Results 1 to 15 of 16
    TehKing's Avatar
    TehKing is online now It's good to be TehKing.
    Feb 2004
    Twin Cities, Minnesota
    Correct Automatic Lock Procedure *
    Thanks to zxlwno for discovering this error in the owners manual.
    The 2005 Magnum manual has it backwards between turning "Flash Lights on Lock/Unlock" on/off and "Unlock All Doors on first press." Here is the correct way.
    To turn off/on "Flash Lights On Lock/Unlock":
    1. Press the UNLOCK button for 4 to 10 seconds.
    2. While the UNLOCK button is pressed, (after 4 seconds) press the LOCK button. Release both buttons.
    The "Flash Lights On Lock/Unlock" feature can be reactivated by repeating this procedure.
    To turn off/on "Remote Unlock Driver's Door 1st":
    1. Press the LOCK button for 4 to 10 seconds.
    2. While the LOCK button is pressed, (after 4 seconds) press the UNLOCK button. Release both buttons.
    The "Remote Unlock Driver's Door 1st" can be reactivated by repeating this procedure.
    To turn off/on "Sound Horn On Lock":
    2. While the LOCK button is pressed, (after 4 seconds) press the PANIC button. Release both buttons.
    The "Sound Horn On Lock" feature can be reactivated by repeating this procedure.
    I tried this last procedure using the UNLOCK button and PANIC button together. It didn't seem to do anything. If anyone else finds that it changes something please let the Forum know.
    Automatic Door Locks at 15mph:
    For vehicles not equipped with the EVIC, the Automatic Door Locks can be enabled or disabled by performing the following procedure:
    1. Close all doors and place the key in the ignition.
    2. Cycle the ignition switch between LOCK and ON and back to LOCK 4 times ending in the LOCK position.
    3. Depress the power door lock switch to lock the doors.
    4. A single chime will indicate the completion of the programming.
    Automatic Unlock:
    3. Depress the power door unlock switch to lock the doors.
    You don't have to burn books to destroy a culture, just get people to stop reading them.
    PaulFix's Avatar
    PaulFix is offline Mr. White Chocolate P. Rock
    May 2005
    BC, Canada
    THanks, very handy for some without EVIC.
    Dodge Magnum RT AWD MDH=Jan 19th 2005 7-8pm
    Tow package, Midnight Blue, Painted spoiler body colour, Auto headlights, HID lows, Fogs on with Hi beams, SC flash with custom tranny and 91 tune, RER MyGig installed, Tranzformer, Resonators deleted, Custom Stainless intake.
    160,000km driven very hard, repairs include replaced front brake rotors and pads $200, rear pads$, ebrake shoes, all 4 tie rod ends $50ea (only 1 was loose), front sway bar rubber bushings $25(first thing to check if front is clunky); 3m refinished headlights WOW $30, 4 sets of tires, 2 tranny filter and flushes,
    Turf's Avatar
    Turf is offline '05 Dodge Magnum SXT AWD
    Jan 2006
    Michigan
    last weekend i had the manual out and was trying to program the car to unlock all the doors on one press, and discovered that it was backwards.
    vidwiz is offline LX Newbie
    Feb 2006
    On page 22 of my 05 300c manual, it describes the procedure to make the trunk open with only one press of the trunk button. This has not worked for me, I have tried reversing, and various combinations with no luck. Anyone know the proper buttons to push? This cannot be set in my EVIC.
    bookeem's Avatar
    bookeem is offline All Black Everything!!!
    north jersey
    automatic unlock is , when the car is put in park and the key is taken out, all doors unlock bythemselves?
    is there a way to have the interior lights/map lights come on when the key is taken out, and then stay on and dim off after u get out and close the door?
    i find myself at night having to park, i take the key out, and im like ok its dark, and have to open the door for the map lights to come on, to find what ever i may be taking out the car with me , my last car , the interior lights would come on when the key was removed from the igntion, would stay on for about 30 seconds then dim out..
    Thank You Haz
    cjsCharger is offline LX Newbie
    Mar 2006
    Does the automatic unlock do the rear doors also? I hate having someone in the back seat and having to manually unlock their doors for them.
    2006 Brilliant Black Dodge Charger Mods -SRT 8 hood -20% Tint -Cold Air Intake -20" DIP Nitro Wheels on Nexen rubber -XM Radio
    1995 Deep Garnet GMC Yukon GT 2Door 5.7 L 350 V8 Mods -Full Audio System -7" In Dash DVD Player -20% Tint -Tow package
    bookeem's Avatar
    north jersey
    yeah same here, thats what i was asking just in different words..lol
    Thank You Haz
    F1fan's Avatar
    F1fan is offline "There can be only one"
    Nov 2005
    MPLS, MN
    Yes it does unlock the back doors too
    bookeem's Avatar
    north jersey
    what makes them unlock though, the car being put in park, turning the car off taking the key out?
    Thank You Haz
    done's Avatar
    done is online now Member for 7 years
    Old Hickory, TN
    Quote Originally Posted by bookeem
    None of the above. You just open the driver's door.
    bookeem's Avatar
    north jersey
    ahh so i see says the blind man...i"ll be trying a few of those when i get home ...
    Thank You Haz
    bookeem's Avatar
    north jersey
    ok, what about the headlights on with unlock button on the FOB...
    ide like to disable that so my headlights dont turn on when i hit the unlock on the remote..
    Thank You Haz
    ZMagnum's Avatar
    Tucson, AZ
    I believe this can be done but if you don't have EVIC then it's a trip to the dealership for Starscan changes.
    bookeem's Avatar
    north jersey
    thank you ZMagnum
    Thank You Haz
    UK CHRYSLER 300C's Avatar
    UK CHRYSLER 300C is offline LX Padiwan
    Quote Originally Posted by vidwiz View Post
    I have tried this and it doesnt work for me either,any ideas,thanks
