay
    4.-25A-S143-To PCM (Gas) ECM (Diesel)
    5.-15A-ECM (Diesel)
    6.-25A-ASD relay output-to S107-to various powertrain components(Gas) S156 to various powertrain components (Diesel)
    7.-25A-Underhood Lamp (Police), Headlamp Washer Relay (Via S130)
    8.-25A-Starter Relay Contacts
    9.- Starter Relay
    10.-30A-Wiper On/Off Relay, Wiper High/Low Relay Coil
    11.-30A-ABS Module-Control Valves
    12.-40A-Radiator Fan Control Relay
    13.-50A-ABS Module-Pump Motor
    14.-Not used
    15.-50A-Radiator Fan High Low Control Relay Coil, Radiator High Fan Relay
    '08 Challenger
    FUSES/INTEGRATED POWER MODULE (IPM) - SRT8
    Integrated Power Module (IPM)
    The Integrated Power Module (IPM) is located in the engine compartment. This module contains fuses and relays.
    CAUTION:
    • When installing the integrated power module cover, it is important to ensure the cover is properly positioned and fully latched. Failure to do so may allow water to get into the integrated power module and possibly result in an electrical system failure.
    Cavity | Cartridge Fuse | Mini-Fuse | Description
    1 | — | 15 Amp Blue | Washer Motor
    2 | — | 25 Amp Neutral | Powertrain Control Module (PCM)
    3 | — | 25 Amp Neutral | Ignition Run/Start
    4 | — | 25 Amp Neutral | Alternator
    5 | — | — | —
    6 | — | 25 Amp Neutral | Ignition Coils/Injectors
    7 | — | — | —
    8 | — | 25 Amp Neutral | Starter
    9 | — | — | —
    10 | 30 Amp Pink | — | Windshield Wiper
    11 | 30 Amp Pink | — | Anti-lock Brake System (ABS) Valves
    12 | 40 Amp Green | — | Radiator Fan
    13 | 50 Amp Red | — | Anti-lock Brake System (ABS) Pump Motor
    14 | — | — | —
    15 | 50 Amp Red | — | Radiator Fan
    16 | — | — | —
    17 | — | — | —
    18 | — | — | —
    19 | — | — | —
    20 | — | — | —
    21 | — | — | —
    22 | — | — | —
    '08 Challenger
    CAUTION:
    • When installing the Power Distribution Center cover, it is important to ensure the cover is properly positioned and fully latched. Failure to do so may allow water to get into the Power Distribution Center, and possibly result in an electrical system failure.
    Rear Power Distribution Center Fuses - SRT8
    1 | 60 Amp Yellow | — | Ignition Off Draw (IOD)
    2 | 40 Amp Green | — | Integrated Power Module (IPM)
    3 | — | — | —
    4 | 40 Amp Green | — | Integrated Power Module (IPM)
    5 | 30 Amp Pink | — | Heated Seats - if equipped
    6 | — | 20 Amp Yellow | Fuel Pump
    7 | — | 20 Amp Yellow | Sub Amp - if equipped
    8 | — | 15 Amp Blue | Diagnostic Link Connector (DLC)/Wireless Control Module (WCM)/Wireless Ignition Node (WIN)
    9 | — | 20 Amp Yellow | Power Outlet
    10 | — | — | —
    11* | — | — | —
    12* | — | — | —
    13* | — | — | —
    14 | — | 10 Amp Red | AC Heater Control/Cluster/Security Module - if equipped
    15 | — | 20 Amp Yellow | —
    16 | — | 20 Amp Yellow | —
    17 | — | 20 Amp Yellow | Cluster
    18 | — | 20 Amp Yellow | Selectable Power Outlet
    19 | — | 10 Amp Red | Stop Lights
    20 | — | — | —
    21 | — | — | —
    22 | — | — | —
    23 | — | — | —
    24 | — | — | —
    25 | — | — | —
    26 | — | — | —
    27 | — | 10 Amp Red | Occupant Restraint Controller (ORC)
    28 | — | 10 Amp Red | Ignition Run
    29 | — | 5 Amp Orange | Cluster/Electronic Stability Program (ESP)/Powertrain Control Module (PCM)/STOP LIGHT Switch
    30 | — | 10 Amp Red | Door Modules/Power Mirrors/Steering Control Module (SCM)
    31 | — | — | —
    32 | — | — | —
    33 | — | — | —
    34 | — | — | —
    35 | — | 5 Amp Orange | Antenna Module - if equipped/Power Mirrors/Rain Sensor - if equipped
    36 | — | 20 Amp Yellow | Hands-Free Phone - if equipped/Video Monitor - if equipped/Radio
    37 | — | 15 Amp Blue | Transmission
    38 | — | 10 Amp Red | Cargo Light/Vehicle Information Module - if equipped
    39 | — | 10 Amp Red | Heated Mirrors - if equipped
    40 | — | 5 Amp Orange | Auto Inside Rearview Mirror/Heated Seats - if equipped/Switch Bank
    41 | — | 10 Amp Red | AC Heater Control/Headlights/Park Assist - if equipped/Tire Pressure Monitoring - if equipped/Occupant Restraint Controller (ORC)
    42 | 30 Amp Pink | — | Front Blower Motor
    43 | 30 Amp Pink | — | Rear Window Defroster
    44 | 20 Amp Blue | — | Amplifier - if equipped/Sunroof - if equipped
    *Cavities 11, 12, and 13 contain self-resetting fuses (circuit breakers) that are only serviceable by an authorized dealer. The Cluster (without power memory seat), the Driver Seat Switch (with power memory seat), and the Memory Module (if equipped) are fused by the 25 amp circuit breaker in Cavity 11. The Passenger Seat Switch is fused by the 25 amp circuit breaker in Cavity 12. The Door Modules (except base), the Driver Door Lock Switch (base), the Driver Express Power Window Switch (if equipped), and the Passenger Door Lock Switch (base) are fused by the 25 amp circuit breaker in Cavity 13. If you experience temporary or permanent loss of these systems, see your authorized dealer for service.
    2011
    Last edited by fnkychkn; 08-07-2011 at 09:58 PM. Reason: added diagrams to first post and added '08 TIPM info
    ZMagnum's Avatar
    Tucson, AZ
    Jaak's Avatar
    May 2005
    Knowledge Base!!!! Don't let it get buried!
    (Damn new posts function... It's here already!)
    2006 Magnum SRT8 - 11.85@117
    fnkychkn's Avatar
    Quote Originally Posted by zxlwno
    Can you also post the relay functions?
    sent you an e-mail. can you post it to the KB. thanks
    ZMagnum's Avatar
    Tucson, AZ
    I didn't get nothing yet FC.
    Quote Originally Posted by fnkychkn
    ASU_Magnum's Avatar
    ASU_Magnum is offline I'll be back...someday
    Nov 2005
    Phoenix
    Ok,
    I installed my amp and speakers a few days ago and I want the amp to come on when the radio is turned on and for it to go off when the radio is off. Right now the amp turns on and is always on with the car in ACC or ON, regardless of the radio being on. Could I tap Fuse 36/ 20 Amp Yellow/ Radio/Navigation with the remote wire to make it so that the amp only turns on when the radio is on?
    2005 Magnum SXT Bright Silver - SOLD
    2006 Yamaha R6 Raven -STOLEN
    Quote Originally Posted by Zmagnum
    You are famous. You have the fat woman sittin' crack findin' Magnum
    fnkychkn's Avatar
    fuse 36 is always live (B+). factory amplifier is triggered by a wake-up signal over CAN-B bus.
    ZMagnum's Avatar
    Tucson, AZ
    LX Relays (Front & Rear)
    In Front:
    In the Back:
    IDSmoker's Avatar
    IDSmoker is offline LX Padiwan
    Boise, ID
    For anyone interested, here's the total quanitity of fuses broken down by type:
    • 05 Amp Orange - 5
    • 10 Amp Red - 8
    • 15 Amp Dk. Blue - 7
    • 20 Amp Lt. Blue - 3
    • 20 Amp Yellow - 13
    • 25 Amp C - 2
    • 25 Amp Clear - 2
    • 30 Amp C - 1
    • 30 Amp Pink - 7
    • 40 Amp Green - 3
    • 50 Amp Red - 3
    • 60 Amp Clear - 1
    There may be some errors here, since I did a quick 'n dirty spreadsheet for this...
    STAGE 3 R/T's Avatar
    Jan 2006
    Argyle, Tx
    anything for the windows? my front right window and the window lock is not working. other 3 are working fine...
    fnkychkn's Avatar
    Quote Originally Posted by hawaiiHEMI View Post
    R/F window switch is fed from driver's switch. if it was a main power feed problem, no windows would work. not clear on the window lock part of your question. the only window lock switch is on driver's side. maybe you mean the door lock switch on passenger's side?
    any mods done lately on that door and/or harness? maybe the switch connector became dislodged.
    Jan 2006
    Argyle, Tx
    i just did the lambo door install. the passengers window was working fine. i checked all my wires they are connected properly...
    lastnight approx 10PM every window was working with zero probs. today start car, try to lower windows and the front left window no work! that i know on the drivers side, the function to lock the windows doesn't work as well. i am going to double my wires tomorrow... just wondering if my motor went out or? thanks again mr funky!
    atwong1's Avatar
    atwong1 is offline Paddle Shifter rocks!
    Nov 2007
    Atlanta
    deleted because not very clear
    Check out my front brakes, I am an AWD!!!!
    atwong1's Avatar
    Nov 2007
    Atlanta
    I want to use the unused slot 10 as shown below. How do I get parts to do it?
    3 | — | — | —
    10 | — | — | —
    11* | — | — | —
    12* | — | — | —
    13* | — | — | —
    20 | — | — | —
    21 | — | — | —
    22 | — | — | —
    23 | — | — | —
    24 | — | — | —
    25 | — | — | —
    26 | — | — | —
    31 | — | — | —
    32 | — | — | —
    33 | — | — | —
    34 | — | — | —
    leeruisea is offline LX Newbie
    Nov 2009
